Intake Manifold Spacer 4.0l Coming!
Discussion in 'Performance and Tuning' started by highaltitude, Feb 6, 2012.
  1. Apr 4, 2012 at 10:01 AM
    #361
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Wait what?
  2. Apr 4, 2012 at 10:52 AM
    #362
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Wait? Where.....?
  3. Apr 4, 2012 at 12:48 PM
    #363
    memario1214
    Colton
    Missoula, MT
    Ditching your setup?
  4. Apr 4, 2012 at 1:16 PM
    #364
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Oh no. That was just a joke.
  5. Apr 4, 2012 at 6:47 PM
    #365
    chriss
    chriss Well-Known Member
    chris
    While we wait, could someone point to ANY "proof" or "data" that shows an improvement by adding one of these spacers to a stock engine? Any engine. I searched a little and found nothing.
  6. Apr 4, 2012 at 6:49 PM
    #366
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Different engines arent a good source of weather or not a gain can be had by a certain mod. Differenct engines are timed/tuned/fueld differently than others.
  7. Apr 4, 2012 at 7:14 PM
    #367
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  8. Apr 4, 2012 at 9:10 PM
    #368
    chriss
    chris
    Yes, other engines are a good source of information. And, they're very similiar but not the same.
    Not to be a stickler, but plenum spacers and intake runner spacers are two different things.
    The site does show dynagraphs with moderate gains at high rpm. Though the 2 different graphs have different results.
  9. Apr 5, 2012 at 4:56 AM
    #369
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Engines engineered, designed a built by different manufacturers are NOT a good source of information for performance mods, especially one like this. Read back to the first couple pages and a few pages back where they dyno'd an automatic Tacoma. The Nissans show much larger gains while the Tacoma showed very, very minor gains. Different engines can not be used as a source of information, what works on one, might not work on the other.
  10. Apr 5, 2012 at 7:22 AM
    #370
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Weeeellll......if you go by the names of the Tacoma intake, you have the: upper plenum (plastic) and lower plenum(aluminum, which bolts to the heads). So technically it is still a plenum spacer. ;)
  11. Apr 5, 2012 at 7:23 AM
    #371
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Nope. More. :cool: lol
  12. Apr 5, 2012 at 7:33 AM
    #372
    highaltitude
    highaltitude [OP] Well-Known Member
    Asheville, NC
    2017 ZR2
    http://extremetruckperformance.com/?page_id=37 This is the spacer on a 2005 4.0 V6 Nissan Frontier (same engine 2005-2012) he wasnt stock, but doing a before and after dyno shows a gain regardless.
  13. Apr 5, 2012 at 8:44 AM
    #373
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Like mentioned above, the Toyota V6 doesnt seem to show the same gains. The dyno of the Tacoma with the auto tranny showed minimal gains. More than likely within the margin of error of the dyno.
  14. Apr 5, 2012 at 8:55 AM
    #374
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Quite possibly very true.
    Gives me an idea though. I might very well be able to get my ex to let me try it out on her truck. Since she has a manual. Not going to hold my breath on that one though.
  15. Apr 5, 2012 at 8:57 AM
    #375
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im not holding my breath on anything here. Dyno's were supposed to be a couple weeks from the first post, and here it is 2 months later.
  16. Apr 5, 2012 at 9:00 AM
    #376
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lol. No "quite" about that one. Very true.
    I am getting on the dyno today......but not for the purpose of this test. Just to go over my tune since an exhaust leak was found. Dang turbo, is always messing up my N/A plans... ;)
  17. Apr 5, 2012 at 9:15 PM
    #377
    chriss
    chris
    To be honest I was hoping you would point to this. The link has a graph that states the red lines are the before and implies the other lines are after.
    http://extremetruckperformance.com/wp-content/uploads/2010/10/IMS-dyno-sheet.jpg
    Look up this formula hp=tq*rpm/5252. This is why hp=tq at 5252 rpm. If this is not constant across the graph then the drive ratio is not 1:1. Meaning the results are skewed. This is not necessarily bad. The number can be used in comparison, however not a direct comparison. Similar does not mean same.
    Back to graph. Look at the anomalies. There are some points were hp is increasing and rpm is decreasing or stays the same. Transmission shift points one might think. Though the 2 "after" curves are not similar (same?). What would constitute the change in those 2 curves? Why more power on subsequent runs?
    The other graph on the link claims to show air/fuel ratios before and after. Why would they have changed? No programming changes were made. The MAF sensor or exhaust sensors were not changed, were they?
    I need more.
  18. Apr 5, 2012 at 9:21 PM
    #378
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    FYI the vehicle was a 4Runner.
  19. Apr 6, 2012 at 9:24 AM
    #379
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is right. I can't believe that I had forgotten that we did do the dyno by the date which was set.
  20. Apr 18, 2012 at 6:29 AM
    #380
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    :tumbleweed:
    Damn I love extrude honing....
