Installing icon C/O w/o resi
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma mud, Jul 30, 2011.
  1. Jul 30, 2011 at 7:17 PM
    Tacoma mud
    Tacoma mud [OP] Well-Known Member
    Kyle
    TEXAS
    97' xtra cab sr5 4x4
    soon to come
    How hard is it to install this kit on my 97 tacoma? Will i have to get diff. Drop and sway bar drop? :confused::confused:
  2. Jul 30, 2011 at 7:20 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    if they are pre-assembled (pretty sure they are), then it's not a big job at all... only a few bolts per side to remove and then even less to install the new stuff. you'll need a floor jack and some basic hand tools.
    check your cv angles... you may need a diff drop... or you may find that you're alright.
  3. Jul 30, 2011 at 7:22 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    What angle are they supposed to be at?
  4. Jul 30, 2011 at 7:31 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    And how hard would it be to intall the TC ucas???
  5. Jul 30, 2011 at 7:33 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    not hard at all, remove stock put on new
  6. Jul 30, 2011 at 7:40 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    Ok thanks! :D
  7. Jul 30, 2011 at 7:46 PM
    ktmrider
    Junk
  8. Jul 30, 2011 at 9:16 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    it's a pretty straight-forward process. make sure you've got a 4 lb. deadblow hammer and a ball-joint press and/or a 2/3 gear puller (you can rent from autozone or o'reilly's, etc.). i could not have done the removal of the stock ucas without those.
  9. Jul 30, 2011 at 9:16 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    as close to flat as possible. a little bit of downward angle is ok, but you don't want too much.
  10. Jul 30, 2011 at 10:50 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    Ok well hopefully i dont have to cuz my cash is already running low :(
  11. Jul 31, 2011 at 12:30 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    its hard to save money when you find out about this forum. but its all worth it.
  12. Jul 31, 2011 at 12:50 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Step one: remove your sway bar
    Step two: Don't take corners nascar style
    Step three: take it off road
    Step four: think about the awesomeness of no sway bar :D
  13. Jul 31, 2011 at 6:31 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    it doesn't cost anything. you put down a deposit that's 100% refundable within 48 hours usually. trust me, you'll wish you had them when you're mid-way through tearing your truck's suspension apart and you get stuck and have to walk to the nearest auto parts store to get 'em! :)
