installed finally
Discussion in 'Audio & Video' started by commtrd, Aug 17, 2009.
  1. Aug 17, 2009 at 6:40 PM
    commtrd
    commtrd [OP] commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    I got all the stuff installed finally. Pioneer DEH-P410UB HU, Image Dynamics XS-69 mids / tweeters, and ARC Audio KS-125 amp. It all sounds really good. I can tell it would have been better with a sub and I now wish I had gone with a 150W amp instead of the 70W amp. But for what I was trying to do with the install I would say that it was accomplished. Those speakers will flat get after it. I found out that rammat is hard to work with in 103 degree heat. The adhesive is so gooey it is hard to remove the paper backing so I put it in the house overnight in the AC to cool off and when I did the other door today it was considerably easier to work with. I found that if I removed the boots from both ends of the door conduits it was a lot easier to pull the wire through and the boots go right back in real easy. It took me about ten minutes to get the speaker wire pulled through the ports in the bulkhead and into the doors. Then just pop the boots back in and it's done. I left all the original wire intact due to the other functions (window controls etc.) all being bundled up together with the speaker wires and modular plugs. Just taped up the unused plugs there so there wouldn't be anything to rattle with the door plastic back on. Speaking of the door plastic there was a lip about an inch and a half around the speaker grid that mated up to the original speakers and I cut that off with a knife flush so that it would not interfere with the new speakers movement. It was real easy to cut that stuff off. I don't know if it would have hit the surrounds on the new speakers but now I don't have to worry about that. It looked like it probably would have touched the speakers if I had left it intact.
    A couple tips on stuff I learned from doing my install. I still have to work with the HU a little to get some settings done but it's all working great. I found that on the '09s there was already a plate covering the big hole in the door so it was easy to deaden that area not having to fabricate a way to cover the hole.
  2. Aug 18, 2009 at 6:24 AM
    Fmsvandal
    Fmsvandal Well-Known Member
    David
    Ormond Beach, FL
    09 DC/LB TRD Sport
    Toytec Ultimate 3" Lift, Light Racing UCA's, N-Fab Steps, Black Headlight Mod, Satoshi Thin Lip Grille, Painted Hood Scoop, Debadged, Bakflip G2 Cover, Pop/Lock, Alpine HU, Kicker Door Speakers, RE Audio Subs, Arc Audio Amps
    ...so lets see some pics of the finished product.
  3. Aug 18, 2009 at 7:50 AM
    ToyoDen
    ToyoDen Member
    Raleigh, NC
    09 Tacoma 4x4
    mud flap delete, chrome steps, Pioneer receiver, Pioneer CD changer, Alpine amp, Polk Audio rear component speakers
  4. Aug 18, 2009 at 8:59 AM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    I can't read. Need pics please.
  5. Aug 18, 2009 at 9:33 AM
    commtrd
    Corpus Christi TX
    I will shoot one of the HU installed after the markets close. Really that's the only thing visible anyway. Amp under drivers seat and I'm not pulling the plastic off the doors just for a picture.
  6. Aug 18, 2009 at 9:37 AM
    Fmsvandal
    David
    Ormond Beach, FL
    09 DC/LB TRD Sport
    ...All we wanna see is the Finshed product...
  7. Aug 18, 2009 at 9:39 AM
    Rudbwoy7s
    Rudbwoy7s Well-Known Member
    TEXAS
    08 Double cab 4x4 sr5
    3" Revtek suspension lift, 17" Black and silver American Eagle Alloy wheels, 285/70 Nitto Terra Grapplers, Flowmaster 40 series muffler, sockmonkey brake light cover, Maglight mod, Viper alarm, Smith & Wesson hitch receiver cover
    x2
  8. Aug 18, 2009 at 2:39 PM
    commtrd
    Corpus Christi TX
  9. Aug 18, 2009 at 2:40 PM
    commtrd
    Corpus Christi TX
  10. Aug 18, 2009 at 2:43 PM
    commtrd
    Corpus Christi TX
  11. Aug 18, 2009 at 2:46 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    hey whats that aux button for between your 12v outlets, my 05 doesnt have that
  12. Aug 18, 2009 at 2:51 PM
    Rudbwoy7s
    TEXAS
    i was wondering the same thing.
