Intake for HP
Discussion in 'Performance and Tuning' started by dunkhi, Jan 6, 2009.
  1. Jan 6, 2009 at 7:10 PM
    dunkhi
    dunkhi [OP] CSULB socal
    Craig Sirois
    Southern California. Fountain Valley
    09 Ivan Stewart
    Toytec Coilover kit. Bilstein's 5100. Alcoa Wheels. General Tires. Magnaflow Cat-back. BLHM. Yellow fogs. 13TW5 jl sub. Stewart Decals.
    Im looking for an intake PURELY for horsepower/acceleration.
    Without having mpg into the picture.
    anyone got any suggestions?
  2. Jan 6, 2009 at 7:18 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    well airaid. AFE makes a good one. and K&N
  3. Jan 6, 2009 at 7:26 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    hmm... URD
  4. Jan 6, 2009 at 7:31 PM
    dunkhi
    Craig Sirois
    09 Ivan Stewart
    well i know afe is great for diesel i also have a duramax 2500 with it and a tuner.
    but i am not sure how it goes on the gasoline.
    im leaning more towards k&n but then again there is probably better company's out there
  5. Jan 6, 2009 at 9:35 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    i just got a new intake, ill sell u my k&n with 2 filters for $130. im also in socal
  6. Jan 7, 2009 at 1:27 AM
    ERdept
    ERdept Well-Known Member
    I got the K&N but it's the Non-street legal version.
  7. Jan 7, 2009 at 2:39 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    The only CAI that is CARB exempt is the Airaid. And you will be wasting your money on that if you are looking for performance.
    The best designed intake for performance is the TRD/AFE intake. (The TRD one is made by AFE).
    I am running the K&N intake with a True Flow filter. And to date I have the fastest trap speed in the 1/4 from a 1gr (best of my knowledge, and a lot of other performance mods). So in that aspect I can't say anything bad about the K&N, but you will be better off with the TRD or AFE sealed intakes. :D
  8. Jan 7, 2009 at 2:45 PM
    tacoskim
    Los Angeles, CA
    Stock
    xrunnit i got a brand new never used before true flow filter for the k&n that i never put on that i can sell to u for cheap if u ever want an extra one
  9. Jan 7, 2009 at 5:40 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    +1000
    URD TCAI with a properly tuned MAF Cali, is got to be the best bang for your dollar. Look at all the designs, nothing different. All aftermarket filters will allow more air than stock. Main thing you want from a filter is how much dirt it actually keeps out of the motor. Thats why I originally went with True flowXDI. But some slight qwerks, ie dificulty of removing the filter element & cleaning the filter, and how rich it originally was making my truck run; has steered me to upgrade to the URD. URD Filter placement is awesome. Every other company draws air from the engine bay, if not for sound, you would be better off with a drop in filter in the stock set up. And True Flow makes those also.
    Long story short: you want HP, then you need the coolest ambient air possible.
    My Votes for URD:cool:
  10. Jan 7, 2009 at 6:03 PM
    carolinyens
    carolinyens Creedmoor Connections
    Durham, NC
    08 X-Runner
    TRD CAI, TRD SS, Toyota All Weather Mats, Eagle Eye Halos, NST Crankshaft Pulley, ScanGauge II, TRD Shiftball, TRD SeatCovers, WeatherTech Vent Visors, 20% tint, DTLT's and NST pulley combo.
    TRD CAI. not sure about how much of a difference is between this and the URD one. But the TRD one works. My Scan GaugeII says so ( lower underhood temps). So I would say between the TRD/AFE or URD. Depends on how much you wanna pay and how often you wanna clean it.
  11. Jan 7, 2009 at 11:43 PM
    dunkhi
    Craig Sirois
    09 Ivan Stewart
    if i do get an intake ill just get the trd
    so it works well if s/c later on.
    hmm thanks for the help
    but i think i decided that its worth it just to save up for trd cai and trd s/c someday that way no problem with warranty or trade in value someday.
    and i dont think 300 dollars is worth it for about 5hp.
    so i think ill just get my 3inch lift ; )
  12. Jan 8, 2009 at 4:47 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Interesting.. PM me with the details. I got to take care of some minor body work, as well save money for a couple track days coming up but if the price is right.
  13. Jan 8, 2009 at 4:51 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    This is very true. While cruising I am within 1-2* of ambient with the K&N open filter. The TRD/AFE intake would be about the same. So no difference in HP there. The only difference the placement will matter is when you are sitting still not moving. In that case I would want slightly warmer air. Warmer air is less dense, less dense means less air, and less air = more fuel efficient (though also less hp). When you are sitting still you don't need hp, even rolling slowly. By the time you get up and moving the air being pulled in by the K&N, TRD/AFE, or URD, will all be about the same.
