Instrument Panel Lights have gone out
Discussion in 'Lighting' started by BenHyman, Jan 18, 2009.
  1. Jan 18, 2009 at 7:22 PM
    BenHyman
    BenHyman [OP] New Member
    Minneapolis
    2002 Toyota Tacoma Ext Cab
    I asked this question in another forum; I drive an 02 Tacoma Ext CaB. It appears that two of my instrument panel lights have gone out; the ones behind the tachometer and engine temp. Could this be a bulb problem or a fuse problem? I would think that if it's the fuse, all inst panel lights would go out. How difficult is it to replace these bulbs? Is this better left to a pro, orcould this be done by an inexperienced hack (like me).
    Any help would be appreciated.
    Regards
    Ben Hyman
  2. Jan 19, 2009 at 11:50 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    You're right - if it were a fuse problem all the dash lights would have gone out.
    You'll need to remove some dash trim to get to the instrument cluster bulbs.
  3. Jan 20, 2009 at 10:23 AM
    notbrigum
    notbrigum Well-Known Member
    Chandler AZ
    08 double cab 4x4
    TRD intake, Magnaflow exhaust, billet grille, tube steps
    You asked if better left to a pro (a dealer tech perhaps) or a 'hack like myself'..:) What would 'I' do? It can be a fair amount of work to get the trim off, then pull the instrument cluster out and disassemble to some degree the back of the cluster to get to the bulbs (althought they're prob right there on the surface and unscrew). I would pay the money to have the dealer do it. It's annoying to pay someone for work you can do yourself but.. Are these speedos mechaincal or electronic? If they're still mechanical, then there's also a cable that has to be disconnected from the back of the cluster/speedo head. No big deal, just more work.
    My vote? If it's an electrical speedo and you're bored and fairly good with this stuff, do it yourself. If it's a mechanical speedo, you're not so good w/this stuff, pay the dealer. Maybe 90 mins of labor? Maybe $100? Just guesses. If you do it yourself, you've got to drive to the dealership with the bad bulbs in hand once you take it apart and hope they have them in stock? Good luck.
  4. Feb 1, 2009 at 5:41 PM
    apkarian100
    apkarian100 Well-Known Member
    Hooksett,NH
  5. Feb 1, 2009 at 5:46 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    At $90 and hour and I would bet the time/labor book says 3-4 hours, I'd do it myself. And that pesky 10% rag fee would just piss me off....
  6. Feb 22, 2009 at 1:35 PM
    Bob Loblaw
    Bob Loblaw Active Member
    Victoria BC Canada
    '96 4x4 Extra Cab 2.7L & '07 Double Cab 4X4
    HELP!! I'm in the middle of this job right now, but I'm stuck at #14. All my trim panels are off, the gauge cluster is unscrewed, the wiring harnesses are unplugged, but the guage cluster won't come out. Do I have to disconnect the speedo cable? How? Not much room in behind there.
  7. Feb 22, 2009 at 3:10 PM
    apkarian100
    Hooksett,NH
    Just pull the speedo cable out of the back, simple as that. It just pulls out.
  8. Feb 22, 2009 at 3:32 PM
    Bob Loblaw
    Victoria BC Canada
    Roger that! After squeezing my hand in behind to try and unclip the damn thing, cutting my flesh to shreds, I thought I'd try a mighty tug, and sure 'nuff. Out she popped.
    On a side note, you will need 4 (count 'em four bulbs) for the LED conversion. 2 centre ones for tach & speedo, and 2 outer ones for temp & fuel. (At least that's how it is in my '96) So I had ordered 2 bulbs for this job, had a spare from changing the gauge bulbs to LEDs in my '59 Bug, and I'm still one shy. So now I gotta order 1 more bulb (and maybe another spare) and take it all apart again next weekend to change out that last bulb. Dammit!
    Enough of this for now, I'm going in to watch the NASCAR race from California. Go Kyle Bush!!
  9. Feb 23, 2009 at 1:05 PM
    Bob Loblaw
    Victoria BC Canada
    So I went for a ride last night after the race (Kyle Bush finished 3rd) to check out my new lights. Lovin' 'em!! Even though the fuel guage is still illuminated with the OE bulb, the rest on the left side of the cluster look AWESOME! I love the way the blue light changes the colour of the needle from orange to what appears to be white. Can't wait for my other bulb to arrive.
  10. Feb 23, 2009 at 3:41 PM
    apkarian100
    Hooksett,NH
    Glad to here you like the conversion. I still love looking at my dash after the conversion.
  11. Mar 28, 2013 at 8:09 AM
    scoostraw
    scoostraw Active Member
    Ken
    Wisconsin
    1995 Tacoma 4x4 Ext Cab 6cyl 5-Speed
    Reviving an old thread here.
    What part number leds are needed for this? There's a piece of debris in my 95's gauge bezel, and while I'm in there to re move it I thought I might pop in led's. But I have no idea which ones to get, nor where to source them?
  12. Aug 22, 2013 at 7:03 PM
    BigBossTaco
    BigBossTaco Member
    Buffalo, NY
    02 Tacoma
    Gibson catback, tailgate seal, cone filter mod, extang tonneau cover
    hey, im currently facing this problem. the link to remove the instrument cluster seems to be dead. does anyone have a working link?
  13. Nov 6, 2013 at 9:17 PM
    Tyler Andrews
    Tyler Andrews Well-Known Member
    Tyler
    Eugene
    03 Ext cab DLX tacoma
    pro-comp wheels, 15% tint
    Any advice for getting the wires unplugged from hazard lights, rear locker, reostat dimmer switch, etc. Can't seem to get them unplugged, and can't move any further until i get them out!
