Installed D-Rings in the Bed (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neubs, Feb 27, 2009.
  1. Sep 10, 2020 at 7:16 AM
    #801
    micah323
    micah323 Well-Known Member
    I just picked up the sprinter rings from dodge. They are def bigger and beefier than the stock ones. Not sure I am going to get them to swivel freely or if that doesn’t have to do with the d Ring and is about the bolt/washer setup
  2. Sep 10, 2020 at 10:07 AM
    #802
    Muddinfun
    Muddinfun Well-Known Member
    They don’t need to swivel. You’re overthinking this. Mount the front ones so they’re angled just slightly rearward. In other words, mount the left front with the D towards the middle of the truck. Then rotate it just slightly clockwise and tighten the bolt. Whatever you anchor down, you’re going to be pulling somewhere between straight across and 45 degrees back. The D ring will be just fine pulling in those directions. If you put D rings on the middle bed bolts, point them towards each other.
    Grossomotto likes this.
  3. Sep 10, 2020 at 11:26 AM
    #803
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    It would be a shoulder bolt to make them swivel , but they don’t make one to fit . You would have to come up with something . I’ve had my dodge d rings for over a year now and haven’t got around to actually make them swivel I’m probably just goi g to bolt them in
  4. Sep 10, 2020 at 11:27 AM
    #804
    igno1tus
    I’m pretty sure a sleeve pressed on the bolt would probably work . I was going to make some out of heat treated 17-4 stainless
    the d ring MIGHT have to be modified thou
  5. Oct 15, 2020 at 5:05 AM
    #805
    2k11Tacoma
    2k11Tacoma New Member
    2011 White Tacoma
    Excellent info. Gonna try this on my 2011 long bed.
    igno1tus and Island Cruiser like this.
  6. Oct 16, 2020 at 4:10 PM
    #806
    AMC
    AMC Well-Known Member
    Fullerton
    4x4 TRD Sport
    None yet.
    Good stuff
  7. Nov 23, 2020 at 5:55 PM
    #807
    SAR Taco
    SAR Taco TRD-SAR
    Bryan
    PNW
    2009 Trd-Sport DCSB 6MT Super White
    2 in. spacer lift, rear facing halogen spot lights, leer 100xr canopy, FN Fx Pro wheels in Matte Bronze. Falken Wildpeak AT3W 275/70/17 LRC. Lots of LEDs. Rear ARB air locker.
    Edit: SOLD
    Welp unfortunately I seem to forget my truck is a rust bucket and bolts generally won't come out.... so I'm looking to sell my OEM D rings if anyone wants to buy. Couldn't get the bed bolts to come loose even with a 24" breaker bar and getting to the point of crushing the bolt head.
    All 4 for $20 (~50% off) plus shipping. Also wanting to sell the T-55 socket used to pull the bed bolts, $3 (bought for $6).
    I know many are going for cheaper aftermarket options but this is good for anyone looking for the factory look and feel.
  8. Nov 23, 2020 at 6:34 PM
    #808
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    I'll take 'em! Sent you a PM so we can work out a deal. Thanks!
    SAR Taco[QUOTED] likes this.
  9. Dec 24, 2020 at 5:31 PM
    #809
    tacopiano
    tacopiano Member
    Scott
    2021 2WD SR Utility
    Werk truck modz
    Getting ready to install mine. I wonder if there’s a more discrete way to cut the floor mat if you don’t have to worry about swivelin’. The gaping, square hole I see in so many installs costs a lot of material.
  10. Dec 24, 2020 at 6:19 PM
    #810
    Muddinfun
    Some people use a large hole saw to cut a nice round hole in the bed mat. Of coarse, put a block of wood under the mat when you break out the hole saw.
  11. Dec 24, 2020 at 7:32 PM
    #811
    igno1tus
    It is about the bolt , the rear (closest to the tailgate ) swivel because they use a shoulder bolt . There isn’t (that I know of) a shoulder bolt made to make the sprinter ones swivel . I am a machinist by trade and considered making a spacer for the factory bolts and hardening them but I’m not so sure the idea would work so I haven’t followed up and actually tried it .
  12. Sep 24, 2021 at 6:17 PM
    #812
    Taco-Obsessed
  13. Sep 24, 2021 at 10:30 PM
    #813
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    Will the bed bolts go into the sprinter d ring holes without the need for drilling?
  14. Sep 25, 2021 at 2:11 AM
    #814
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    They go right through
  15. Sep 25, 2021 at 4:24 AM
    #815
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Are you happy with these? They look heavy duty. I don’t usually put very heavy things in it but a piece of mind and extra securing points low to the bed is what I’m after. My frame is relatively new so I’m hoping the bolts back out easily enough. I’ll keep them soaked in the PB a week or so before I do the work. Thanks!
  16. Sep 25, 2021 at 10:37 AM
    #816
    Island Cruiser
    Kauai
    Baja
    I am happy with these! Keep in mind that they do not swivel and the D rings themselves take some effort to pivot but they are stout. I sprayed about 3-4 coats of Rustoleum primer and then the same number of coats in black on the head of the bed bolts to try to prevent it from rusting like my original ones did. The coats will still chip off as you slide stuff around back there but it can always be touched up. I rarely load stuff in the bed as well but with those extra D rings, it helps tremendously since they’re strong tie down points. Only thing I keep in the bed constantly is my full size spare.
    Pibbles99[QUOTED] likes this.
  17. Nov 7, 2021 at 9:05 AM
    #817
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    I like this mod and want to do it but have a question. Concerning the Toyota D-rings, the head on the bed bolts are much larger than the bolts supplied with the Toyota D-rings and it appears they will not sit flat when installed. Will the bed bolts clear the sheet metal and sit flat?
    Will the head of the bed bolts clear the sheet metal on the Sprinter D-rings?
  18. Nov 7, 2021 at 11:17 AM
    #818
    Island Cruiser
    Kauai
    Baja
    I hope this pic helps answer your question about how the Sprinter D-rings sit:
  19. Nov 7, 2021 at 12:36 PM
    #819
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    On mine I ground a little bevel on the bottom of the bolt head with a bench grinder to clear the raised part of the D ring bracket.
  20. Nov 7, 2021 at 12:42 PM
    #820
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Friend of mine works at a dodge dealership and is holding four of them for me. My new frame is only 2 years in so I don’t think it will be much of a problem to back the bed bolts out to replace them
