Installed Resister for LED hyper-flashing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JabambyBrew, Mar 28, 2019.
  1. Mar 28, 2019 at 12:17 PM
    JabambyBrew
    JabambyBrew [OP] Well-Known Member
    JB
    Denver NC
    2019 Toyota Tacoma TRD PRO
    I installed resister for my rear turn singles for hyper-flashing on my LEDs. I watch Taco Twans video 5 time before I installed them. After installing them I still get hyper-flashing when I have the lights on but not when I have the hazards on. I noticed in the video Taco Twan doesn’t test each turn singles out by its self just the hazards. What an I doing wrong? Any help would be great!
  2. Mar 28, 2019 at 12:54 PM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    LEDs used for rear turn signal or LED turn signals in front too?
    If both you will need 4 load resistors total.
  3. Mar 28, 2019 at 1:07 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I only used resistors in the rear - I have LED everything in my tail lights + LED front turns.
    Did you use 50w 6ohm resistors?
  4. Mar 28, 2019 at 1:10 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Symptoms would indicate resistance is too high. Suspect double check connections made for poor connection, or reduce resistance by another ohm ie 6 ohm to 5 ohm.
  5. Mar 28, 2019 at 1:58 PM
    JabambyBrew
    JB
    Denver NC
    This what I used.
    https://www.amazon.com/Resistors-Si...id=1553806502&s=gateway&sprefix=led+re&sr=8-8
    I even went ahead and redid the connections. I do have led turn singles in the front but never had a problem with them.
  6. Mar 28, 2019 at 3:50 PM
    Vinci
    Vinci Well-Known Member
    Sarasota, FL
    '17 MGM Limited 4x4
    Which wires did you bridge in the rear? You should have bridged the yellow to the white/black on the driver side and the blue to white/black on the passenger side.
    The size resistors you have match what I successfully used, so I think you may have a wiring issue.
    The hazards don't hyperflash because they bypass the normal flasher circuit and always flash at a set rate
  7. Mar 28, 2019 at 4:17 PM
    JabambyBrew
    JB
    Denver NC
    From what you said I did it wrong. I think Taco Twan did it wrong as well. Yeah I didn’t do the yellow or blue wires. Dammmmit. Easy fix though. Thanks for the help.
  8. Mar 28, 2019 at 4:47 PM
    Vinci
    Sarasota, FL
    '17 MGM Limited 4x4
    I had to check them with a meter because, like you, I found that information seemed to be conflicting where I was reading. If you bridged the white/black and green (both thinner wires), that was the running light.
  9. Mar 28, 2019 at 6:31 PM
    Siblue
    So Cal
    25 Tundra TRD pro
    WTF is a Taco Twan?
    ricco333, musicisevil and MrBrooks like this.
  10. Mar 29, 2019 at 4:41 AM
    JabambyBrew
    JB
    Denver NC
    YouTube channel lol
    Siblue[QUOTED] likes this.
  11. Mar 29, 2019 at 6:28 AM
    JabambyBrew
    JB
    Denver NC
    Thanks for the info. That fixed it. Oh yeahhhh!
  12. Mar 29, 2019 at 9:05 AM
    caribe makaira
    Caribbean, Puerto Rico
    Another option for those looking to do the same.
  13. Oct 1, 2020 at 10:43 AM
    van_isle_taco
    van_isle_taco Member
    Vancouver Island, BC
    2020 Tacoma OR DCSB
    I had to add some resistors for after swapping out all my bulbs for LEDs and this post saved me so much time. Thanks @Vinci!
    Vinci[QUOTED] likes this.
  14. Dec 20, 2023 at 9:54 AM
    Frankmelton
    Frankmelton Member
    I see this is an old post, but I am having similar issues. Is there a way to install one resistor for the entire lighting system? I thought this was one circuit. I have after-market LED assemblies in the front and rear. The hazard lights only work when the engine is running. I am sure I need a resistor. I don't know which one and how to install it.
  15. Dec 20, 2023 at 9:58 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^You have aftermarket tail light assemblies or LED bulbs? Most LED tail light assemblies have the load resistor mounted right on the casing.
    Chew likes this.
  16. Dec 20, 2023 at 10:03 AM
    Frankmelton
    Frankmelton Member
  17. Dec 20, 2023 at 12:22 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Googling the Keystone P/N TO2503291 shows this headlight is intended for 2020+ TRD OR/Sport/Limited models that came with the same style of LED reflector headlights from the factory (i.e. it's intended to be a crash replacement part). What year and model is your truck? Are you using any adapter harnesses?
  18. Dec 20, 2023 at 12:26 PM
    Frankmelton
    Frankmelton Member
    I have a 2019 Tacoma TRD Sport. I had to use the conversion kit to make it fit into my truck.
  19. Dec 20, 2023 at 12:38 PM
    caribe makaira
    Left & Right, so you'll need one per side.
    Frankmelton[QUOTED] likes this.
  20. Dec 25, 2023 at 6:11 AM
    Frankmelton
    Frankmelton Member
    Has anyone installed resistors on OEM LED headlights? I know it doesn't sound very clear. The situation is that I got OEM LED headlights for my truck (Aftermarket headlights come with the resistors already installed), and now I am having issues with the hazard lights only when the car is not running. Are there any schematics on how to install the 50W load resistor? I need to find out which is the blinker cable. I understand that one end of the resistor goes to the ground cable and the other to the blinker cable. Thats is difficult to tell because my conversion kit only has DRL, Low beam, and high beam.
