Installing front Bilstein 5100s. What do I need?
Discussion in 'Suspension' started by trdracing5, Oct 8, 2010.
  1. Oct 8, 2010 at 2:02 PM
    trdracing5
    trdracing5 [OP] Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    I am planning on installing my Bilstein 5100 front shocks next weekend. I am going to go ahead and assemble everything before hand and then install on the Tacoma. What else do I need besides these items?
    Bilstein 5100 shocks.....
    OME coils....
    KYB Shock mount....
    Shock bushings and washer kit...
    Coil Compressor...
    Is there anything else I need to make this go smoothly??????????
  2. Oct 8, 2010 at 6:59 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    an 18 pack of your favorite beer :D
  3. Oct 8, 2010 at 7:01 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    for afterwards off course :laugh:
  4. Oct 8, 2010 at 7:05 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    if those are your coil compressors, i would recommend getting a better set.
  5. Oct 8, 2010 at 7:16 PM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    Coil compressors were only a pic but I think the local auto parts rents out the same type. Is there a better type that I should look for?
  6. Oct 8, 2010 at 7:18 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    I used those, they sucked but they worked. Had to crank down real hard.
  7. Oct 8, 2010 at 7:24 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    those will be hard to do if you preload your setup. the arms are not think enough to extract from the compressed springs
  8. Oct 8, 2010 at 7:26 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Those compressors are just fine if you use them wisely. I've used them several times. Here are some tips:
    1. Grease the threads. It takes a lot of torque to compress the coils and you don't want thread binding to make it even worse.
    2. Make sure the compressors are on exact opposite sides of the coil. Squeezing too much on one side won't ever give good compression (Not to mention the danger of it possibly slipping out.)
    3. Take the claws off the bolts, work them as close to the top and bottom of the coils as possible, and put the bolts back in. Just squeezing a few coils in the middle won't really get you anywhere because the outer coils will continue to expand.
    4. Compress the two sides equally. I personally do 3 turns this side, 3 turns that side. Back and forth, back and forth. This keeps the pressure evenly distributed for both ease and safety.
    5. If you have, or can borrow, an impact wrench, use it!!! It turns and arm burning hour into a ten minute breeze.
  9. Oct 8, 2010 at 7:30 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    You can do it if you take the bolts out and spin each claw out to the middle-ish area of the coil where the gaps are a little bigger. If you leave the bolts in, you'll never get the claws in or out worth a damn.
  10. Oct 8, 2010 at 7:35 PM
    SlimDigg
    SlimDigg We Back!!
    Calgary, AB
    Coming Soon....
    is this the ideal setup for the front of a 2001 double cab 4x4? I want to get the billies but i'm wondering whether to go with stock coils or aftermarket?
  11. Oct 8, 2010 at 7:35 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    just have a shop put the shocks together for you. i had Midas do mine for $40, only took 10 min.
  12. Oct 8, 2010 at 7:59 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    There is no "the ideal" set up. Basically, this is one of those "You get what you pay for" situations. The more you pay, the better your suspension will be. Stock coils are fine. Aftermarket coils are better. You can spend anywhere between $100 for spacers and over $1000 for adjustable coilovers. The important thing is to do your research and find what you need/want. You don't need Icons if you only fart around on off road trails now and then. Those are designed for bombing through the desert at 60mph. Even if you don't need them, that doesn't mean you don't want them. You decide.
    Yep, that's easy but I'm too cheap. My wife is already giving me enough shit for buying parts then coughing up $60 for ANOTHER alignment.
  13. Oct 8, 2010 at 8:03 PM
    ColtsTRD
    Scott
    AZ
    this is what i'm doing...I called up a Midas over here by me and they quoted me that same price
  14. Oct 9, 2010 at 11:47 AM
    SlimDigg
    SlimDigg We Back!!
    Calgary, AB
    Coming Soon....
  15. Oct 9, 2010 at 2:57 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    5100's and coils such as a set of Old Man Emu's (OME) would have you prepared for anything. I can't remember the 1st gen coil model numbers but I think they are 881, 882, and 883. They have different heights and spring weights. Probably the middle one would give you a little lift and a little more stiffness to support your bull bar. Coils will only add about $150 to your cost and I would really recommend them over stock. OME's typically lift your vehicle only about 2" by themselves. If you decide you want more lift, you could move the 5100's up a notch or add a small top spacer.
  16. Oct 15, 2010 at 7:44 PM
    KauaiSandRambler
    KauaiSandRambler Member
    Chad
    Kauai
    07 Tacoma TRD 4x4
    Will these coil springs give lift in addition to the settings on the 5100's? Just asking as I got my 5100's and now in the marked for an aal (gotta buy my parts one by one so the wife doesnt get suspicious... she thinks these are necessary repairs:)). Would like to get a little more lift if the coil spring will add that and can go for a 2.5 aal insead of the 1.5".
  17. Nov 4, 2010 at 9:30 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Sorry to hijack, but I'm putting my 5100's on my '06 4x4 this weekend and have a couple of basic questions about the install:
    1 - If I set them at 2.5" with stock springs, do I need a sway bar relocate?
    2 - Do I need a diff drop kit for 2.5"?
    3 - For the rear, I am putting 5100's with toytec 2" AAL (no TSB). Do I need longer U-bolts than stock?
    Thanks for any tips.
  18. Nov 5, 2010 at 5:43 AM
    bgbdwlf
    bgbdwlf Well-Known Member
    surprise,az
    08 PreRunner Off Road
    bone stock for now
    trdracing where did you find the KYB shock mount, i want to do the same thing and pre-assemble mine.
  19. Nov 5, 2010 at 4:48 PM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    Im doing 5100's on the front of mine tomorrow using the" crappy" spring compressors, this will be about the 6th pair of struts I've done, just my first time on a tacoma, ill let u know how they work
  20. Nov 6, 2010 at 7:48 AM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    Getting one more thing to help make the job a bit easier....
