Intake Manifold Spacer 4.0l Coming!
Discussion in 'Performance and Tuning' started by highaltitude, Feb 6, 2012.
  1. Feb 20, 2012 at 8:27 PM
    #241
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    I think your missing the point of the spacer. Long runner intakes are better for low rpm tq. The spacer would lengthen the intake runners. Short runner intakes are better for higher rpm hp numbers.
    This spacer is more for tq, than for hp's.
  2. Feb 20, 2012 at 8:54 PM
    #242
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Ugh still no spacer!! I need MOAR HP!! Well not really but I'm really interested to see the results of R&D
  3. Feb 21, 2012 at 6:42 AM
    #243
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Correct.
    That is also one thing that nearly 75%+ of the member here talk about. Low end TQ. So apparently that is what they are most interested in. Upon a second dyno from me, and some from the OP, we should have congruent data.
  4. Feb 21, 2012 at 12:18 PM
    #244
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    What I think is funny is that they focus on the HP when torque is what you want.:goingcrazy:
  5. Feb 21, 2012 at 12:26 PM
    #245
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Exactly! HP does burnouts, torque gets that big ass trailer moving on a steep incline :thumbsup:
  6. Feb 21, 2012 at 12:28 PM
    #246
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Torque does burnouts...
  7. Feb 21, 2012 at 12:30 PM
    #247
    Pugga
    Massachusetts
    Now you listen here, NumNutz :p
  8. Feb 21, 2012 at 12:36 PM
    #248
    NumNutz
    Virginia Beach, VA
    Lots.
    TORQUE!!!!
  9. Feb 21, 2012 at 12:52 PM
    #249
    NumNutz
    Virginia Beach, VA
    Lots.
    Hahahaha:anonymous:
  10. Feb 21, 2012 at 2:02 PM
    #250
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lmmfao!!!!
  11. Feb 21, 2012 at 2:03 PM
    #251
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MOAR SMOKE!!!!!!!
    Sick pic man! Bad ass!
  12. Feb 21, 2012 at 2:09 PM
    #252
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    you're missing my point. I was aiming to the fact that, toyota designed their intake to be as effecient as possible as far as gaining hp/tq. if adding a little gap between the intake and the block would help, they obviously would have done it. but they likely tested various intake lengths and the one they came up with worked. Nissan, on the other hand, may have missed this oppertunity.
    but then again, the dyno's vairy
  13. Feb 21, 2012 at 2:10 PM
    #253
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Not if it cost them more money, hence engineer vs business.
  14. Feb 21, 2012 at 4:00 PM
    #254
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    In this world of modern auto engineers, CAFE standards are king. If, as mentioned, the 1/2" spacer made that big of a difference, Toyota would have used it, or made the runners longer. They spend shit loads of money as it is, designing these engines, whats another couple bucks? After all, more efficiency the better. The stock torque curve is among the flattest out there for a V6 engine. Some V8's dont have the curve of the 1GR. BUT....STILL waiting on a decent dyno comparo. Dont get me wrong, I'd love to see more HP unlocked from the engine. But given the dyno already posted up, it really doesnt look like much to be had. As for the "Gain" at the beginning of the run, Its very rare that you see the dyno curve follow the same lines as the one before it, at the beginning of a run. After the first 500 to 1000 rpm of the run, are when the dyno can accuratly record any gains.
  15. Feb 21, 2012 at 4:03 PM
    #255
    Front sight
    SW Florida
    Get real. Toyota is not the be all, end all of automobile engineering. I'm sure Toyota tested various frame's on the 1st gen Tacoma's and went with the one that worked best. Just like Toyota designed the rear leaf springs to hold the advertised weight in the 2nd gen Tacomas without riding on the frame rails. It's been an issue since 05, and there are STILL 2012's rolling off the lot with the same weak 3 leaf spring set up.
    There is always a trade off for the manufacture. Cost, emmisions, part availability, will the best part fit, etc. To think that Toyota equipped the Tacoma with the best intake with the perfect runner length, the best exhaust manifolds, the best stereo or anything else is foolish.
    Over all I think the Tacoma is a great package, but I think there is room for improvment from the owner.
  16. Feb 21, 2012 at 4:10 PM
    #256
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Leaf spring rates are dictated by the "95%" who buy the vehicle. If they want a truck to ride like a car, guess what they get? Engines and efficiency have to meet governmental regulations, as well as be able to make as much power as they can to apease the consumer.
  17. Feb 21, 2012 at 4:19 PM
    #257
    Front sight
    SW Florida
    I hear what your saying. But there is still some power that can be squeezed out of this moter. I'm not expecting huge gains to be had from the spacer, but I do think that a gain can be had.
  18. Feb 21, 2012 at 4:34 PM
    #258
    Front sight
    SW Florida
    Chris, are you saying that there are no gains to be had then with the 4.0l? That the 4.0 makes as much power and is as efficient as it can get?
  19. Feb 21, 2012 at 4:39 PM
    #259
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nope. Just sayin its not as easy as alot of people think. Gone are the days when an intake, and exhaust give 25 to 35 hp. Now, most good exhausts get a net gain of about 5 hp. If that. 15 years ago, a header, full exhaust, and decent intake could give 50 hp, or so. Now, the same mods "might" give 15 to 20, if that. Now that manufactures have the capacity to accurately time the pulses in the intake/exhaust, simple spacers dont have the impact as they once did.
  20. Feb 21, 2012 at 4:41 PM
    #260
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If Toyota is anything like Nissan, why didn't Nissan add the spacer to their VQ motors?
    Why didn't Subaru add a phenolic spacer to its motor, like the aftermarket companies do?
    Why did Toyota make a lower oil pan on PreRunner and Xrunner that has the sump, in the highest part of the oil pan, is prone to causing bearing oil starvation, retains a half quart of old oil when you drain it and is in a lower section that is away from the sump, and could have been a half inch to one inch thicker to prevent such issues?
    I don't know.....They surely noticed that though. I did, and that is why Coupe now makes an oil pan spacer and Oil Pan to alleviate that dumb engineering oversight. :D
    Toyota did the same thing with the Scion tC's oil pan as well. Excellent design for rod knock. Lol.
    If Toyota doesn't care about it enough, they put what works. Not the best of what works, but what works. Unfortunate as that is.
