Installed D-Rings in the Bed (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neubs, Feb 27, 2009.
  1. Nov 14, 2009 at 8:59 AM
    #121
    PacoTheTacoMan
    PacoTheTacoMan Well-Known Member
    Weathertechs, personally fabricated tailgate lock, tint, extra D rings, Exactfit seatcovers, re-enforcing the tailgate and adding a leaf next week.
    Does anyone know the specified torque on the bolts? I will be doing this tomorrow, and realized I should probably tighten these things to specifications.
  2. Nov 14, 2009 at 10:32 AM
    #122
    monrad
    monrad Coprolite
    B'wood, SC
    09 DC short box TRD Sport, TM
    Avid light bar+RBG, Lightforce 140s, fog mod, FSM badges, Bobcatoshi grille + Stampede, JDM DRLs, TRD cat-back, rear spring TSB, AccessLE
    See posts #101 and #114, depending on which method you're using
    TRDSport10 likes this.
  3. Nov 15, 2009 at 4:33 AM
    #123
    PacoTheTacoMan
    Thanks. Big difference there. It makes sense, though. The automation at the factories I have worked in always seem to have a hard time with torque consistency. I don't guess it really matters.
  4. Nov 19, 2009 at 7:49 AM
    #124
    TSer
    TSer Member
    06 Tacoma
    Exactly right! Common sense just isn't so common anymore.
    Army surplus drings rated to 2400 lb breaking strength, and 800 lb working load.
    Great Mod!
  5. Nov 19, 2009 at 8:51 AM
    #125
    r0ss
    r0ss Active Member
    Ross
    SFO > LAX > AUG > ATL
    very cool! now i can actually haul motorcycles in my truck with out having to worry about the bed falling apart.
  6. Nov 23, 2009 at 5:30 AM
    #126
    roy826
    roy826 Well-Known Member
    Mississippi
    2010 Prerunner TRD Sport DC
    I installed my two front OEM D-rings under the bed bolt location saturday. It all turned out okay. Bed bolts were not that tight from the factory. Truck is brand new with 1500 miles on it so far. I re-torqued all of them at 55 ft. lbs. One was already at that. I am on the fence about adding the two in the middle. It was raining when I finished so I could not load my dirtbike to see if indeed I will need the two middle ones. I started to install the front ones per the factory recommendations but opted out of that after examining the bed in that area. Seemed really thin and flimsy to me. For the ones concerned about the bed bolt method rest easy there is no way you could pull one of those bolts loose or break one.
    Nice mod thanks to all who have done this before me. The input was very helpful.
  7. Nov 23, 2009 at 6:12 AM
    #127
    Gringo
    Gringo Active Member
    MA
    '10 2wd AC SR5
    HID's, extra D-rings
    slight deviation from topic - for those of you who mention carrying motorcycles, are you loading bikes over the tailgate, or removing the tailgate and loading right into the bed? I've seen mention of weak tailgates, mine's a 2010 so not sure if that's been fixed, and it's unclear to me what the weight limit of the tailgate is... I rarely carry my bikes but want to be sure that if the situation arises, I can haul my 600 lb bike without bending my truck!
  8. Nov 23, 2009 at 6:25 AM
    #128
    roy826
    Mississippi
    I rarely haul a motorcycle now that I have a two rail trailer but I will be putting a dirtbike in the back from time to time. Don't plan any sportbikes or streetbikes in the back they will go on the trailer. I did it all the time with my '02 Prerunner which had a weak tailgate also. I use an aluminum ramp and rode the dirtbike up in the back not sure I can get away with that on the shortbed DC. Either way I plan on puttign it straight in and rear wheel on the tailgate. It can't be over 100 lbs on it and surely it'll hold that. Like I said I had streetbikes in over the tailgate on my '02 and it never broke.
  9. Nov 23, 2009 at 6:54 AM
    #129
    Gringo
    MA
    '10 2wd AC SR5
    Thanks Roy,
    I had to haul my 600lb dual-sport in my '00 Pre-runner once, also hauled my wife's ~400lb bike a few times - no problems. I'm just worried about the 2nd gen. tailgate, heard alot of stories of bent gates...
