Installing Bilsteins
Discussion in 'Technical Chat' started by grubburg, Apr 11, 2015.
  1. Apr 11, 2015 at 4:26 PM
    grubburg
    grubburg [OP] Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    This is going to be a difficult project. I'm not a mechanic.
    First of all, what are the appropriate points to jack-up the suspension and physically place the jack? I couldn't find any information on this in the manual. i jacked it up at teh cross bar that runs under the driver's seat and attaches to the frame rails down the sides.
    Second, I took the bilsteins out of the box. how do you affix the circlip to the selected adjustable height? it just slides freely.
    just an FYI, i'm doing this one https://www.youtube.com/watch?v=vkVLBOnAifc as it looks straight forward enough...
    third, my plan is to put the jackstands on cinder blocks, as they don't go high enough by themselves. is that considered safe?
    fourth, how high should i jack the truck up? how far off the ground should the tires be? i'm going to set them at 1.75 inches on the bilstein, so how far off the ground should the tires be when i start?
    this is going to be a long thread full of newb questions.
  2. Apr 11, 2015 at 4:35 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Not sure what you mean by this? Where do you place the jack to lift up the vehicle? If so, on the frame or cross member if you don't have your skid on.
    There are instruction on how to move the clip in the box it came in. However, to move it up you just get one edge of the clip out of the groove and work it up then slide it into the next groove. Keep on going until you are in your desired groove. Ensure the clip can freely spin when its in the groove.
    I like this method, done it twice.
    I don't think TW likes cinder blocks. Personally, ive used 2x4 blocks of wood stacked to give me the extra amount of lift necessary..
    Jack it up enough to get the tires off, maybe the tires should be around 2.5 inches off the ground.
  3. May 25, 2015 at 3:31 PM
    grubburg
    2019 TRD OR MT
    again, about the circlip, there isn't really a away to "lock" it into a level. even when it's in the right position, it could easily just be slid to another position. isn't it supposed to lock in at a level, so it's permanent?
  4. May 31, 2015 at 6:05 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    The clips just snap into the grooves. Once the clip is in the groove you want the lower spring perch slides down over the clip. The clip is just there to stop the spring perch at the desired height. But both are supposed to rotate around the shock.
  5. Jun 3, 2015 at 8:33 PM
    technolust
    technolust Erudite Polymath
    Zack
    Lehigh Valley, PA
    2016 Black Tacoma Off-Road
    315 Maxxis RAZR, SCS F5, Bilstein 8112, Dakar Leafs, Tepui Tent, Leitner Design Rack
    I *am* mechanically inclined but on my 4x4 it was a bit of work in the front until I realized what needed to be done to get the strut out. I disconnected the sway and toe arms and it made my life a lot easier. I marked the toe arms w/ permanent marker on the threads to know where to put the adjustment nut back to which helped.
    Unfortunately I do not have a super powerful impact so the spring compressing was a bit of work. I'd blast the clamps down and waste a battery and charge another back and forth and back and forth. I guess I need to man up and get a proper air impact. I've been putting it off far too long.
    Anyway, I've never worked on a Toyota (or a truck) before but using pry bars, leverage, a bit of hammering and lots of disconnecting of components I got it to work.
    As far as lifting the truck I used two large blocks of wood stacked up and jacked via the rear diff. Once the tires were in the air I removed them, then lowered it onto my jack stands. My stands were the limiting factor. Full droop in the rear had the tires on the floor and the jack stands. It's a bit of a learning curve when you're used to low Subarus like I am.
    My advice is be sure you use all the proper shims/bushings/etc when assembling your shock because I forgot one shim as I was getting tired and forgetful and saw it on the floor and this was after I struggled to get the strut assembly back in the front. So, I took it BACK out and once again disassembled and reassembled the strut.
    Next time I do it it'll take 1/3 the time. That's how it always goes.
  6. Jul 1, 2015 at 1:25 PM
    Rocket's World
    Rocket's World New Member
    Tom
    2006 Trd Acess Cab
    Did you have to remove the front sway bar to drop out the strut assemblies?
  7. Jul 7, 2015 at 8:53 PM
    KauaiBoy
    KauaiBoy Active Member
    2003 3.4L 4x4 Tacoma Xtra Cab
    K&n Intake, Toytec Bilstein Lift
    @Rocket's World On your truck you need to loosen the sway bar bracket so that you can move the linkage out of the way, but don't need to actually remove the sway bar.
  8. Jul 7, 2015 at 9:00 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    only caveat to what kauaiboy said is: if you dont remove the sway bar, its will make it a pain to get the coilover out. First time I put 5100's/eibach coils on i removed the sway bar completely and had no issues. Second time (I went from .85 to 1.75 setting and added TC UCA) I tried to save time by just loosening the sway bar and left it on (I didnt feel like removing the pelfrybilt skid) and it wasted 15-20 min (each side) fighting the sway bar to get the coilover out. if you have a stock skid, remove it, followed by the sway bar (the pelfry skid weights like 40# and held by 6 bolts, by yourself it can be quite a task taking on and off (especially if truck is on a lift already and youre by yourself). Just my 2 cents. good luck
  9. Jul 7, 2015 at 9:13 PM
    KauaiBoy
    x2 ^^ Good thought
    I just got my info on this from helping a friend and watching youtube so take it with a grain of salt.