  13. Aug 18, 2009 at 3:05 PM
    commtrd
    Corpus Christi TX
    That is for an auxilliary audio input for the stock radio. It is now non-functional. I do have the cord for either a thumb drive or an ipod routed to the glove box so I still have capability of using those media. Also I chose not to install the interface for the steering wheel controls since the only time I ever used those was when the stock radio screwed up and that was the only way to control volume on the stock POS radio. I use the wireles remote provided with the deck quite a bit. It is very handy.
    I didn't want to spend too much on audio equipment but I did want to put good sound in my truck. The deck is pretty basic and the amp is a little under-gunned at 70 watts / ch but all I wanted to do was get rid of the problem stock sound system. I need to get a 300mm f4 and a 200mm f4 micro lens and photography equipment is brutally expensive (especially when getting the good stuff, those two lenses will cost $3000). So I guess my priorities show up.
  14. Aug 19, 2009 at 4:58 AM
    Rudbwoy7s
    TEXAS
    its good that you recognize your priorities and put the money where its needed. Im in the same boat right now, no money for mods but once I get back on my feet from all of the wedding bills I'll be installing an audio system next.
  15. Aug 19, 2009 at 9:00 PM
    boutym
    boutym Member
    NY
    Where did you get the textured install kit and did it come in that color?
  16. Aug 19, 2009 at 9:09 PM
    socal16
    socal16 Well-Known Member
    Diego
    las vegas nv
    08 trd offroad black 4x4!!!
    wheels and tires, k&n cold air intake, limo tint,bhlm,TRD seatcovers, OME lift
    that was one of the upgrades that toyota made on the tacoma for the 2009 model
  17. Aug 19, 2009 at 9:09 PM
    kasey200
    kasey200 Well-Known Member
    south dakota
    07 TRD Dboubl Cab Longbed
    3" toytec, 285 BFG AT's
    i believe that's a metra kit. that is what i have anyway. very nice kits
  18. Aug 20, 2009 at 5:19 AM
    commtrd
    Corpus Christi TX
    Kit is a metra and it worked out great. I got it from sonicelectronix with an amp wiring kit and the HU. Nor ratlles or any other problems with the install due to mounting the HU. I would recommend the metra kit but I did not install a double-din radio with video etc. I would think their kit for that would be just as good.
  19. Aug 20, 2009 at 6:10 AM
    boutym
    boutym Member
    NY
    I may switch mine out. I have the Scosche and not so crazy about it. Little flimsy in my opinion and the color match is off quite a bit.
  20. Aug 25, 2009 at 8:13 PM
    commtrd
    Corpus Christi TX
    Follow up: The speakers seem to be "breaking in" nicely and the system is sounding even better. So I guess there is some merit to the idea that the speakers do "break in" with more hours of play time. I am hearing details in music that I have never heard before. The addition of the sound system has made the truck just a blast to drive. I now understand the concept of the sound stage and how a good install really complements good components. The only part I messed up on is I should have pulled 4 gauge wire for power to the amp and terminated it into a distribution block under the console to allow for future expandability if desired. Oh well...and I probably should have gotten a 150 watt / channel amp instead of a 70 watt / ch amp (although I may have ended up damaging my hearing had I done so). It is so tempting to crank it up sometimes when it sounds so good with zero distortion...really incredible and getting better all the time!
    To anyone who thinks 6 X 9's can't match the round speakers...please give me a break. The Image Dynamics XS-69 components just rock. That's all I can say about that. A good sub in there would just be absolute perfection. I need all the space in the back I can get though so no sub for me. Anyway the sound systen installation was such a major improvement I can hardly believe it.
