Installed RS3200+ system
Discussion in 'Canada' started by Dakota, Oct 21, 2009.
  1. Oct 21, 2009 at 4:42 PM
    Dakota
    Dakota [OP] Member
    Nova Scotia
    4 door 6' box TRD SR5 Sport
    Scangauge2,Trailer brakes,Tacoma running boards,tri fold tonneau cover,Locking tail gate,lights under seats& dash,12v pwr plug behind rear seat,all lube fluids changed to Amsoil, RS3200Plus, Max 4. Train Horns, WeatherTech mats.
    I just purchased a RS3200+ and OEM running boards for my 2009/4 D Tacoma. I was in Maine last week, but priced them there and in NS before buying and NS was cheaper by $20 on the running boards. So not everything is cheaper there. I installed the security using a guide I found on here and installation was made easier also it works great.
    Lot of help on here Thanks Guys..
  2. Oct 21, 2009 at 6:44 PM
    AK27
    AK27 Well-Known Member
    :woot: congrats! and welcome to TW! :canada:
  3. Oct 21, 2009 at 7:17 PM
    Dakota
    Dakota [OP] Member
    Nova Scotia
    Thanks. AK, I will mostly add another LED for more effects when armed.
  4. Oct 27, 2009 at 5:05 AM
    Dakota
    Dakota [OP] Member
    Nova Scotia
    I have installed my RS3200+, everything works, But I can figure what fuse they are speaking of at the end after checks are completed?
    ( Remove the appropraite fuse after checks are complete)
  5. Dec 18, 2009 at 2:25 AM
    Dakota
    Dakota [OP] Member
    Nova Scotia
    I'll try to help you. What is your question?
    Dakota
  6. Dec 19, 2009 at 7:45 PM
    Dakota
    Dakota [OP] Member
    Nova Scotia
  7. Dec 21, 2009 at 4:34 PM
    Dakota
    Dakota [OP] Member
    Nova Scotia
    I'm sure you'll get it done. The most difficult part was removal of the white wire from the main socket was getting the pin to release, I lost an hour getting it apart without damaging the plug. If you master getting apart you're set. Or Just cut and solder it adding the new end, you will notice this part in the instructions. The instruction are good and there maybe someone in your area who give you a hand.
