intake help
Discussion in 'Performance and Tuning' started by kris219, Dec 15, 2008.
  1. Dec 15, 2008 at 3:23 PM
    kris219
    kris219 [OP] Well-Known Member
    Kris
    miami
    tacoma trd
    spindle lift with dakar leaf pack, blacked out headlights and tailights, satoshi, debadged, HID headlights n fogs, flowmaster 40 single in dual out
    Ive been thinking about getting a cai for my truck but im not really sure where to start. how do u access the stock intake when its in the fender well. also im having a lot of trouble choosing a new cai. i live in miami and it rains a lot so im not sure about URD. i also dont wana empty my pocket either. any suggestions?
  2. Dec 15, 2008 at 3:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    honestly man...............with the expense what they are for all the cai's out there..........just remove the secondary filter and install a good drop in like the afe pro dry s................you'll have mileage gains, plus it costs alot less than a cai to do this. plus..............with a cai, you get the most benefits from it during higher rpm driving......you really want see any gains during normal driving.
  3. Dec 15, 2008 at 3:33 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    i was worried about the same thing but after talking to alot of people and the creator of the intake, youll be ok with rain. the only time the water will get in ur engine is if u go into a deeeep puddle.
  4. Dec 15, 2008 at 4:31 PM
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    i live in jacksonville, which is exposed to just as many hurricanes as miami, and i run the urd intake with a recessed grill. only issue i have is the maf getting soaked. which was fixed by sealing it with a sealer. the filter will get wet, and you might notice a little restriction, but as long as your not in a lake and flooring it, you wont have any problem with the rain and the filter.
  5. Dec 16, 2008 at 1:01 PM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Hey, how do you take out that secondary filter?
  6. Dec 16, 2008 at 1:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can basically just use a pocket knife and cut the 6 small rivet heads off, then pull the filter out...............just make sure no plastic shavings or anything is left loose in there.
  7. Dec 16, 2008 at 1:53 PM
    cole47
    cole47 Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    where is it located?
  8. Dec 16, 2008 at 1:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    open up tha air box and take out the drop in filter...........and its right there.
  9. Dec 16, 2008 at 1:56 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    gotcha...... thanks
  10. Dec 17, 2008 at 1:51 PM
    TacoTycoon
    TacoTycoon Well-Known Member
    Justin
    Hayes, VA
    07 TRD Sport 4WD Indigo Ink
    Bilstein 5100 Coilovers, Diff Drop Kit, TSB AAL, 285/70/17 BFG A/T Tires, 17X8 Helo HE835 Wheels, Rear Bilstein 5100s, Dual Flowmaster 50 series, TRD CAI, TRD Front Seat Covers, Rear Suspension TSB, 35% Tint, Redline Hood Struts, MagLite Mod
    yeah sometimes I wish I had just done the drop in route, but if your heart is set for an intake i say TRD or AFE (same intake, different logo) and Truefolow makes a good intake as well with great filtration...My trd gives me a thrill at the expense of mileage haha
  11. Dec 17, 2008 at 1:58 PM
    tacoskim
    Los Angeles, CA
    Stock
    the drop in route benefits the most on the 1st gen, the 2nd gen really doesnt benefit from the drop in
  12. Dec 18, 2008 at 7:16 AM
    TacoTycoon
    Justin
    Hayes, VA
    yeah, but from time to time I can feel the low end power loss because of the intake and wish I had just bought the trueflow because it has better filtration. But, don't get me wrong I do not regreat getting mine
  13. Dec 19, 2008 at 8:38 AM
    kris219
    Kris
    miami
    tacoma trd
    i dont mean to offend you but how do you know this?
  14. Dec 19, 2008 at 11:36 AM
    tacoskim
    Los Angeles, CA
    Stock
    from the "search" feature
