Intake Manifold Spacer 4.0l Coming!
Discussion in 'Performance and Tuning' started by highaltitude, Feb 6, 2012.
  1. Feb 21, 2012 at 8:42 PM
    #301
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    I've been following this on/off since the beginning as I have been interested in a manifold spacer for quite some time now. In fact I've looked into producing my own variant of one, specifically out of a thermo-polymer. My reasons for the polymer were not to reduce costs, but to minimize added mass and reduce/insulate intake temps.
    However seeing as the majority of the manifold is already plastic along with the significantly higher manufacturing time/costs associated with the polymer, I gave it up. It is much easier, faster and cheaper to machine these out of aluminum - not only in short run production sense, but also in R&D/prototyping. Can you imagine how much it would cost and how long it would take to have to produce new molds/tooling each time a revision is necessary.
    You can also machine them from the polymer, but that is not cost effective in a short run either. I guarantee you that NST has looked into producing theirs out of a "plastic" material, but found that billet aluminum is the easiest and most profitable considering their needs and capabilities.
    All I wanted to do was inquire as to the progress of OP's development of his own spacer. I don't need anyone to school me on what a manifold spacer does or how it does it. So you might have a little harder time talking down to me. But I'm happy that you guys are so knowledgeable in race engine technology, or that you spent a lot of time googling this shit.
    Also, I'm pretty sure I can have these machined out of T6-6061 for under $70 a pop. That's including materials, a couple of prototypes and the CAD work(should any revisions be necessary). All made 100% in the USA!
    OP, I look forward to your dyno sheets. Good Luck and don't forget that you'll have to find some way of securing the upper plenum once it's shifted up by the spacer
  2. Feb 21, 2012 at 9:38 PM
    #302
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Now that post is a good post. :)
    I like a good debate always. I also like to keep a pleasant demeanor when conversationing/debating. Too many times though, to many people put forth an unecessarily forward disposition. Then in turn it make my responses harder to remain polite.
    I apologize for my rather unbecoming disposition.
  3. Feb 22, 2012 at 11:58 AM
    #303
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    People get butt hurt too much, too quickly on this forum.
  4. Feb 22, 2012 at 12:07 PM
    #304
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I dont think anyone has gotten their butts hurt in this thread. Just back and forth banter, discussing weather or not this will work.
  5. Feb 22, 2012 at 3:16 PM
    #305
    acdronin
    acdronin Well-Known Member
    Compared to the other threads? Ha! this has been serene like a sewing circle
  6. Feb 22, 2012 at 4:37 PM
    #306
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lmao. That's hilarious!
  7. Feb 22, 2012 at 4:46 PM
    #307
    highaltitude
    highaltitude [OP] Well-Known Member
    Asheville, NC
    2017 ZR2
    hmm, I wont touch that one, sounds too personal, I dont want nothing to do with someone's hurt butt, LOL
  8. Feb 23, 2012 at 5:21 PM
    #308
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Already done, I have a lower stock manifold coming to mate with a head and do some flowbencing, with the rough casting run out in the ports I think the velocities will be off, I.e. too many deflections in the boundary layer. I have a buddy at extrude hone that can fix that and see if I can get better lam and still keep it around .5 mach in the tract
  9. Feb 23, 2012 at 5:23 PM
    #309
    SoCaltaco65
    Chris I'm butthurt....I mean....errrrruuuum....ya
  10. Feb 23, 2012 at 5:27 PM
    #310
    SoCaltaco65
    Butt you do drive a Nissan....
  11. Feb 24, 2012 at 5:02 AM
    #311
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Lemme guess... just did your taxes? :rolleyes:
  12. Feb 24, 2012 at 5:49 AM
    #312
    Zoot
    Zoot Well-Known Member
    2011 DC/SB TRD O/R 4X4
    Toyota bed mat, Wet Okole's F&R, Window Tint, custom trail-stripes, Cooper A/T3 265/75R16, MedlinAround interior LEDs, Leer 100r, aFe air filter, K&n cabin filter
    Subscribed for results
  13. Feb 24, 2012 at 7:05 AM
    #313
    SoCaltaco65
    yes I did....
  14. Feb 24, 2012 at 10:12 AM
    #314
    highaltitude
    Asheville, NC
    2017 ZR2
    Just filling up gas can make you feel that way too. Feel violated:(
  15. Feb 24, 2012 at 10:16 AM
    #315
    Alby9999
    Alby9999 Well-Known Member
    Alby
    NNJ
    07 AC TRD OR Impulse Red
    TRD Cat back exhaust 3" FR lift-AAL CAI-Ram air D rings Tail gate theft mod 4x4 illumination switch mod Redline hood struts Fogs on any time mod diff breather relocation mod 886 reverse light mod Wet Okole Avid weld on sliders LR UCAs Locker mod 115 in cab outlet 400w anytime
    Too funny. I had an 87. No engine issues and 237,000 on original clutch. Also the stock rims were chrome and where in great shape when I finally sold the truck in 2007.
  16. Feb 24, 2012 at 10:34 AM
    #316
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    88 toy pick up....rear end is about to explode....original gears/third member...385,xxx miles :spy:
  17. Feb 25, 2012 at 8:41 AM
    #317
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
  18. Feb 25, 2012 at 8:46 AM
    #318
    Pugga
    Massachusetts
    Making the relationship between the Nissan Sentra engine and the Tacoma engine is ridiculous. They're completely different, 4cyl vs. 6cyl, truck vs. a car and different manufacturers. The manifold spacers might work with certain vehicles but if the manufacturer did their homework on the low end of the engine, they might not work on others.
    Not to mention, you're a little late to the party. The OP has made a prototype and is dyno testing on the 4.0L engine to prove results (or lack thereof). You can have your $0.02 but these aren't blind claims, they're going to be backed up by dyno results.
  19. Feb 25, 2012 at 8:55 AM
    #319
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Peak HP numbers mean nothing. It's all about the curve of the power. A motor can lose 2 peak HP, but still gain throughout the rest of the curve. Longer runners will give you more torque. Anyone looking for peak HP on a 6 cylinder truck is crazy unless you drive at 5k+ rpm all the time. In my drag racing days, I gladly gave up some high end HP for more low end torque to get my heavy car moving. Always ran faster than the guys with more HP.
    I'm not saying this will work - but we should be concerned with torque numbers across the curve, and not peak HP numbers.
  20. Feb 26, 2012 at 11:19 AM
    #320
    Pugga
    Massachusetts
    So when is this next round of dynos supposed to happen?
    :popcorn:
