Installing 2012 stock radio in a pre-2012
Discussion in 'Audio & Video' started by Jerez, Apr 3, 2012.
  1. Jan 6, 2013 at 4:25 PM
    #161
    Jerez
    Jerez [OP] SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    I ordered those pins as well :cool:
    I've been looking at how to wire up the USB port right now
  2. Jan 9, 2013 at 11:10 PM
    #162
    dibble9012
    dibble9012 Well-Known Member
    Those pins were a tight fit but they worked!!
    Only connections left are ignition power (works fine without it hooked up), FM/AM, GPS, and SAT antennas, and speed signal for the amplifier. Also need to get a different radio surround. Dealer accidentally ordered the one for a 2wd. The climate controls fit fine in the new surround. The radio surround is swappable between the old and new styles. The radio came with an entune account so all that works. Love having pandora, Bluetooth iPod, and iheartradio available on the touchscreen.
    tattoosamm and blksandpearl2010 like this.
  3. Jan 9, 2013 at 11:14 PM
    #163
    Jerez
    Rod
    Ontario Ranch
    Estock
    Sick, how much was the surround?
    Looks good man!! Hopefully I can get the camera working and the USB port to hook up my iPhone straight
  4. Jan 9, 2013 at 11:50 PM
    #164
    dibble9012
    Surround was expensive, but looks good. My old surround was messed up from the previous owner anyways.
  5. Jan 10, 2013 at 9:54 AM
    #165
    Jerez
    Rod
    Ontario Ranch
    Estock
    Gotcha, ya it's in the high $200s
    Cool, now they those pins work, I just have to wait for mine that should come in today
    Old_Skool likes this.
  6. Jan 10, 2013 at 7:57 PM
    #166
    dibble9012
    Got SiriusXM radio working today. Found a male to male satellite radio cable from Toyota. Temp installed right now but looks like the length is perfect to go from the radio to the drivers kick panel. I don't know how it's still working, the trial period is only supposed to be 3 months and it's been at least 4 since I bought the radio. Not complaining though.
  7. Jan 10, 2013 at 10:31 PM
    #167
    Jerez
    Rod
    Ontario Ranch
    Estock
    I need to check the antenna plug tomorrow for you...forgot about it :anonymous:
  8. Jan 11, 2013 at 9:59 AM
    #168
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    so this is a complicated swap- but what about entune/jbl to non entune/non jbl for a 2012 unit? as complicated or less so? any tips on this type of swap?
    thanks
  9. Jan 11, 2013 at 2:11 PM
    #169
    Jerez
    Rod
    Ontario Ranch
    Estock
    Both are a bit complex especially an entune to a non jbl Tacoma...
    Dibble is swapping then entune unit to a 2010 jbl Tacoma
    And I'm swapping a non entune to a non jbl 2008
    I like a challenge :cool:
  10. Jan 11, 2013 at 9:09 PM
    #170
    Jerez
    Rod
    Ontario Ranch
    Estock
  11. Jan 11, 2013 at 9:11 PM
    #171
    dibble9012
  12. Jan 11, 2013 at 9:13 PM
    #172
    Jerez
    Rod
    Ontario Ranch
    Estock
    See the thing is that I don't have the cam and I want to check the exact connection in the back...maybe I'm missing something (since both radios are different)
    And my truck didnt come with a back up cam so I'm installing that from scratch anyways so might as well check how Toyota connected it under the foot panel and stuff
    Oh ya and to test my USB plug
  13. Jan 19, 2013 at 1:25 AM
    #173
    dibble9012
    Actually I'm putting the entune in a non-JBL truck. Little bit more work but worth it so far. I like the challenge too!
  14. Feb 19, 2013 at 7:35 AM
    #174
    dibble9012
    Jerez, were you able to find the part number or source for the USB jack harness?
  15. Feb 19, 2013 at 7:37 AM
    #175
    Jerez
    Rod
    Ontario Ranch
    Estock
    Negative...gave up on this project for a 2-3 months, need to finish up some other "stuff" on it that's been pending for a while now :(
  16. Feb 19, 2013 at 7:46 AM
    #176
    dibble9012
    At the point now where I'll probably just make my own USB adapter cable.
  17. Feb 21, 2013 at 8:38 AM
    #177
    jprovence
    jprovence Well-Known Member
    Joshua
    Albany
    11' Tacoma TRD
    Stock
    So perhaps this would be almost plug n play for my 2011 JBL Tacoma. Its totally different then 2010 and earlier.
  18. Feb 21, 2013 at 8:44 AM
    #178
    Jerez
    Rod
    Ontario Ranch
    Estock
    Negative, same truck same stuff
  19. Feb 21, 2013 at 2:33 PM
    #179
    NorCalTacoma
    NorCalTacoma Well-Known Member
    Northern California
    09 SW Dbl Cab LB TRD Sport 4x4
    Snug top with remote open,Bilstein 5100, rubber bed mat,Kmc Addicts, Duratracs,Pioneer Z150, Arc 900x6, Memphis Mojo Pro Components f&r,2x12 Memphis shallow mount subs.
    So how hard would it be to swap a 2013 entune unit into a 2009 JBL equipped truck? Love the look of the new entune and yours is looking great.
  20. Feb 21, 2013 at 8:11 PM
    #180
    jprovence
    Joshua
    Albany
    11' Tacoma TRD
    Stock
    Weird cause the XM radio is inside the deck unlike some older trucks and iPod adapters don't work either. Something has to be different.
