INSTALLED STEERING WHEEL AUDIO CONTROLS ON MY 08
Discussion in 'Audio & Video' started by adio, Feb 20, 2014.
  1. Apr 1, 2014 at 7:58 PM
    #41
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Nice work!
    Ive been reading that the non-bluetooth stereos will not make calls even if i add controls.
    Now, if i get an aftermarket reciever, do you think i can install the right side bluetooth controls, to control the bluetooth calling? If so, i'll likely be doing this mod!
    Thanks,
    Greg
  2. Apr 8, 2014 at 1:49 AM
    #42
    Ernesto4
    Ernesto4 Well-Known Member
    North Hollywood
    15 Tacoma access cab 5 lug SR5
    will this work with an aftermarket stereo?
  3. Apr 8, 2014 at 8:21 PM
    #43
    adio
    adio [OP] Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Not really sure. I'm gonna guess all you would need is an adapter for that specific aftermarket headunit.
  4. Apr 16, 2014 at 9:42 PM
    #44
    skygear
    skygear                    
    Great write up. Considering looking at the NEWER style steering wheel. Wonder if it will all be plug and play.
    Also, wanted to look at the T4R for heated steering wheel. New clock spring and the works. Not sure if it would all work though. Switches are not an issue to wire up. More worried about the rest of it and air bags.
  5. Jul 15, 2014 at 6:37 AM
    #45
    Formula51
    Formula51 Member
    Greenville, SC
    07 PreRunner
    Any updates regarding a steering wheel from the refreshed Tacoma? I am thinking it might be cheaper to buy an entire steering wheel with the audio controls from a salvage yard for those of us who just have a standard wheel now.
    Also, can someone confirm if a standard radio (non-JBL) in a 2007 Tacoma will have bluetooth capability if I add the controls and a mic?
    If not, it is my understanding I will need to buy an aftermarket receiver with bluetooth (deciding between a Sony WX-GT90BT or Pioneer FH-X700BT) and buy the SWI-PS (Pacaudio) interface.
  6. Oct 26, 2014 at 1:28 PM
    #46
    locomotive282
    locomotive282 Active Member
    Peter
    Carson, CA
    '11 DCSB PreRunner V6
    I just did this mod on my 2011 which already had the volume controls on the left side. It is confirmed all that is needed is the right side steering wheel controls and the ribbon cable. This mod was super easy and no need at all to remove the steering wheel or air bag at all.
    Loosen the T30 on both sides:
    After loosening the front airbag and horn button assembly can come off for access. There is no need to remove any of the air bag wires or remove the steering wheel.
    Take off the blank right side control.
    Connect the ribbon cable to the new controls.
    Unscrew the existing control so you can connect the ribbon cable to it.
    Re-secure both sides of the steering wheel controls including the placing the clip on the ribbon cable to the steering wheel housing.
    Put back the air bag horn button assembly and tighten back the t30 screws on both sides.
    You now have both side steering wheel controls!
    I want to thank the OP for showing us this great mod. Very easy and inexpensive if you already have left side controls on your truck. Hope this can help everybody else looking to do this mod themselves.
    gearcruncher, Tex-Tac and STOCKTRD like this.
  7. Oct 27, 2014 at 6:08 AM
    #47
    CanadaToy
    Greg
    Toronto
    Nice!
    Did you wire these controls up to an aftermarket HU, do they work properly?
    Thanks,
    Greg
  8. Oct 29, 2014 at 10:34 PM
    #48
    locomotive282
    Peter
    Carson, CA
    They were wired up to an Pioneer AppRadio 1 and worked perfectly. I just finished installing a Pioneer AVIC 8000NEX and they are still working perfectly without any programing of the Axxess ASWC-1. I have never even updated the ASWC-1 to the latest firmware since the old unit I have uses a special connector unlike the new ones which have a micro USB port.
  9. Nov 7, 2014 at 10:54 AM
    #49
    CanadaToy
    Greg
    Toronto
    That's great to hear, i can't wait to do this upgrade. How are you liking the 8000NEX? I've always liked pioneer.
  10. Nov 7, 2014 at 11:02 AM
    #50
    locomotive282
    Peter
    Carson, CA
    I love the 8000NEX. I was waiting a very long time to upgrade from an original AppRadio which quickly became just a radio after Apple when to the Lightning connector.
    I am hoping this radio can last the life of my truck as it has all the features I could want right now including Car Play mode which works with the steering wheel controls also.
    The only thing I can see adding to the system is a flip down rear seat monitor and a mobile hd tv tuner.
