Installed D-Rings in the Bed (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neubs, Feb 27, 2009.
  1. Feb 6, 2018 at 11:27 AM
    #641
    yarberrymt
    yarberrymt Well-Known Member
    Got my swiveling!
    So this size was perfect. The bearings were cheap. This functions 100% and I have 360 degree swiveling on each D-ring and I'm happy.
    **However, I toasted a bearing trying to torque it down with a torque wrench. Is should have known, but the bearing deformed under the pressure, it widened and it smooshed down which hindered the swiveling function. My solution was to give them several good, quick blasts with an impact gun, but avoid the slow torquing pressure the torque wrench provided.
    So I'll pick up my search for a harder metal/material bearing of the exact same size so I can swap them out and torque them to spec.
    But this solution is just what I was looking for and the huge (albeit perfect) holes I cut in my OEM bed mat now have a purpose!
  2. Feb 6, 2018 at 11:31 AM
    #642
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    You should of used steel instead of brass/bronze , it would be a lot stronger and you could torque it to the proper spec
  3. Feb 6, 2018 at 11:39 AM
    #643
    unclejunk
    unclejunk Well-Known Member
    Albany NY
    '18 Quicksand OR DCSB 6MT
    I have been planning to do this and was going to use a steel or SS spacer without a flange from McMaster. I'm no engineer.. what is the purpose of the flange in this application? As long as the spacer touches the bottom of the bolt head and the top of the washer, it doesn't seem necessary to have a flange. I think it would be much easier/cheaper to find a steel spacer than the flanged version.
  4. Feb 6, 2018 at 3:01 PM
    #644
    yarberrymt
    Take a second to read my post.
    igno1tus[QUOTED] likes this.
  5. Feb 6, 2018 at 3:04 PM
    #645
    yarberrymt
    I just jumped on and chased an idea another poster referenced with the flanged-type bearing. The flange bit may* be better for load distribution (?), but I do think a regular, non-flanged, spacer would work and serve the same purpose.
    Would probably be much easier to find as well.
    Let me know what you end up finding and how it goes.
  6. Feb 6, 2018 at 4:04 PM
    #646
    igno1tus
    :anonymous::thumbsup::rofl:
  7. Feb 6, 2018 at 5:42 PM
    #647
    22argh
    22argh Well-Known Member
    nice!
  8. Feb 6, 2018 at 5:52 PM
    #648
    whitburg24
    whitburg24 Member
    Zach
    2017 Tacoma SR5 MGM DCSB
    Nice job OP nice clean install, that bead mat is sweet to too. thanks for the idea
  9. Feb 6, 2018 at 6:46 PM
    #649
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    For anyone that installed rings in the composite bed itself (not the bed bolts), I'd like to see pics of the locations you chose.
  10. Feb 6, 2018 at 6:54 PM
    #650
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    I did turned out great!
    Check my build
  11. Feb 7, 2018 at 2:57 PM
    #651
    Neubs
    Neubs [OP] Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
    Great idea! Nicely done. Good luck finding steel bushings. Not sure if you have any Taylor’s DIY Centers near you but if you do, they have a good hardware section with lots of random misc stuff.
  12. Feb 8, 2018 at 8:41 AM
    #652
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    With a harder material like steel, I don't think that you would need the flange, mostly because the sleeves under the bolt don't have them. I did some looking on McMaster Carr. While they have some spacers (straight or flanged) that would work, the prices are pretty high. Around $1.00 each, like the brass bushings, feels right.
  13. Feb 20, 2018 at 12:39 AM
    #653
    lensam69
    lensam69 Member
    San Francisco Bay Area
    '17 DCSB V6 4x4 OR
  14. Mar 5, 2018 at 4:42 PM
    #654
    pretzelcuatl
    pretzelcuatl New Member
    Henry
    2008 Toyota Tacoma
    Added BAKFLIP bed cover, D-rings
    After ten years I finally put a BAKFLIP bed cover on and just put in four D-rings my 2008 Tacoma. The whole project was pretty easy, used a hand drill and vise to widen the ring base holes to 1/2" (couldn't hold them down well enough with my drill press), and it took seconds with a Dremel to remove the enigmatic thread from the bolts to get the washers off. Even the bolt removal was easy (though I pre-sprayed WD-40 on the thread of the bolts a few hours before attempting). Some people had to shave an edge off their washers, but it seems to me it's better to have the washers against the bed, not the ring base, and with that config no shaving is necessary. Thanks for everyone here for the pointers.
  15. Mar 17, 2018 at 4:00 PM
    #655
    lensam69
    lensam69 Member
    '17 DCSB V6 4x4 OR
    @scrapedface Doesn't get enough credit for this idea :D.
    I did the same thing, and it works out great because the washer acts as a "bearing" as the bolt spins, which lets you put a good amount of pressure with a file. It took a whole 30 seconds per bolt to grind down those ribs.
    Anywho... First mod done :) Bolts were ok, only one of the gave me some grief, but nothing a bit of WD-40 couldn't solve.
    I went with the army surplus d-rings, and ended up doing all six bed bolts (I like having options). Instead of cutting holes, I just did slits, so I can hide the rings when not in use. (The mat also serves to muffle any rattling).
    Hidden:
    Deployed:
  16. Mar 17, 2018 at 4:34 PM
    #656
    NMTrailRider
    New Mexico
    Nice. I plan to go the same route. I'm thinking about drilling two 1/4" (or 1/2") holes in the mat for each ring, with a single slit cut between the two holes. So when the ring is "up", each side of the ring will protrude through a hole. Make sense? I thought I'd put a wood block under the mat to drill.
  17. Mar 17, 2018 at 4:48 PM
    #657
    lensam69
    lensam69 Member
    '17 DCSB V6 4x4 OR
    Nice. Try one without the holes first. The mat is pretty thick and can hold up the ring quite straight (provided you cut the slit truly parallel to the ring)
    If you don't like it, you can always poke holes later
    NMTrailRider likes this.
  18. May 12, 2018 at 1:13 AM
    #658
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Where is everyone getting the factory D-rings? Any dealer or is there someplace online that has a best price?
  19. May 12, 2018 at 1:26 AM
    #659
    Muddinfun
    Muddinfun Well-Known Member
    I just went to my local Dodge dealer and gave them the part number and they had them in a couple days with no shipping charge.
  20. May 23, 2018 at 5:46 PM
    #660
    Bravisimo
    Bravisimo So many mods, very little money.
    Joe
    Santa Clarita, CA
    2014 Tacoma PreRunner SR5 DCLB
    Tint, headlights wrapped & rear lights smoked, power outlet mod., grill & rear bumper wrapped, Falken A/T 3W,
    how are you guys getting the bolt through the ring base? It won't slide through the bolt because the ring base hole seems to be barely wide enough.
