Intake Manifold Spacer 4.0l Coming!
Discussion in 'Performance and Tuning' started by highaltitude, Feb 6, 2012.
  1. Feb 21, 2012 at 4:44 PM
    #261
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No idea why Nissan didnt do that, if the posted gains are accurate. The spacer surely doesnt have that kinda impact on the Toyota motors, does it? No idea about the Subi'es, and the oil starvation issue isnt on every truck. Seems to only be on a few.
  2. Feb 21, 2012 at 4:47 PM
    #262
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Following the same thing in the case of the tacoma 05-08 had a log style header, 09 to current have a shortie style header. Toyota took noticed and improved rather than leave it the same. Because they will be using it for a WHILE. Had they followed your logic chris4x4 they would have done that from the start. Look at 2003 when the 4th gen 4runner came out it also had the log style header up to 2009 when the 5th gen was introduced. They improved on the design as there was lots of room for improvement. Same case for the lower intake manifold. Staying with tacoma 05-08 it has a lip from the casting process where the plastic intake manifold sits. 09 to current that is machined out now.
  3. Feb 21, 2012 at 4:51 PM
    #263
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    Ok, we're on the same page then. I agree with you on that you don't get the quick gains of the "good old days" with simple bolt-ons. But as good as the manufactures are, their hands are still tied with noise and emmisions and cost-penny pinchers. Power can still be had, but it costs more to find it for sure.
  4. Feb 21, 2012 at 4:54 PM
    #264
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The oil pan issue is only in high potential for those that have the shallow lower oil pan. All Xrunners have that one. Some PreRunner have it as well, while others have the 4x4 deep lower oil pan. For those with the shallow oil pan, we learned after some testing that it is inthe best interest if that vehicle owner to make sure to fill the oil to the top dot on the oil stick. Usually right at 5 quarts depending on size of oil filter. Not what the factory recommends.
    I am not sure why they would swap between the two either. I can post pics of the difference. Probably best in another thread though.
  5. Feb 21, 2012 at 4:54 PM
    #265
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That's all I'm saying. Shirley powers there to be had, it's just gonna be a lot harder to find it.
  6. Feb 21, 2012 at 4:55 PM
    #266
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Quoted for truth. :)
  7. Feb 21, 2012 at 5:11 PM
    #267
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    You have nothing to add to this conversation... :p
  8. Feb 21, 2012 at 5:25 PM
    #268
    memario1214
    Colton
    Missoula, MT
    Dyno sheets and then pass your judgment... That's what I am doing. Arguing over the topic is irrelevant until there is something concrete to argue over IMO. I'm willing to give the OP a fair shot at my money and a :thumbsup: for trying even if it doesn't produce the results that he/we hoped that it would.
  9. Feb 21, 2012 at 5:48 PM
    #269
    acdronin
    acdronin Well-Known Member
    Shirley you jest!
  10. Feb 21, 2012 at 5:50 PM
    #270
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, that was my phones fault. Evidently, when I say "Surely", it thinks I mean the girls name.....
  11. Feb 21, 2012 at 5:51 PM
    #271
    acdronin
    Aw, ya missed the movie line Chris!
  12. Feb 21, 2012 at 5:52 PM
    #272
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    i did :eek: sorry
  13. Feb 21, 2012 at 5:52 PM
    #273
    memario1214
    Colton
    Missoula, MT
    Okay Mr. Magoo.. :rolleyes:
  14. Feb 21, 2012 at 5:53 PM
    #274
    acdronin
    "no I'm not kidding and stop calling me Shirley"
  15. Feb 21, 2012 at 5:53 PM
    #275
    Lucario Runner
    Robert
    06 Toyota 4Runner
  16. Feb 21, 2012 at 5:55 PM
    #276
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    Back on topic... maybe for at least the next couple responses anyway.
    How many different Tacomas has this thing been tested on? Are there any pictures of the prototype(s)?
    How did this spacer affect intake/engine sound? and did the test mule driver(s) notice any changes via butt dyno?
  17. Feb 21, 2012 at 5:57 PM
    #277
    Lucario Runner
    Robert
    06 Toyota 4Runner
    http://www.xr-underground.com/forum/showthread.php?t=39808
  18. Feb 21, 2012 at 6:24 PM
    #278
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Look on the first page bro. Mine was the first prototype for the 1GR engine. NST sell them now. As well as the possibly the OP. :thumbsup:
  19. Feb 21, 2012 at 6:37 PM
    #279
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    So I can just hook up NOS and get one good 20 ft run out of my 2.7 is what I should be walking away from this thread with right?
  20. Feb 21, 2012 at 6:41 PM
    #280
    Bobber Bill
    Los Angeles, CA
    I'm well aware of the NST spacer and what people think of it. Unfortunately, I'm also aware of their price. I emailed them months ago inquiring about their spacer and haven't gotten any response.
    Wasn't this thread started to follow the progress of another manifold spacer?
    Maybe I missed something, but I thought there was some guy looking to produce his own manifold spacer for the 1GR at a more realistic price.
