Installed Sirius Stiletto 08 Taco
Discussion in 'Audio & Video' started by Oilcan, Feb 11, 2008.
  1. May 4, 2008 at 9:12 AM
    ChrisDeSoup
    ChrisDeSoup Come on, Touch it......
    Up in ya
    08 Tacoma Double Cab PreRunner Sport
    Seatbelt Ding Mod All Weather Mats Gate Lock MOD Rear Spring TSB
    You need an FM Modulator from crutchfield.com they are inexpensive and easy to install, I put mine in last night... see the top of the thread.
    I am looking at placing my antenna in the bed
    ^ with this position I don't know how the reception will be
    The bed is composite but the rails are not! I have my antenna jammed between my windshield and dash but my reception is shit! I don't want it on the roof so I guess my bed is the only viable solution for me. I am just looking for a way to get the wire into the cab. I was able to get the wire hidden under the lip of the side caps and run it to the back of the cab but I have a double cab and don't see a way to get it in unless I run it under the cab, through to the engine compartment then into the cab.
    Any Ideas? :confused:
  2. May 4, 2008 at 1:19 PM
    wbhvacer
    wbhvacer Well-Known Member
    Cartersville Ga.
    Dodge Challenger Rt
    there should be a grommet on the corner of the cab back side that you can run it through it looks like the same size as the one i used under the hood
  3. Feb 3, 2009 at 7:07 AM
    drifter379
    drifter379 CenTex Honky
    Texas
    06 Tacoma SR5 Prerunner
    Secondary Air filter mod,Removed running boards,AFE Pro dry filter,sirius satelite radio,relocated horns,sockmonkey decal,EZ change drain plug,color matched grille,grille craft mx, BHLM, Fog light mod, Hellas behind the grille
