Installing the Bestop Supertop on my 2016 Tacoma.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dr_D, May 9, 2016.
  1. May 9, 2016 at 7:45 PM
    Dr_D
    Dr_D [OP] Member
    Marina del Rey, California
    2016 Tacoma Access Cab
    Does anyone know if you're supposed to drill or cut into the composite bed to install this? Thanks!
  2. May 10, 2016 at 7:10 AM
    jimilivz
    jimilivz Member
    Seattle
    No drilling required. You should know up front that Bestop has thus far elected not to update their top for the 2016 Tacoma. The bed rail to top of cab dimensions are slightly different. The top of the Supertop will be about an inch above the top of the cab. This would probably increase drag and pose a greater risk of blow-off while driving. The problem has been discussed elsewhere in the forums. Here is a link below to the instruction manual:
  3. May 10, 2016 at 8:42 AM
    Dr_D
    Dr_D [OP] Member
    Thanks jimilivz. I'm new to the forum so still figuring out how to navigate it.
  4. Sep 13, 2016 at 1:43 PM
    joetacoma16
    joetacoma16 Active Member
    2016 tacoma trd OR access cab
    How did the install go? Can you share pictures?
  5. Sep 14, 2016 at 11:28 AM
    Dr_D
    Dr_D [OP] Member
    The install did not go! I called the manufacturer 2xs and they confirmed that it would fit the 2016 - FALSE! I got halfway into the install when I realized that there was no physical way to make it fit. Save yourself the frustration!
  6. Sep 14, 2016 at 7:29 PM
    joetacoma16