  10. Nov 23, 2009 at 7:25 AM
    #130
    roy826
    Mississippi
    Yes I am also worried about even putting a dirtbike over the tailgate on this truck after reading the bending in the middle that happens.:eek: I may get more use out of my trailer from now on looks like. I have a 400 Super Motard I would like to haul in the back instead of on a trailer looks like that might be dicey as well. Kinda wish now I had bought another extended cab truck verses this Double cab model.:( At least the weight would be more on the bed when hauling instead of on the tailgate.
  11. Nov 23, 2009 at 4:06 PM
    #131
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    Just got my D-rings in the mail, can't wait to get 'em installed! Just gotta pick up an impact wrench and the appropriate size Torx bit (insert Tim Taylor-style grunting noises) :D I love tools... :cool:
    Gringo- I have a 2010 also, and I'm 99% certain that they fixed the tailgate problem. I've had 2x 225 pound people sit on mine, and it didn't hurt a thing. Hope this helps.
  12. Nov 25, 2009 at 5:15 PM
    #132
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    I've loaded my 250-lb dirt bike ('07 KTM 400 XCW) and my 380-lb street bike ('03 Suzuki SV650) in my '09 Tacoma many times using a ramp on the center of tailgate. No problems so far - but I wouldn't trust it with a real heavy bike. From what I've read, they strengthened the tailgate in '09, but it's still pretty weak. You can feel it flex around when you walk on it. It's pathetic, really. There's a thread on here somewhere about a guy who folded his tailgate in the center when loading his Harley-Davidson touring bike (probably around 800-lbs). I think he straightened it himself and then welded in some reinforcement to make it much stronger.
    Just curious, Gringo... what "dual-sport" bike do you ride that weighs 600 lbs??? The BMW R1200GS is the largest bike I can think of that can remotely be considered a "dual-sport" (and I certainly wouldn't take it on any serious off-road) and BMW claims it weighs just over 500-lbs wet. 600-lbs would be a LOT to handle off-road!
  13. Nov 27, 2009 at 10:51 AM
    #133
    Gringo
    MA
    '10 2wd AC SR5
    I've got a BMW R1150GS that's ~600lbs with a full tank, I use it as a two-up touring packmule; no extensive offroading with that bike, just hunting for free campsites. My daily ride is an old R100 GSPD that's alot more fun on gravel roads.
    I rarely haul a bike but want to know I can do it without hurting the truck...
  14. Nov 27, 2009 at 10:55 AM
    #134
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    nice rings!
  15. Nov 27, 2009 at 11:00 AM
    #135
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    bout to order me some now... thanks boss...
  16. Nov 27, 2009 at 1:42 PM
    #136
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    Just finished the mod. Love it. Easy as hell.
    For anyone out there who has yet to do this, there's something out there called a Uni-Bit that makes enlarging the holes in the D-rings wayyy easier. Pick one up, you'll find lots of other uses for it. Lowe's, HD, Menards, wherever.
    Gringo- sounds to me like you should be able to load your bike w/o problems. You might be a little nervous hauling the bike the first time or 2, but as long as you use good ratchet straps and do it right your truck'll hold it. I know, pretty basic info :)
  17. Nov 29, 2009 at 2:59 AM
    #137
    cwrose
    cwrose Don't spreadsheet this...
    Fairbanks, AK
    2023 Tacoma TRD OR DCSB in MGM
    I love the image that pops into my head when you call your GS a packmule. I plan on doing a bit of light enduro riding on my R1200R this next summer. My biggest concern is the non-disconnectable ABS; sure makes the hill descents more nerve racking.
  18. Nov 29, 2009 at 8:46 AM
    #138
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    Awesome Suggestion. I don't have a bed mat, but rest assured when I get one I'll do the same.
    Nice work on the D-ring install. I have a pair to install, but hesitant to relocate above the wheel well where the short bed meets the back wall.
  19. Dec 10, 2009 at 7:24 PM
    #139
    MIK
    MIK Active Member
    Max
    Acton, MA
    2010 LB SR5
    Leer shell, 4 leaf springs
    Great site you guys have here. A lot of information for new tacoma owners. I just installed extra d-rings following suggestions in this thread. Probably the easiest mod :) Thank you!
  20. Dec 10, 2009 at 8:06 PM
    #140
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    I see this was your first post... go to New Members and make an introduction. You'll love it here. Welcome to TW!
