Installing 2015 Bed Extender in 2007
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bradforj, Oct 9, 2016.
  1. Oct 9, 2016 at 8:46 AM
    bradforj
    bradforj [OP] Well-Known Member
    TN
    07 4x4 v6 TRD Sport
    2012+ Front End Swap 2014 steering wheel swap w/audio and BT controls 2014 power window controls 2014 lower center dash and radio bezel 2014 a/c controls Auto-dimming mirror Heated side mirrors Turn signal side mirrors Backup camera DNX890HD head unit Kenwood speaker system Kobalt slim toolbox In-channel Ventvisors N-Fab running boards
    My father recently traded in his 2015 for a newer truck and gave me his OEM bed extender. It should work on my 2007, but I am unsure what parts I need to get. Has anyone done this? I know I will need some brackets, but I don't know if the 2015 brackets fit the 2007. I did not have a chance to look at his truck before he traded it, so I can't check to be sure. Also, the bed extender has a couple of small straps with buckles. I am unsure what these are for since I have never owned a bed extender before. Do I need additional parts to secure these buckles to the truck?
  2. Oct 9, 2016 at 9:34 AM
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    Not sure of part but I'm 100% it will work. It's the same bed
  3. Oct 9, 2016 at 10:15 AM
    bradforj
    TN
    07 4x4 v6 TRD Sport
  4. Oct 10, 2016 at 9:11 AM
    Dexter9
    Dexter9 Member
    Rob
    MA
    '15 DCSB Sport 4x4
    The straps are to connect the extender to the tailgate (they attach to the tailgate latches on each side). I guess it's to keep the extender from bouncing, but I never use them. All you need are the brackets that mount to the truck. I used some black marine caulk after drilling the holes for the brackets.
    Make sure you test fit before drilling holes. Be sure your extender will flip and your tailgate will close properly
    Edit.. those brackets don't look anything like mine... I have the
    PT392-35000 extender
  5. Oct 23, 2016 at 11:13 AM
    bradforj
    TN
    07 4x4 v6 TRD Sport
