Intake Manifold Spacer 4.0l Coming!
Discussion in 'Performance and Tuning' started by highaltitude, Feb 6, 2012.
  1. Jul 6, 2013 at 12:48 PM
    #1021
    WailuaTaco808
    WailuaTaco808 A.L.O.H.A. Member
    Phil
    Hawaiian Islands
    2010 Tacoma TRD SPORT Kauai Built
    Oh boy...
    I do have a question. So in the install i wasn't able to put the screws in to hold the intake manifold to the block. dont know if anyone else had that happen. and if anyone else is getting a buzz in the engine. i figure its kuz the mounts are tapping at certain rpms making a buzz i dunno. Just curious i kinda like the sounnd (made my throttle body whistle louder :p almost sounds like a diesel) .
    or if the noise was comming from my stupid 13mm socket that i lost in the engine bay.... its still in there i guarantee it.
  2. Jul 6, 2013 at 1:02 PM
    #1022
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Uhhhh...
  3. Jul 6, 2013 at 1:03 PM
    #1023
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
  4. Jul 6, 2013 at 1:14 PM
    #1024
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You should not be allowed under the hood of a vehicle... :facepalm:
    Go find your lost socket.
  5. Jul 6, 2013 at 1:37 PM
    #1025
    3ps14
    3ps14 Well-Known Member
    Orange, CA
    05 trd sport dc
    OME 885s, Black FJ Alloys, TSB AAL, BHLM, Satoshi, Hellas, Black Valence, 6k HIDs
    Do we get to know your secrets yet?!
  6. Jul 6, 2013 at 1:53 PM
    #1026
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    you have no idea how pissed i was when that fucker fell off my impact gun.... i would have to remove the heads to find that socket now.... it fell off on the last bolt on the install in the back of the intake manifold so im sure its under the intake runners...
  7. Jul 6, 2013 at 2:52 PM
    #1027
    Pugga
    Massachusetts
    Do you have an extension on a magnet? I would try that before removing the headers.
  8. Jul 6, 2013 at 2:56 PM
    #1028
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    :facepalm: I don't even know where to begin
  9. Jul 6, 2013 at 3:39 PM
    #1029
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    it rolled on one of the back hoses under the runners. tried a magnet, and i used an optical line to find it.... i literally have to take off the heads at this point.... i know it wont cause any damage its just annoying to know its there. it cant be sucked in anywhere, everything is sealed tight. it could possibly fall out one day on some intense off roading maybe. seriously, i wanna kick myself for buying crappy tools
  10. Jul 6, 2013 at 3:44 PM
    #1030
    emelianenkov
    Alex
    NORTH POLE
    Impact gun!? Max torque is 22 ft/lbs! Jesus you REALLY shouldn't be allowed under the hood
  11. Jul 6, 2013 at 3:45 PM
    #1031
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    small handheld electric impact... on a very low setting jesus im not stupid
    the same impact gun i use to tighten down my hose clamps on my intake its not breaking anything
  12. Jul 6, 2013 at 4:45 PM
    #1032
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    I guess you can chalk it up to the learning process...
  13. Jul 6, 2013 at 5:51 PM
    #1033
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    who knows maybe ill do what Nate (xmods) did and paint my heads... in the process find that socket....
  14. Jul 6, 2013 at 6:12 PM
    #1034
    Pugga
    Massachusetts
    You should drop a set of short tubes in there while you have the heads off :D
  15. Jul 6, 2013 at 6:40 PM
    #1035
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    short tube headers? pretty sure i can do that without taking off the heads.. unless ur talking about another short tube im not familiar with.
  16. Jul 6, 2013 at 6:48 PM
    #1036
    Pugga
    Massachusetts
    Yes, you can do that without taking off the heads... but while you're tearing shit apart, why not use that as the excuse to add more parts :notsure:
  17. Jul 6, 2013 at 6:53 PM
    #1037
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    I've got a 6 speed, if someone will buy the spacer and pay for the dyno run I'll be glad to try it out. :cookiemonster:
    Actually how much does a dyno run cost? I never bothered to check my other Toyota truck or Land Cruisers when I had them.
  18. Jul 6, 2013 at 7:20 PM
    #1038
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    10' PRO-4X CC, modded..
    Too long to list :D
    I only painted the valve covers, not the heads :)
    Even if you take the valve covers off, you would still have to take off the intake manifold to get your socket :(
  19. Jul 6, 2013 at 7:27 PM
    #1039
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    damn it... :( i was worried u were gunna say that nate... UGGHHNNGGD:annoyed: ill just wait till one day i have free time to do a major tear down....... so, Pugga u think short tubes would be better than long tubes?
  20. Jul 6, 2013 at 9:06 PM
    #1040
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    Too long to list :D
    ^ Depends which ones are equal length..