  11. Nov 7, 2014 at 11:05 AM
    #51
    TicoTRD
    TicoTRD Well-Known Member
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    so OP, since u upgrade your radio, do u think it would be possible to upgrade the steering wheel as well? cause im not gonna lie, I like the newer steering wheels wayyyy better. and did u have a write up on the radio install? thanks
  12. Nov 8, 2014 at 1:55 PM
    #52
    locomotive282
    Peter
    Carson, CA
    I'm not the OP I just updated the thread for people who already have steering wheel controls on the left side but no controls on the right side. The OP did just what you were asking upgrade his stock steering wheel to one with controls. It is an expensive mod because it requires purchasing an air bag and a few other parts but can be done.
    As to a write up of the radio install there is a couple out there that I used to reference when I I was doing mine. I should do one myself since I know it could be helpful to others but after finishing my install I dread opening my dash for a while.
  13. Nov 12, 2014 at 8:48 AM
    #53
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    no im talking about installing a 2014 steering wheel into a 20010....is it possible and has it been done?
  14. Nov 22, 2014 at 3:46 PM
    #54
    tbird95
    tbird95 Well-Known Member
    British Columbia, Canada
    TRD sport SR5 V6 DC, LB, 4x4, Tow package
    4runner heated, signal, courtesy light side mirrors, rearview mirror w/compass, temp & backup cam w/ pop luck PL 5400, Interior lights/gauges, BHLM, grillcraft MX black. Third brake light LED swap, rear tail lights LED swap from 2011. 3" Toytec (Boss) Coil overs, rear TSB AAL Bilsteins, Light Racing UCA. TRD grill badge, VIPER Smart Start.
    Thanks for the info, great write up. I just put the blu tooth controls on the rhs of my steering wheel, the controls dont seem to work but all the volume etc still work just fine not sure what the problem would be any thoughts? It's connected just like yours right to left with the ribbon etc, I even used the same part numbers and have an 08. I have an aftermarket deck (Alpine) everything still works fine except the blu tooth controls.
  15. Nov 23, 2014 at 7:04 PM
    #55
    bradforj
    bradforj Well-Known Member
    TN
    07 4x4 v6 TRD Sport
    2012+ Front End Swap 2014 steering wheel swap w/audio and BT controls 2014 power window controls 2014 lower center dash and radio bezel 2014 a/c controls Auto-dimming mirror Heated side mirrors Turn signal side mirrors Backup camera DNX890HD head unit Kenwood speaker system Kobalt slim toolbox In-channel Ventvisors N-Fab running boards
    Check this out:
    http://www.tacomaworld.com/forum/audio-video/267743-axxess-aswc-2.html#post9445515
  16. Dec 5, 2014 at 7:41 PM
    #56
    TRD2006
    TRD2006 Well-Known Member
    stock 2006 4x4 TRD Sport
    I have been wanting to add the switches for the volume in my truck for a while, what all would I need? Ive got a 06 tacoma sport, would i just need the cable and the cover and switch? or would I need a new clockspring?
  17. Dec 22, 2014 at 11:59 AM
    #57
    tigre
    tigre Member
    Tigre
    Escondido, CA
    08 PreRunner SR5 DCLB "Indi"
    Great write up, thanks adio!
  18. Jan 14, 2015 at 11:29 AM
    #58
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    I just got a decent deal on a 2013 wheel for my 2005 taco without any wheel controls (plain wheel, but loaded truck otherwise, TRD Sport). hoping to get an airbag cheap and clockspring and will let everyone know how it goes.
    PS if anyone knows a reason this wont work, please share!!
  19. Feb 26, 2015 at 12:57 PM
    #59
    gearcruncher
    Canadain bumper technician
    I just did the right side blue tooth controls on my 2010 .
    I already have the left side steering wheel controls .
    I have a factory non jbl 6 disc receiver .
    With this said , the Bluetooth controls wont work if you didnt have a factory bluetooth receiver .If you keep the factory radio , you need the blue logic controller http://www.tacomaworld.com/forum/audio-video/80492-2007-tacoma-blu-logic-install-how.html
    However , if you are installing an aftermarket receiver with bluetooth , the right side controls will function fine as long as you purchase the Aswc controller and hopefully your new receiver came with a michrophone .
    [​IMG] aswc-toyota-tacoma-steering-wheel-control-manual.pdf (814.2 KB, 1 views)
    http://www.amazon.com/Metra-ASWC-Steering-Universal-Interface/dp/B0039H2W66
  20. Mar 4, 2015 at 7:34 AM
    #60
    jds0912
    jds0912 Well-Known Member
    Justin
    Baltimore, MD
    2007 Tacoma TRD Off Road
    Some shit I got on craigslist
    Hey man. What does the third bluetooth steering wheel button do when you press it with the new HU? I understand answer and hangup, but when you press the lower button does it go to siri or something?
