Installed Metra Ipod/MP3 adapter
Discussion in 'Audio & Video' started by rhoppas, Nov 3, 2007.
  1. Aug 9, 2008 at 6:37 PM
    #101
    dillkawi07tacoma08
    dillkawi07tacoma08 New Member
    quail valley
    08 double cab long bed white
    I bought the metra adapter for my 08 tacoma and plug it in!! No power went to the adapter and i could not get any sound!! Any suggetions on a better adapter or what i did wrong!!!
  2. Sep 18, 2008 at 7:13 AM
    #102
    namariegaudi
    namariegaudi Member
    SR5
    So does the adapter work on stereos that don't have the "SAT" or AM/SAT" button? I have a 2006 Tacoma TRD...So I wan't to know if I can use the Metra solution with my current stereo.:confused:
  3. Sep 18, 2008 at 7:35 AM
    #103
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    Which head unit do you have? I'm not sure about all of the setups but it worked on my Jbl indash 6 disc. You use the disc button to switch between cd and cd1 on my setup. Hope this helps.
  4. Sep 18, 2008 at 7:37 AM
    #104
    namariegaudi
    namariegaudi Member
    SR5
    I have the regular single disc stereo...not sure if that's a good reference for you
  5. Sep 18, 2008 at 7:41 AM
    #105
    Justin626
    Palmer, Alaska
    I'd assume that if your HU has an AUX button, then it should have the same plug slot as mine to plug in an auxillary cd changer. If that is the case, i would think it would work. I haven't really seen anyone discuss much about the single disc HU's.
  6. Sep 18, 2008 at 8:02 AM
    #106
    namariegaudi
    namariegaudi Member
    SR5
    Nope, no AUX button...just the regular buttons (AM, FM1, FM2, DISC)...hope I'm not already screwed as it is....
    Thanks man
  7. Sep 18, 2008 at 8:09 AM
    #107
    Justin626
    Palmer, Alaska
    Well, I would think that once the adapter is plugged in, you would push the DISC button to switch between cd and cd1. Pulling the HU out is real simple to do. Follow the instructions for removal on this link and check to see if there is a spot for a small nearly square connecter to plug into. I would say the spot for the connector would measure about 3/4" wide by 1/2" tall. If its there it should work. Circuit City carries this adapter, atleast they do via their website.
    http://www.tacomaworld.com/forum/audio-video/571-stereo-upgrade-basic-how-2nd-gen.html
  8. Sep 18, 2008 at 8:10 AM
    #108
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    http://www.xcarlink.co.uk
    This is a good device and I have it on my Tacoma, it also have bluetooth functition, USB connection, you can use any flash drive, usb drive to play your mp3, also it come with the AUX in, so you can connect your ipod or mp3 player too.
    It is a very good device, check it out, hope this can help you.
  9. Sep 18, 2008 at 8:11 AM
    #109
    namariegaudi
    namariegaudi Member
    SR5
    well, once I'm back home (in about 2 or 3 days) I'll go and look...thanks for the help...I'll let you know how it goes
  10. Sep 19, 2008 at 10:02 PM
    #110
    rhoppas
    rhoppas [OP] Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    The Metra will work with your stock radio. You simply press the DISC button to toggle between your CD and your Metra unit.
  11. Sep 20, 2008 at 5:27 PM
    #111
    rhoppas
    Topeka, KS
    Good addition to the thread... Thanks Kyouto42!
  12. Oct 15, 2008 at 8:53 AM
    #112
    taconinja
    taconinja Well-Known Member
    Pittsburgh
    08 Base 4X4
    I have an 08 4X4 Base Regular Cab with the stock AM/FM/CD headunit. Will the Metra from Circuit City plug right in? Thanks!
  13. Oct 15, 2008 at 3:12 PM
    #113
    spp
    spp OC, Kalifornia
    OC California
    What year is your Tacoma and which factory HU do you have?
    I looked at the link and the stock unit I have doesn't match any of the pictures on their site. Mine is an '07 access cab SR5 5-lug.
  14. Oct 15, 2008 at 4:09 PM
    #114
    wing103
    Boston
    It work on the 2008, but it won't work on the 2009 model.
    You can send a photo of your stero to them, than they will tell you will it fit or not... at that point if not work after the purchasing, you can return it back and get refund.
  15. Oct 16, 2008 at 9:47 AM
    #115
    spp
    spp OC, Kalifornia
    OC California
    The 2009 comes with an Aux input jack. ;)So back to my question which year and stock unit do YOU have?:)
  16. Oct 16, 2008 at 10:34 AM
    #116
    SHunter080703
    SHunter080703 Well-Known Member
    I was wondering the same thing. Will the Metra work with a Single Disc HU? I have an AUX button on my HU.
  17. Oct 16, 2008 at 6:54 PM
    #117
    rhoppas
    Topeka, KS
    I am almost 100% certain that the Metra works with all stock radios in 2005-2008 models.
  18. Oct 30, 2008 at 10:51 AM
    #118
    roborock
    roborock Member
    does anyone know if you can listen to music through the ipod connector with an iphone 3g? I know it won't charge and I can probably just use the 3.5mm adapter, but any info would help. thanks.
  19. Oct 30, 2008 at 11:03 AM
    #119
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    The metra adapter WILL work with single disk head units. I have have mine for several months now and no problems. Just use the DISK button to switch between the cd player and the metra adapter.
  20. Oct 30, 2008 at 11:11 AM
    #120
    Justin626
    Palmer, Alaska
    I had to do a double-take at your name. :rofl:
