Installed rear extended travel 5100's(F4-BE5-B110-T5)
Discussion in 'Suspension' started by Zac808, Apr 26, 2012.
  1. Apr 26, 2012 at 6:47 PM
    Zac808
    Zac808 [OP] Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I was down in San Diego Wednesday and figure I would pay a visit to Downsouth Motorsports. Got around to talking with Marco about my rear suspension feeling like $hit. I was running TSB w/ Wheelers 1.5" AAL and stock TRD shocks. He recommended the extended travel 5100's because most likely my shock was topping out here and there.
    Got around to installing it today and damn these things are long;). The line on the OEM shocks are where the dust boot was sitting when installed on the truck. So I had about 2" of down travel.
    In the pic below you can see where each shock tube actually ends and the the difference between them.
    Actual installation wasn't to bad. I ended up using the OEM jack out of my Matrix to help get the shock into place. I didn't have enough to muscle it up.
    Once installed I took some measurements to see how much up travel I will have and if I will need to extend my bump stops. Looks like I have 4.5" of up travel. And my bumpstop are 4.75" away from the frame. I will most likely end up welding a .5" plate to the frame to keep the shock from bottoming out.
    Next is to figure out what kind of modifications need to be made for the down travel. Some folks say that the brake line brackets need to be bent. What about the differential electrical wires? Are they long enough.
    Is it better to have more down travel vs. up travel?:confused:
    Thanks again to Marco at DSM for showing me the differences in the two 5100's.
    blqchclt likes this.
  2. Apr 26, 2012 at 6:51 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    if you wheel what you really want is more bump than droop...well at least for higher speed wheeling.
    also...:spy: this is bad advice BUT Bilstein does have a "lifetime" warranty so...i wouldnt worry about setting up the bumps, just use the shock and if something goes out warranty it :spy:
    ^this is bad advise lol, dont listen to him
    Pirhett likes this.
  3. Apr 26, 2012 at 6:58 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    :eek::eek::eek::eek::eek::eek::eek::eek::eek::eek:
  4. Apr 26, 2012 at 6:59 PM
    08pretaco
    az
  5. Mar 7, 2013 at 7:47 AM
    rmarqu2
    rmarqu2 YES... i am a murse....
    Roger
    Baton Rouge
    09 Black 4x4
    FOX 2.5 coilovers, FOX 14" rears, AP expos, AP front plate bumper and skid, lightforce 240 blitz, warn m8000, 3/8 amsteel, BAMF sliders, cheap Chinese rock lights, ARB lockers all around
    Did that....tried that.... Doesn't work!!! They don't cover a snapped shaft!
    3rYODA likes this.
  6. Mar 7, 2013 at 11:07 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Your leafs wont have enough droop to use the entire down stroke of the shock but that's ok. I'd un-bolt the bottom of the shocks again and let the leafs flex to full droop and double check the break lines. The shocks will then be sitting next to the bottom mounts and both will be at full droop, you'll see what I mean......when I had those leafs they drooped to 25" and that shock goes to 27" and change.
  7. Jun 24, 2014 at 4:02 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Is this the shock that is recommended to use with the Dakar leaf pack on 2nd Gens?
  8. Mar 3, 2015 at 9:11 PM
    BCTRD
    BCTRD Well-Known Member
    Drew
    Kelowna, BC
    2008 TRD SPORT
    You are using the Bilstein B110 with a TSB+1.5" AAL?
    how do you like it?
    Im wanting to install OME dakar leafs and use the B110 but I want to make sure that it will work out.
  9. Mar 4, 2015 at 11:12 AM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I can tell you this......
    Right now I have the Dakar leaf pack installed and am running standard length Bilstein 5100's. I'm pretty sure they are the limiting factor in my down travel. I was informed that these are not ideal and I'll eventually blow them if I go wheeling or go over bumps quickly. They seem to be fine for paved roads though.
  10. Dec 1, 2015 at 1:35 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Anyone else running the B110 shock with the Dakar leaf pack?
    Captainskidmark likes this.
  11. Dec 1, 2015 at 2:00 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Not Dakars, but I ran them on my "stormtrooper" build with a 4" leaf pack and they worked wonderfully.
    Crom[QUOTED] likes this.
  12. Dec 1, 2015 at 2:03 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Thank you. That's good to hear. :thumbsup:
  13. Dec 1, 2015 at 2:05 PM
    Crom
    Nick
    San Diego, CA
    Millions
    @BCTRD Did you ever run the shocks with Dakar?
  14. Dec 1, 2015 at 2:11 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    I've been running them with my Dakars and AAL for about 30k miles now. These are so much better than my old OME rear shocks. Here's a picture of the droop I get with them.
  15. Dec 1, 2015 at 2:15 PM
    Incognito
    VA
    Absolutely! Very cost efficient and I think for your needs they'll be perfect. I'm very similar in my exploring/wheeling as you are and they never let me down.
  16. Dec 1, 2015 at 2:18 PM
    Crom
    Nick
    San Diego, CA
    Millions
    I wish I could like your post more than once! That looks really good. Yes I have the too-short OME shock as well and want to get rid of it. I need to put on my extended brake lines that have been collecting dust for 8 months and get 'er done.
    Yes very cost efficient. I like that. :D
    0uTkAsT and Incognito[QUOTED] like this.
  17. Dec 1, 2015 at 2:30 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    Haha thanks! I ended up going with these basically because they were super cheap and had the travel I was looking for. Wasn't expecting the best of quality based in the price but these have blown me away. I pretty much do overlanding and go explore some trails locally so these have been awesome for me. I did the extended brake lines when I put the AAL in the rear about 40k miles ago. Only thing I don't like is that the E-brake cable is pretty tight at full droop.
    Crom[QUOTED] and Incognito like this.
  18. Dec 1, 2015 at 2:47 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Good to hear all of that... On the e-brake too tight issue, I've seen that most with those that do the shackle flip kits. I recently asked Spencer (ragincajun35) that question as he just flipped his shackle on his 2015.
    He says he solved it, check here in his build thread, for the start of the dialog. Might be useful...
    Pirhett and Sje1124[QUOTED] like this.
  19. Dec 1, 2015 at 3:03 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    See I thought I had done that. I just went and looked but like a ding dong I removed the bracket that Spencer left on and left the bracket that he removed. I'll have to get out there and take off the last 2 brackets then I should be good to go. Just hope that it doesn't hang down too low since I don't have the two top brackets any more.
    CapeBretonExo and Pirhett like this.
  20. Dec 1, 2015 at 3:10 PM
    Crom
    Nick
    San Diego, CA
    Millions
    :D Interesting. Maybe take the remaining bracket, unbolt it slide up the cable and reattach where the higher one once was? :notsure: Thanks for the additional pics.
    Sje1124 likes this.
