Installed eibach 1.6 and WOW
Discussion in 'Suspension' started by Zac808, Nov 18, 2009.
  1. Nov 18, 2009 at 8:18 PM
    Zac808
    Zac808 [OP] Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I just got done installing by GB eibach springs. Left side was about and hour:mad: and right side was less than 20 mins:D.
    Ride quality is amazing. No nose dive. Rides smoother than stock. BTW I have the stock billies.
    I have a couple questions though:
    1. When I disconnected the sway bar, the link dropped on to the tiny metal piece sticking off of the rotor shield at the 10 o'clock position. It hit perfectly on the swaybar link boot. Now there is a tear and grease cam out. Is the link rebuildable or should I just order a whole new link?
    2. Also when I installed the top plate, the two top strut to frame bolts weren't perfectly perpendicular with the bottom strut bushing. I had to pry/beat it into the LCA. If the bushing has some twisting pressure, will this cause premature wear? Should I remove the whole strut and make it exactly 90 degrees from the mount bolts? I plan on getting 5100's in a year or so. Should I just wait until I get the 5100's and just leave the strut how it is until then?
    I know, I know
    :worthless:
    Pics will be up tomorrow.
  2. Nov 18, 2009 at 8:39 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I just used a spud wrench kind of like a big awl to slip into the bottom bolt hole and gave it a twist to line it up with the mount.
    Shouldn't hurt anythig unless you buggered up the rubber real bad.
