Installed Metra Ipod/MP3 adapter
Discussion in 'Audio & Video' started by rhoppas, Nov 3, 2007.
  1. Sep 15, 2010 at 2:07 PM
    #181
    Trachito
    Trachito Well-Known Member
    New Orleans
    well, i followed your link, which had another link on it, which led me to find this:
    http://indashpc.org/new/aux_adapters/grom-aux-toy.html
    This is exactly what i need. a simple adapter to my factory stereo that will plug right into my regular mp3 player. reasonably priced and comes with everything i need. no need to buy additional RCA cables or anything. thank you so much.
  2. Sep 15, 2010 at 2:08 PM
    #182
    MSUtacoboy
    MSUtacoboy Well-Known Member
    MS
    2008 Silver DC 4x4 Trd off-road
    that's pretty much what the Metra is... but for 9.99+ shipping through Amazon.
  3. Sep 15, 2010 at 4:00 PM
    #183
    Trachito
    New Orleans
    from what i saw that was just for the iphone, which i don't have. i tried looking for a regular mp3 one but couldn't find it. i even emailed the maker and they said it was discontinued, which i wonder why. 10 bucks would have been sweet.
  4. Sep 15, 2010 at 4:59 PM
    #184
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    the metra is ipod but no deck control + 3.5mm aux
  5. Sep 16, 2010 at 6:39 AM
    #185
    Trachito
    New Orleans
    oh.... great. screw it, as long as i have something that works well and is reliable.
  6. Sep 18, 2010 at 1:01 PM
    #186
    MSUtacoboy
    MS
    just installed Metra. it has two connections, only had to use 1. connects ipod and plays perfectly. doesn't let me go thru the whole ipod but you put it on what album and go from there. no text was showing up, but i didn't get to play with it, just install and back to football on tv. will give a better update in a few days. but for $15.99 shipped, can't beat that.
  7. Sep 18, 2010 at 4:20 PM
    #187
    rolltide3705
    rolltide3705 Well-Known Member
    A.J.
    Birmingham, Alabama
    06 Prerunner Sport Double Cab
  8. Sep 19, 2010 at 4:39 AM
    #188
    Trachito
    New Orleans
    What about the 3.5mm connection, is it an aux plug or a direct connection to your device?
  9. Sep 19, 2010 at 2:06 PM
    #189
    MSUtacoboy
    MS
    what i have is a direct connection to the ipod.
    (both plugs going out of the metra looks like an s-video plug, you know, the round with pins in it)
    i've got to find something like this with a 3.5mm jack on the other end to run my phone
  10. Sep 20, 2010 at 6:42 AM
    #190
    Trachito
    New Orleans
    ah, ok. so basically it comes with an ipod connector. when you find the 3.5mm jack update on here and lemme know how well it works. i'd expect it to be just plug and play but i don't know how the interface is wired to work considering that it's made to allow the HU to control the ipod.
  11. Sep 20, 2010 at 9:51 AM
    #191
    MSUtacoboy
    MS
    will do, but it may be a while.
    the radio thinks you have a cd changer plugged in. mine doesn't show text.
    d1t1 is all songs, or what every you have the ipod on at the time you plug it in.
    D2 - D9 are supposed to be playlist. i don't think this is right, but i've got to look more into it. as said before it does what i wanted. plays my ipod thru the stock radio and 1000x better than the fm mod.
  12. Sep 21, 2010 at 5:27 AM
    #192
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Not sure which metra y'all have or how many diff versions of it there mighta been but when I had that, it had an 8 pin female s-video looking connection for the ipod like the cable in the pic above would plug into with the ipod flat connector on the other end. It also had a female 3.5mm hole on it where all you have to do was score male to male 3.5mm to attach aux devices. When switching to grom usb unit, I simply moved the ipod/3.5 cables over from metra to grom and added the usb connection to it. I have all 3 connections to the grom audio box.
