Installed LED turns, keeps blowing 10A Tail fuse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JSO, Jan 8, 2017.
  1. Jan 8, 2017 at 10:16 AM
    JSO
    JSO [OP] Well-Known Member
    Shane
    Jax, FL
    2016 TRD Off Road DCSB 4x4
    3” lift, 285 K02’s Morimoto Elite HID swap with yellow LED fogs This
    I installed JDM Astar LED's in rear signals and front DRL/signals, as well as corner lights. I have resistors on all four corners and everything works properly with no hyperflash. But now when I turn on the headlights it immediately blows the 10A Tail fuse behind the dash. Everything else continues to work EXCEPT the corner lights and tail lights. Brake lights and all signals still work properly.
    I'm stumped! Any ideas or suggestions would be appreciated
    Side note... I searched here and google extensively before posting :annoyed:
  2. Jan 8, 2017 at 11:04 AM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Are you sure you hooked the resistors to the correct wires?
  3. Jan 8, 2017 at 11:23 AM
    JSO
    Shane
    Jax, FL
    Yes I did. I think the bulbs are not CK style. I'll have to purchase a new set I'm guessing
  4. Jan 8, 2017 at 12:26 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    try putting a 15A fuse in. if it still blows you got a bad ground some where. or faulty wiring
  5. Jan 8, 2017 at 12:57 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    That is most likely the problem. Using a "standard" 3157 or 7443 in a CK socket will cause the low intensity "tail/parking" light circuit fuse to blow--it's due to differences in placement of the ground contacts.
    The standard lamp in the CK socket shorts the low intensity feed to ground...
  6. Jan 8, 2017 at 1:00 PM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    ^^This,
    On a side note. I thought the 2nd gens had a flasher module you could replace instead of splicing in resistors for turn signals
  7. Jan 8, 2017 at 1:01 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^Yes, or you can even open up the flasher module and grind down a resistor inside, but module is a bit difficult to access.
  8. Jan 8, 2017 at 1:03 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    lucky, on the third gen, the module is built into the guage cluster. Can't do anything about it. Have to use resistors
  9. Jan 8, 2017 at 1:05 PM
    KenLyns
    Belly of the Beast
    ^Ehh so use resistors. My eBay tail lights with built-in LED turn signals also have built-in resistors. So far they haven't overheated.
    IMG_4188s%2Btail%2Blight_7ce438ea5b677b7d54a5a7889ad903638707c254.jpg IMG_4165s%2Btaco%2Btail_0637986aa9cf3791cb766372ac96ef0d0e57eb84.jpg
  10. Jan 8, 2017 at 1:31 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    What not obvious is that adding the resistor means the LED/resistor combination uses just as much power as an incandescent lamp..
  11. Jan 8, 2017 at 2:02 PM
    KenLyns
    Belly of the Beast
    ^Correct. However, most people don't convert to LEDs in their Tacos to reduce electrical power consumption; they do it to improve appearance.
    Aw9d likes this.
  12. Jan 8, 2017 at 2:04 PM
    KenLyns
    Belly of the Beast
    I suppose with the proper schematics, it may be possible to disassemble the gauge cluster and rework some circuit board components to achieve the correct blinking rate for LED bulbs.
  13. Jan 8, 2017 at 2:58 PM
    JeffreyB
    Jeff
    I'd love to do it once they last as long as household LED bulbs just to never have to worry about a light being out. Automotive led seems to have burn out issues though.
  14. Jan 8, 2017 at 5:43 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    You can replaced the flasher relay on a non DTRL vehicle with a new drop in relay. On DTRL trucks, you have to modify the OEM relay.
    You can convert your bulbs to CK style bulbs super easy instead of replacing them with overpriced CK style bulbs. I did this for my truck with no problem.
    Heres a link - https://www.tacomaworld.com/threads/convert-non-ck-3157-led-bulbs-to-3157ck.321201/
    The only thing I did differently was add some heat shrink to keep the leads from crossing each other once moving them.
  15. Jan 9, 2017 at 6:35 AM
    JSO
    Shane
    Jax, FL
    I believe this is the issue, yes. Used the same bulbs in the rear with no issue. Installing them in the front causes the "tail/parking" fuse to blow. Will be ordering CK bulbs. Any recommendations? I know lots of folks here love VLED and Diode Dynamics. Does JDM Astar make a CK application? I've had great results from them at a much lower price. (I know you get what you pay for but there is such a thing as point of diminishing returns as well)
  16. Jan 24, 2017 at 9:08 AM
    JSO
    Shane
    Jax, FL
    Ok so an update...
    I installed the CK style bulbs. The fuse no longer blows. But now it's a new issue.
    They work perfectly until the parking or headlights are turned on. No longer do they blow a fuse but the front signals won't blink. No hyperflash, the rear works correctly, but the front doesn't blink. Also the DRL's don't dim when the parking or headlights are turned on so I think that's connected.
    Any one got an idea?
  17. Jan 24, 2017 at 9:22 AM
    Tylandus
    Tylandus Well-Known Member
    Midwest
    2019 4Runner SR5 Premium Superwhite
  18. Jan 24, 2017 at 9:29 AM
    JSO
    Shane
    Jax, FL
  19. Jan 24, 2017 at 9:31 AM
    Tylandus
    Midwest
    poop
  20. Jan 24, 2017 at 10:20 AM
    cliffyk
    Cliff
    Saint Augustine, FL
    Or just stick with the OEM lighting--but then I'm retired, and old, and have handled more than my fair share of life's hassles to go out of my way seeking tgem out.
    OP, 'twas me I would put it all back to stock to verify its all still working--then modify one end at a time...
