installing sirius on stock touch screen radio
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cewildman, Oct 11, 2012.
  1. May 7, 2014 at 6:43 PM
    #121
    chetweewax
    chetweewax Well-Known Member
    NJ
    15 TRD Sport
    Homelink mirror (Adding soon) Came with truck: FUEL Rims, Mickey Thompsons, Vinyl Tonneau Cover, Remote Start, 20% front window tint
    Glad to have helped
  2. May 31, 2014 at 8:21 PM
    #122
    pasotaco
    pasotaco Well-Known Member
    Central Coast, CA
    2013 4x4 Access Cab
    LCE headers, King 2.5 Coilovers w/ res, TC UCA's, King resi's in rear, Geared to 4.88, rear locker, Timbren Bump stops, All Pro Leafs, Carrier bearing drop kit, ARB onboard air,
  3. Sep 22, 2014 at 1:51 PM
    #123
    98 Taco RRXJ01
    98 Taco RRXJ01 New Member
    bobby g
    round rock tx
    completely bed lined
    I got a question for the 12V guys here:
    I have a 2013 std cab basic model
    I already have a Sirius Starmate 5 dock and play unit that was installed in my previous work truck(2011) Ford Ranger.
    I had it running through the FM Direct Adapter
    These new Toyotas dont have the old style antenna connector
    What are my options: is there a adapter to convert the new antenna connter?
    Can I use a direct mini plug to the radio mount and the stock radio(dash USB/mini plug input)?
    thanks
    bob
  4. Sep 22, 2014 at 1:57 PM
    #124
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I had that same unit for a little while, just connect from the aux to the sirius unit and it plays through the speakers like an iPod. Only thing you don't have is steering wheel controls.
  5. Nov 6, 2014 at 3:30 PM
    #125
    ScottInOKC
    ScottInOKC Well-Known Member
    Scott
    Oklahoma City
    I installed the 00016-00076 kit per the instructions, but my unit isn't recognizing there's a satellite tuner hooked up.
    2014 base model, non Entune radio.
    Thoughts?
  6. Nov 6, 2014 at 3:35 PM
    #126
    chetweewax
    NJ
    15 TRD Sport
    Try turning the tuner knob when you first turn the radio on
  7. Nov 6, 2014 at 3:52 PM
    #127
    ScottInOKC
    Scott
    Oklahoma City
    No bueno. Every thing powers up and the AM/FM/Bluetooth all work just ducky. No satellite input is shown on the Audio screen.
  8. Nov 6, 2014 at 3:53 PM
    #128
    chetweewax
    NJ
    15 TRD Sport
    So you were not getting the satellite icon on the touchscreen?
  9. Nov 6, 2014 at 3:54 PM
    #129
    ScottInOKC
    Scott
    Oklahoma City
    Correct.
  10. Nov 6, 2014 at 6:46 PM
    #130
    ScottInOKC
    Scott
    Oklahoma City
  11. Nov 7, 2014 at 9:44 AM
    #131
    ScottInOKC
    Scott
    Oklahoma City
  12. Dec 4, 2014 at 7:22 PM
    #132
    Sum14U2Nv
    Sum14U2Nv New Member
    Texas
    2012 Toyota Tacoma X-Runner
    There is an adapter cable out that will allow you to connect the oem shark fin antenna for use with siriusxm. There are 2 different ones so be sure to Google the part numbers for pictures and figure out which one you need. SFA12F and SFA12M are the part numbers to the different siriusxm antenna adapters. Hope this helps.
  13. Apr 27, 2015 at 8:48 AM
    #133
    bbdmac
    bbdmac Well-Known Member
    Leominster, MA
    2013 TRD Sport Double Cab
  14. Nov 6, 2017 at 5:08 AM
    #134
    siderman
    siderman Well-Known Member
    Bringing this thread to life again..... I have a 13 Taco with touchscreen unit, no SAT/NAV. I have the opportunity to get a '14 unit with SAT for a good price. Anyone know if this is a plug & play? One thing I'm not sure about is the antenae, I do not have the shark fin but have the regular standing hood one. Does that matter?
