Intake Manifold Spacer 4.0l Coming!
Discussion in 'Performance and Tuning' started by highaltitude, Feb 6, 2012.
  1. Feb 26, 2012 at 11:24 AM
    #321
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Sweet! Let us know how it turns out :thumbsup:
  2. Feb 27, 2012 at 10:10 AM
    #322
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I need to get to PowerFab and do some on mine.
    I had been up there three times during the past week, and forgot every time to get a print out of all of the 4Runner pulls we did. My apologies.
    My truck is up and running, to full N/A potential again. Stock flywheel, stock crank pulley, Tacoma intake cam gears(WOOT!), T56 transmission (WOOT WOOT!), and stock headers/Y-pipe. No catback.
    I will see if I can get in there sometime later this week, as well as getting the dyno graphs from the 4Runner, through email.
  3. Feb 27, 2012 at 11:06 AM
    #323
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have an appointment for next Saturday at PowerFab for the dyno.
  4. Feb 27, 2012 at 4:53 PM
    #324
    Pugga
    Massachusetts
    :woot:
  5. Feb 27, 2012 at 10:34 PM
    #325
    willimatic
    willimatic Well-Known Member
    Will
    Rancho Murieta/Folsom, CA
    06 Tacoma AC 4x4 Sport
  6. Feb 28, 2012 at 3:11 AM
    #326
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    OP cool product....any chance you'll offer it in a polymer material to minimize heat soak?
  7. Feb 28, 2012 at 5:31 AM
    #327
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    The manifold is plastic. The material of the spacer won't make any difference with heat soak.
  8. Feb 28, 2012 at 3:50 PM
    #328
    S7ICKlVlAN
    Dave
    Hawaii
    2012 TRD Sport DCSB
    How would a hot piece of aluminum sitting in the middle of our polymer intake manifolds not get heat soaked? Given, the difference in power, while likely negligible, takes away from the goal of adding the spacer. Just sayin....
  9. Feb 28, 2012 at 5:00 PM
    #329
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lucario and I both have the email that has all of the dyno runs, on his 4Runner.
    However, they are a "DRF" files, and neither of us have the ability to open them. :/
    PM me if anybody has the ability to open that specific file type.
  10. Feb 28, 2012 at 5:35 PM
    #330
    MadToy
    Nick
    Huntersville, NC
    It's not in the middle of the polymer intake. It sits on top of the cast aluminum lower intake manifold, so it's no different than if the lower intake manifold was 1/2" higher. If the upper manifold was aluminum, then a composite or phenolic spacer *might* help (not really, but for argument sake we'll say it might). Reality is heat soak is caused more by the heat rising through the intake ports and into the manifold when the engine is shut off. Heat transfer from the block is not the sole cause of the soak (or the primary cause).
  11. Feb 28, 2012 at 5:42 PM
    #331
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I can fine tune my truck on Xtune but I can't open a drf file. Sometimes I hate computers....
  12. Feb 28, 2012 at 5:47 PM
    #332
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That file wouldn't open it either.
  13. Feb 28, 2012 at 5:47 PM
    #333
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Haha. Ironic isn't it? :rolleyes:
  14. Feb 29, 2012 at 4:02 AM
    #334
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    It looks like a program called DynoJet could have created the DRF files.
    From Fileinfo.com:
    I found this link with some software downloads, but don't know if you have to pay anything to view the files:
    http://www.dynojet.com/downloads/software.aspx
    Hope this helps.
  15. Feb 29, 2012 at 4:26 AM
    #335
    gtec913
    gtec913 Well-Known Member
    glenn
    cali
  16. Feb 29, 2012 at 8:16 AM
    #336
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yeah. Appreciate the help. I had found some other websites that said they could open those files, besides the DynoJet website. They were asking for a fee for the software. That is why I figured I woukd post up on here first to see if by chance someone already had a program that was capable. Figured I would do that before checking the DynoJet site. Looks like i will have to. Sigh.....
  17. Feb 29, 2012 at 8:56 AM
    #337
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Free download of winpep software. Winpep will run .drf files
  18. Feb 29, 2012 at 1:16 PM
    #338
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Thanks for the download link, I'll get on that when I get off school later today.
  19. Mar 8, 2012 at 9:53 AM
    #339
    Pugga
    Massachusetts
    So... what happened with this? Any dyno runs on a stock 6 speed yet? Inquiring minds want to know!
  20. Mar 8, 2012 at 10:02 AM
    #340
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I hope the OP has something. I was scheduled for a dyno this weekend. Had to cancel though. Due to the recent finding of the block leaking oil at the rear oil port, on the passenger side. High rpm makes it leak faster. So, not taking the chance of making it worse. Getting parts to repair it next weekend though.