    This is not the one I had..........
    http://www.installer.com/item/display_item.php?it=TYTO-01
  13. Sep 21, 2010 at 6:44 AM
    #193
    MSUtacoboy
    MS
    yeah mine doesn't have teh 3.5mm female. it's got another s-video looking plug.
    gonna get a pic and post it soon.
  14. Sep 23, 2010 at 7:00 AM
    #194
    Scooter
    Scooter Canadian Member
    Manitoba, Canada
    08 Double Cab TRD Sport Short Box
    Pop n Lock Power Tailgate Lock, Bak Flip Tonneau Cover, Factory DLR installed, Defrost with A/C Off, EZ Down Tailgate Damper, Code Alarm Security System with Remote Starter, Rear Spring TSB, Ming rust proofing & paint treatment, 3M fabric protector, Cargo Mat, Scanguage II, DYI Illuminated 4X4 Switch, Versa-Gate box extender & cargo divider, Toyota Roof Rails, Grom USB Audio adapter with bluetooth, LED Bed lights, OEM Backup Camera with LCD Display Mirror
    My Metra has both the 3.5mm and iPod connectors. I paid $30+$10 S&H for it on ebay, but I think it's discontinued, and hard to find now.
    I have an 08 with the JBL factory stero, and it works fine. My only problem is the iPod connector does not charge iPod Touch. Sonmone on here told me it is because of new firmware on the iPod Touch. I usually use a Sensa mp3 player, so the charging is not an issue. I plug the Sensa to a 12V to USB charger, and use the 3.5mm connector for the audio.
    My daughter uses her iPod Touch every now and then. I just plug in the 3.5 mm jack for the audio, and charge it using the USB power adapter, the same way I plug in the Sensa. It's not as convenient as other setups, and there is no control from the stero, but for $40, it works way better than a FM transmitter.
  15. Sep 25, 2010 at 11:29 AM
    #195
    CrazyCooter
    CrazyCooter Hold My Beer!
    Johnathan
    Virginia
    I just installed my metra interface today. Smooth installation, but when i took off the right side cap under the a/c vent there was a wire with a plug on the end that i dont know what its for (i didn't unplug it). Just wondering if anyone else ran into this while installing their metra ipod hook up?
    Also does anyone know how to fix the lights inside the A/C panel. only one is out and i took apart the whole A/C panel...so just wondering if its a fuse or an actual bulb some where.
  16. Oct 18, 2010 at 9:24 AM
    #196
    Trachito
    New Orleans
    i got this one for $65 plus shipping. it was just a simple one for a regular mp3 player, not an ipod, although it does plug into an ipods earphone jack. it plugged right into the back of my OEM 6 disk changer stereo (not JBL). CD player works fine, radio, etc and it plugs directly into the earphone jack of any mp3 player. the wire harness had 2 plugs meant for the head unit but i only needed to plug in one since i dont have XM radio or a navigation system. very simple and easy to install and works perfectly. i tucked the Grom box to the left of the head unit and ran the 3.5mm cable under the shifter console (6spd manual)/cup holders/and into the center console. that way the cable is out of site. i'll see about uploading a pic or 2 later.
    http://www.gromaudio.com/store/aux_...+_aux_adapter__direct_digital_interface_.html
  17. Oct 18, 2010 at 7:47 PM
    #197
    surfer4191
    surfer4191 Member
    NSB FL
    07 tacoma longbed
    $150 from crutchfield is kinda steep if you ask me but im still going to order one tomorrow. thanks for the post! :D
  18. Mar 10, 2011 at 6:34 PM
    #198
    king22spade
    king22spade Member
    king22spade@yahoo.com
    bhlm, black badges,black stock jbl stero,2.5'' level kit, k&n air filter.
    is there one that works for the facyory jbl 6 disc i have no luck finding one
  19. Aug 5, 2011 at 6:58 AM
    #199
    goyette
    goyette New Member
    Lafayette IN
    08 TRD Off Road
    The Grom Toy2-USB works with the factory jbl 6 disc and sounds great.
