Installing Inverter in Cab
Discussion in 'Technical Chat' started by IronWay, May 4, 2021.
  1. May 4, 2021 at 11:09 AM
    IronWay
    IronWay [OP] Get out there!
    Steven
    St.Paul MN
    2017 Tacoma TRD Offroad
    C4 Winch Bumper, SmittyBilt Winch, Pelfreybilt Mid Skid, Rear Skid, and Rock Rails. Lund Topper with Thule Aeroblade Rack System. ARB Rooftop Tent
    Hey all,
    Hoping this is the right place to ask so here goes.
    I just purchased a Renogy 1000W Pure Sine Inverter and I want to install it somewhere in the cab. I have a 2017 Tacoma with a double cab. Im wondering if anyone has any suggestions as to where in the cab is a good install location that won't be awkward or in the way. Also, looks like I'll be running 2AWG wire from my second battery (house 100A LifePO4) that's under the hood. I had originally considered putting the inverter in the bed but don't feel good about running that long a line from the battery.
    Thanks in advance,
    /s
  2. May 4, 2021 at 2:11 PM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    Seems like the best place would be behind the rear seat, either mounted to the plastic cubby or to a carpet covered piece of plywood or molle panel you install after removing the cubby. In the under seat storage compartment would be good also, but you probably need more airflow to keep that thing cool. The noise from the ventilation fans would make me install it as far away as possible.
  3. May 6, 2021 at 11:15 AM
    mr.rick
    mr.rick Well-Known Member
    Rick
    2021 Voodoo Blue TRDOR
    Other option would be under one of the seats similar to how you would install a subwoofer amplifier. I have an inverter that I plan to install as well, I just haven't gotten around to it and haven't really looked at locations yet.
  4. May 6, 2021 at 11:27 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I would park it under the pax seat, working face lined up with the rear edge, so that its still accessible to reach.
    Is it just me or have inverters gotten stupid expensive lately? Seems like not too long ago I could pick up a 1000W for less than half that.
    ORtoCOTaco likes this.
  5. May 6, 2021 at 2:45 PM
    IronWay
    Steven
    St.Paul MN
    Under the Passenger seat would be ideal, not sure I have the room to make that work though.
    Agreed, very expensive. However, last time I shopped inverters, years ago, I didn't understand sine wave tech at all. Could be Pure Sine has always been a lot more.
  6. May 6, 2021 at 2:52 PM
    LC7
    Far Nor Cal
  7. May 6, 2021 at 2:58 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    It's good for some things, but it's also marketing. Your house isn't pure sine. Most electronics can take a certain degree of dirty power. The only item I've seen that really, truly needed a clean sine wave was the scanning electron microscope I have at the office. Besides that my air conditioner and TV need *mostly* clean power, everything else can run on dirty. :cookiemonster:
    Grossomotto likes this.
  8. May 6, 2021 at 3:05 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    In the whiskey compartment behind the rear seat or under the passenger seat. There is about 1 din of usable space under the console too but the size of a 1k may not fit.
  9. May 6, 2021 at 3:32 PM
    IronWay
    Steven
    St.Paul MN
    Im afraid if I put in the compartment behind the rear seat it will not get enough airflow and overheat. Also, plugging anything into it would be more challenging. That would otherwise be a very good spot.
  10. May 6, 2021 at 3:33 PM
    IronWay
    Steven
    St.Paul MN
  11. May 6, 2021 at 3:45 PM
    LC7
    Far Nor Cal
    From that thread:
    "There are two large torx head screws under the plastic trim on each side
    take the screws out, flip the bar, and bolt them back in ( they screw right into the end of the bar)
    there is an alignment tab on the bar that you may need to grind down a hair to get it back in there"
    There are several other examples of TW members doing it, I just didn't dig any deeper. I might have read about it in the Audio & Video sub-forum.
  12. May 6, 2021 at 3:59 PM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    I Understand. I have a spare battery with charger and a 50 watt ham radio there. It gets hot but would shut off if too much and never has.
