Installing lunchbox locker in front diff
Discussion in '1st Gen. Tacomas (1995-2004)' started by devinzz1, Feb 23, 2015.
  1. Feb 24, 2015 at 9:21 PM
    devinzz1
    devinzz1 [OP] Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    What are selectable locker options besids the arb then?
  2. Feb 24, 2015 at 9:30 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    IIRC an LSD from the old school twin turbo Supras will fit. If you can find one.
  3. Feb 24, 2015 at 9:46 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    can't says I'm aware of another...
    but I'd personally choose the ARB regardless.
    tried and proven...
    worthy of it's investment ;)
  4. Feb 24, 2015 at 9:49 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    limited slip... is not a locker.
    and is dang near useless off road.
    tho' braking application can help...
    it's too damn much effort and brake wear IMO
  5. Feb 25, 2015 at 3:15 AM
    Brake Weight
    LSD is quite useful offload. I had a 4wd Tundra Limited once with a rear LSD that proved quite handy.
    Applying brakes to a normal, open diff can make it act like an LSD.
  6. Feb 25, 2015 at 6:58 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Crom likes this.
  7. Feb 25, 2015 at 8:00 AM
    Brake Weight
    That's for a 2nd gen.
  8. Feb 25, 2015 at 8:35 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    Absolutely, I couldn't agree more. It is just not something I would do. I travel up north in the winter way to often to let a LB locker limit me from traveling.
  9. Feb 26, 2015 at 6:36 AM
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Just sold a buddy's 2007 Jeep with a lunchbox kit in it. Never, Never, again.
    Lincoln locker before dealing with that stuff again, and again, and again.
    Noisy delicate POS!.
  10. Jul 28, 2015 at 10:37 AM
    Brake Weight
    Ordered an Aussie front today. Hopefully it'll come in with some cooler weather so I can install it.
  11. Jul 28, 2015 at 12:43 PM
    devinzz1
    devin
    2023 aclb trd or mt
    I never did order one but would still like to have one. My base pan is slowly leaking oil and the diff has to come out either way to fix.
  12. Jul 28, 2015 at 1:18 PM
    Brake Weight
    That's why I went ahead and ordered one. Oil pan leak is getting worse and I got a little bonus on my paycheck. May as well do something when the diff is on the ground.
  13. Jul 28, 2015 at 3:58 PM
    mrbeggins
    mrbeggins LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    I sure hope you have manual hubs!
  14. Jul 28, 2015 at 4:04 PM
    devinzz1
    devin
    2023 aclb trd or mt
    nope. Cant see it causing a problem in 2wd either.
  15. Jul 28, 2015 at 4:48 PM
    #35
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    well...put it in and let us know! Haha.
    I still don't think it's a great idea. It won't perform how you think it will. You'll constantly be battling steering issues with that thing in the front. Not being able to turn when your in a jam. Unless you have full hydro or even hydro assist, the factory rack will shit the bed within the first year. Being able to engage and disengage the front is the only way to go with these trucks. IFS that is
    Good luck!
  16. Jul 29, 2015 at 6:48 AM
    #36
    Wulf
    Wulf no brain just damage
    rock raisin
    I have to say that's a little dramatic!
    But I agree on one thing, it will be a bitch to turn in 4wd
  17. Jul 29, 2015 at 6:48 AM
    #37
    Brake Weight
    From what literature and reviews I've read, it'll be just what I want. I don't rock crawl and my truck isn't a trail rig. In the south here, it's mostly dirt and mud...the soft stuff. To get to a rock trail I'd have to travel 2+ hours.
  18. Jul 29, 2015 at 11:10 AM
    #38
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Just wire in a switch to the add in the front axle, then you can disengage the pass. side axle shaft when on hard surfaces or tight maneuvering essentially creating an open diff to reduce binding issues but still have 3 wheels(if locked in rear) pulling. Buddy did it on his 4rnr without a locker up front just so he had the option of 2 low.
  19. Jul 29, 2015 at 11:39 AM
    #39
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    I still don't see how that's possible as the ADD is vacuum actuated.....? It would have to be a selenoid, similar to an ARB switch
  20. Jul 29, 2015 at 11:56 AM
    #40
    devinzz1
    devin
    2023 aclb trd or mt
    I already have that done as a 2lo mod aswell.
    I have a switch wired into the blue solenoid valve as a 2lo mod. All those problems you listed with the hard steering would apply to any locker up front (thats engaged) not just the lunchbox ones. And really i havent heard of people unlocking their arbs everytime they want to turn while wheeling.
