Intake Manifold Inside Coated in Gas/Oil!
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Mar 8, 2014.
  1. Mar 8, 2014 at 8:20 PM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    It was bad (no pics), but it was almost to the point of dripping out... :eek:
    PVC valve bad? I pulled it and it was pretty gunked up. I sprayed it down with some cleaner spray (inside and out) and replaced.
    Im hoping that was the issue but what are other symptoms I need to be aware of? Bad piston seals?
    Needless to say, catch can install has been bumped up in priority.
  2. Mar 9, 2014 at 5:04 AM
    jdkilroy
    jdkilroy Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    I think the catch can will help reduce that problem a fair bit although even with the can , I have seen the intakes fouled but to a lesser degree. Usually an uneven distribution of deposit in the different cylinder's intakes which I've always found odd.
    Anyone I know who has a can installed (between PCV valve and intake manifold) has been amazed at how much oil they collect. I made one using a air compressor water trap. I wanted to be able to see how much oil was in there so would know when to empty.
  3. Mar 9, 2014 at 5:40 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Using a air comp. water trap is a great idea! You should do a "mod" thread.
  4. Mar 9, 2014 at 5:44 AM
    jdkilroy
    Jon
    Southern NH
    I get a pic and post, that should pretty well explain it.
  5. Mar 9, 2014 at 6:48 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Im doing an oil catch can that vents to the atmosphere and plugging up the valve on the TB so I dont have to worry about that anymore.
    However, while Im pretty certain it was caused by a bad PVC valve, it was A LOT and Im concerned it wasnt just the PVC valve. Just wondering if anyone else had this happen :notsure:. I hope the cylinder seals are good...
  6. Mar 9, 2014 at 6:55 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Damn, was it smoking blue out the tail pipe??
  7. Mar 9, 2014 at 6:57 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    No :notsure:...
  8. Mar 9, 2014 at 11:31 AM
    jdkilroy
    Jon
    Southern NH
    Pretty sure that you will get codes and fail emissions if you don't keep that vacuum circuit intact. Not sure how strict they are in VA.
    The catch can will get most of it and these engines run 300+ K miles without any modification at all so pretty sure you'll be fine with getting most of that oil out.
  9. Mar 9, 2014 at 5:51 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    It shouldnt do either :notsure:. I havent made up my mind yet how Im going to configure it. I still need a custom plate made to hold the catch can (and fuse box).
  10. Mar 9, 2014 at 6:30 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
  11. Mar 10, 2014 at 8:22 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  12. Mar 11, 2014 at 6:46 PM
    trdtoy
    trdtoy Well-Known Member
    North Carolina
    02 sr5 4x4 auto v6 turbo (sold)
    Turbo with supporting mods and tranny to hold power.
    Do you have restricter on oil feed side of turbo and large drain from turbo? Do you know turbo seals are good? I blew seals out of two brand new name brand turbos before I realized that restricter was not in the feed to turbo. If oil is blowing past turbo seals oil may be in compresor discharge side, turbine side, or both. If no oil in turbo should start looking at line routing to ensure it is correct. Also run lines to catch can and monotor how much oil getting through. This will indicate if you need to dig deeper.....
  13. Mar 11, 2014 at 7:01 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    :confused: No turbo installed yet...
  14. Mar 11, 2014 at 9:06 PM
    trdtoy
    North Carolina
    Oh ok sorry. Narrows that down then! Get that catch can installed and see what ya get in it. Also monitor the inside of your intake mani/plenum to see if or how fast it gets dirty again since you cleaned it. if it gets dirty fast and/or collects a lot of oil in can there may be other issues. How much is too much?..... That is the question.....
  15. Mar 12, 2014 at 12:44 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    If your Cats haven't plugged yet and no major codes are being thrown and you aren't noticing it burning oil.
    its probably not rings.
    That said..
    depending on how much boost your wanting to run, and granted right now you haven't experiance boost so you don't have the boost bug so you're probably thinking "5-7psi is enough, i won't go any higher.." well that a lie :D haha so if you even THINK you'll be running more boost then that...pull the block and open it up and check the rings your self.
    welcome to boosting :eek:
  16. Mar 12, 2014 at 6:27 AM
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    A bad PVC would definitely do that.
    A compression and Leak down test on rings if you suspect those. Engine stays assembled.
    Compression test is blunt numbers and a good quick check, but a leak down test will tell you the percentage that gets past the rings, or valve seats.
  17. Mar 12, 2014 at 7:24 AM
    BamaToy1997
    Bill
    Navarre, FL
    You will most likely (Though I won't say 100% guarantee) result in a lean/rich code if you do that. The computer has pre-calculated in the amount of air mass drawn through the PCV valve into the intake. If this amount of air is missing, then the computer will set a fault, resulting in a rich code, because the amount of air entering is less than the amount of air that SHOULD be entering the engine. Since you will be boosting, the best thing to do is install a small check valve in the line between the vacuum port, and the catch can. Something similar to the check valve in your brake booster line would be the right size and pressure most likely.
  18. Mar 12, 2014 at 7:39 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Haha, I keep telling myself that... :D Thanks for the reasurance. I baby the engine so wasnt too concerned but damn that was a lot of oil :eek: Working the catch can/fuse box bracket today and hopufully finnish wiring.
    Good call. Probably do that this weekend just to be sure. Thanks!
  19. Mar 12, 2014 at 1:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Or get forged internals and go crazy!!! :D
    do it do it do it do it do it do it do it do it...:D
  20. Mar 12, 2014 at 4:23 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I should be able to clamp/adjust what my ECU sees with the FIC and tune off the FIC's MAP sensor... Ill try the vent first and can easily add the hose if the FIC doesnt cut it. Ill have to find a check valve if I plan to keep the hose when in boost...
    pay for it pay for it pay for it pay for it pay for it pay for it pay for it pay for it :D