  15. Nov 6, 2017 at 12:33 PM
    #135
    anarion55
    anarion55 Well-Known Member
    Tony
    S. Florida
    2013 PreRunner SR5
    ImMrYo's Mirror Mod, Stereo Upgrade - Power Pro 60x4 Amp/Kicker powered 8" sub/Pioneer component speakers, PassPort 8500 Radar Detector, Locking Bed Storage Cubbies, Onboard air system - Viair 450C compressor/16 gal. PVC tank/15 & 16" horns, quick-d/c air chuck in bed cubby 24" LED light Bar (mounted to skidplate)A Headlights, foglights interior lights and backup lights all converted to LED (HUGE difference)
    I'm digging way back into my feeble memory here (since I added the Sat module back in 2013)... so forgive me if I'm short on details...
    Mine was added by buying the sat receiver module from Toyota (the required mounting kit is for a Scion - I had to find a knowledgeable parts counter guy who knew this and was able to find the right part number (I may have an entry earlier in this thread with more details).
    The Satellite Receiver MOUNTING KIT came with the antenna, which was NOT the fin type - it is a magnetic mount black antenna, measuring about 1.5" square, and maybe .75" tall, with rounded edges, and a single wire coming out of it. After some experimentation for best reception/least ugly, I mounted mine on the leading edge of the cab's roof, flush against the windshield weatherstippinh, with the wire forward. The wire runs under weatherstripping to the to the driver's side, and exits the lower corner of the windshield, into the engine comparttment. From there it passes through an existing firewall grommet/seal, under the carpet, to the module, which I located under the driver's seat. That was the hard part. The magnet holding the antenna to the roof is very strong, and in that location it is fairly unobtrusive. It has never moved out of position unless I moved it purposely (to wash/wax). It should work equally well at the rear of the cab roof, if you want to run the cable through the 3rd brake light housing, but it would not look as “clean” in my opinion.
    The module is indeed “plug & play” with the stock (non JBL) head unit, which has a multi-pin connector jack specifically for that purpose (it also provides power to the module, I believe). The head unit will automatically recognize the Sat RX module, and it will show up on the touch screen menu along with the other sources.
    Hope this helps.
  16. Nov 6, 2017 at 3:23 PM
    #136
    siderman
    thanks for the quick reply. I'm probly not asking correctly, sorry. Did more research as this is totally new to me and spur of the moment. My antenna wont work and will need to mount and route a new sat one to the radio (head?) unit I now know. What I cant find is if the sat module is built in to the radio unit or in the truck seperate from it. If its in the 2014 unit that is what I'd call plug, play as only needing to hook up the antenna wire, hopefully that will fit?
  17. Nov 6, 2017 at 3:43 PM
    #137
    anarion55
    Tony
    S. Florida
    2013 PreRunner SR5
    I can't comment on the JBL/Entune unit, but the "base" head unit uses a separate Satellite RX unit that plugs (via a cable) into the back of the head unit. Should be the same on the 2014 as on the 2013, but I can't swear to that.
  18. Nov 6, 2017 at 4:43 PM
    #138
    siderman
    The guy sent me some pics looks like you said is 2 units all I should need is a SAT antenna and of course a subscription. One more question if I may. I,m guessing there will be 2 antannae, the original for the standard am/fm and the additional SAT one?
  19. Nov 6, 2017 at 5:31 PM
    #139
    anarion55
    Tony
    S. Florida
    2013 PreRunner SR5
    Correct, but the stock whip antenna (on the passenger side, at the rear of the front fender) is already there for AM/FM. The sat radio kit has everything you need to add Sirius/XM to the stock head unit. An example of the installation instructions and parts list for each of the kit's components is shown here:
    http://toyotaparts.sparkstoyota.com/install/00016-00076inst.pdf
    This kit and instructions are for a Prius, but it's very similar to what the Taco uses. Talk to the parts counter guy and he'll hook you up.
    As you can see, you can order each part individually, but it would probably cost more that way than if you buy the whole kit.
  20. May 14, 2018 at 5:44 PM
    #140
    JBChicken
    JBChicken Member
    What unit would be best to upgrade my 2018 Tacoma SR radio to get XM? No nav, no satellite came with it
