Intake Manifold Spacer 4.0l Coming!
Discussion in 'Performance and Tuning' started by highaltitude, Feb 6, 2012.
  1. Apr 25, 2013 at 6:14 AM
    #521
    yfz-rocks
    yfz-rocks Member
    06 DC/LB Sport 4X4
    6in Fabtech lift w/ dirt logic coils,295/70-17 Super Swamper M-16 tires, 17x9Fuel Boost Blk wheels. Thorley long tubes, Pipe bomb y-pipe, Magnaflow cat back, Afe stage 2 intake, Urd maf &o2 sim
    Thank you sir. It's on my to do list just need to free up the funds
  2. Apr 25, 2013 at 7:58 AM
    #522
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Ant dyno info yet
  3. Apr 25, 2013 at 8:38 AM
    #523
    Aw9d
    Aw9d That one guy
    Hey OP about how many more people do you need on board to get these going?
  4. Apr 25, 2013 at 9:10 AM
    #524
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    As soon as I free up some funds I want to add myself to the list.
    And if OP has some dyno time I'd be happy to try to get down there for him to run before and afters.
  5. Apr 25, 2013 at 9:37 AM
    #525
    highaltitude
    highaltitude [OP] Well-Known Member
    Asheville, NC
    2017 ZR2
  6. Apr 25, 2013 at 9:37 AM
    #526
    highaltitude
    Asheville, NC
    2017 ZR2
    Another 6 and then it's go time!
  7. Apr 25, 2013 at 10:26 AM
    #527
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    That was the dyno run you guys made with the automatic right? Either way, I have no doubt this will help add HP&TQ at 1000-3000rpm.
    And can you link the group-buy? This thread is like a book and I didn't see the link/info.
  8. Apr 25, 2013 at 10:49 AM
    #528
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That was on Grumpy's Xrunner. Not sure why they decided to start at 3k?
    I also did a dyno with Lucario Runner's T4R, which is in this thread.
  9. Apr 25, 2013 at 10:58 AM
    #529
    YOTA LOVER
    NH
    How is the group buy being coordinated?
  10. Apr 25, 2013 at 12:06 PM
    #530
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Click on the link, send the funds, when we hit 10 he sends them off to get CNCed and then he ships them to your door.
  11. Apr 25, 2013 at 12:08 PM
    #531
    highaltitude
    Asheville, NC
    2017 ZR2
    You can go to this link and use the Toyota group buy button to purchase. Make sure to select the USA button or the Canada button depending on where you live. It is convenient for me if you put in your forum name, and vehicles so I know whether it is a purchase for Toyota or Nissan as I sell a lot of Nissan spacers. http://extremetruckperformance.com/?page_id=300
  12. Apr 27, 2013 at 10:09 AM
    #532
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
  13. Apr 28, 2013 at 1:41 AM
    #533
    WailuaTaco808
    WailuaTaco808 A.L.O.H.A. Member
    Phil
    Hawaiian Islands
    2010 Tacoma TRD SPORT Kauai Built
    Oh boy...
    by the 22nd of may ill be making my order. just have to wait for the funds.
  14. Apr 28, 2013 at 2:05 AM
    #534
    Raddbus
    Raddbus Well-Known Member
    Russell
    Santa Maria
    TRUE BLU TACO
    Illuminated 4X4 switch, 3" lift,
    I'm not a mechanic but if I can take something off, I can put it back on. Done a few repairs myself like brakes, water pump, alternators, starters, installed my 3" lift, lowered many cars back in the day and I was wondering how easy would this be for a DYS? Is there any tweaking needed after it is installed?
  15. Apr 28, 2013 at 6:19 AM
    #535
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This is a fairly straight forward DIY project, nothing special about the install. It's just a spacer block that goes under the intake plenum to expand the volume of that plenum. I would unhook the battery for 20 minutes after the install to make the computer 'relearn' the changes you've made but other than that, it's not hard.
  16. Apr 28, 2013 at 7:40 AM
    #536
    highaltitude
    Asheville, NC
    2017 ZR2
    This is easier than most of the things you just listed. No tweaking necessary. I recommend disconnecting the battery to reset the Ecu, so that it can relearn the new hardware, but it is really a bolt on a go mod.
  17. Apr 28, 2013 at 4:20 PM
    #537
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    when nst made this it came with all the appropriate hardware...like 3 taller plenum brackets and longer studs for the lower manifold and longer SS bolts/washers, gasket
    does this kit include everything to make it work?
  18. Apr 28, 2013 at 4:46 PM
    #538
    highaltitude
    Asheville, NC
    2017 ZR2
    When we installed this spacer on the test truck, Im not sure we did much with the brackets at the time. Im thinking the holes in the existing brakets could be elongated , then moved slightly and reused. I think what we did was loosen them, slightly turned them, then reinstalled the bolt "clamping" the top of the bracket rather than going through it. Nothing moved in 1.5 months of driving it like this, including offroading. We replaced the plenum bolts with longer ones and a gasket. Never needed longer studs for anything.
  19. Apr 28, 2013 at 7:17 PM
    #539
    Raddbus
    Russell
    Santa Maria
    TRUE BLU TACO
    I'm outta the country right now, returning May 23. I'm interested in getting in on the Group buy.
  20. Apr 28, 2013 at 7:19 PM
    #540
    Raddbus
    Russell
    Santa Maria
    TRUE BLU TACO
    And Thank You Pugga & highaltitude for the info.
