Installing Gauge Overlays
Discussion in '1st Gen. Tacomas (1995-2004)' started by MartyB, Mar 5, 2019.
  1. Mar 5, 2019 at 4:43 PM
    MartyB
    MartyB [OP] New Member
    Hi. Can anyone tell me how difficult it is to remove the dash panel to put new faces plates for the speedometer, tach, etc.? I have a 2000 Tacoma 2-door. Thank you.
    Here's what I am looking at if I can install it.
    https://www.ebay.com/itm/381684738808
  2. Mar 5, 2019 at 7:00 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I’ve had that cluster out a million times. Probably <5 bolts for the lower dash trim, 2 or 3 screws for the cluster trim, and 4 or 5 bolts for the cluster itself.
    Takes five to ten minutes max. Be careful separating the lens from the cluster body, you might crack a tab.
    Taco critter likes this.
  3. Mar 6, 2019 at 3:48 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    It took me longer than five to ten minutes. But I've only done it once. The hardest part was, as I recall, the interference between the dash and the cluster. There are writeups about it and they show all the trim pieces you have to remove and how to do it.
  4. Mar 6, 2019 at 8:08 PM
    MartyB
    Thanks much. I will give it a try when the weather gets warmer. Marty
