Intake Manifold Spacer 4.0l Coming!
Discussion in 'Performance and Tuning' started by highaltitude, Feb 6, 2012.
  1. Jul 19, 2013 at 1:27 PM
    #1161
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    Having the material be aluminum vs plastic is irreverent. The plastic manifold is normally mounted to the aluminum block. putting another aluminum spacer would marginally change the intake temp if anything.
    better low-end = engine works less to accelerate from 0-30ish and aid in smoother shifting in the low gears.
    I've noticed a lot of casual driving (in my auto) that my truck won't shift from 1-2-3 until 3.5k+ rpms when it *could* shift into gears closer to 2k rpms, thus conserving some fuel running on less revs. saving gas here and there will give back an additional 1-2mpg/tank.
  2. Jul 19, 2013 at 3:20 PM
    #1162
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    My mileage can vary at least 2 or more miles per gallon just with different weather, road, or traffic conditions. Now an overall consistent average from documented fillups taken over time would be much more convincing...
    ...but then so would
    dyno runs. :anonymous:
  3. Jul 19, 2013 at 3:25 PM
    #1163
    tooter
    Greg
    Los Angeles
    I think that it would ever so slightly lower temps because the same heat is being radiated in all directions from a slightly larger total mass of aluminum.
  4. Jul 19, 2013 at 5:03 PM
    #1164
    luka
    Kailua, HI
    the only way to know would be add a thermometer...Aluminum transfers heat so easily that it may or may not drop the temp.
    :deadhorse:
  5. Jul 19, 2013 at 5:53 PM
    #1165
    tooter
    Greg
    Los Angeles
    Yeah, but I don't think that small bit of added metal would make a measurable difference.
    (continues beating... ;) )
  6. Jul 19, 2013 at 6:02 PM
    #1166
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
  7. Jul 19, 2013 at 6:21 PM
    #1167
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Is anyone going to do some tests to prove one way or another? Or is everyone going to keep speculating.
    That horse's ribs have to be mush by now.
    Is it really even necessary to test. Touch it. That mother will be hot. Touch the plastic. I bet it will not be nearly as much. Duh.
    Will the heat from the aluminum radiate? Yes. More so than plastic. Are the negative impacts from that small addition of aluminun greater than the positive impacts of air flow speed/hp/mpg/whatever? Probably not. Otherwise people wouldn't be saying there is some noticeable gain.
    Could it be better if it were plastic? Possibly. One guy made one from another OEM intake. I asked Grimmspeed if they would make a phenolic spacer. They won't do it unless there are a large quantity ordered.
    What is the debate about again? I'm lost
  8. Jul 19, 2013 at 6:32 PM
    #1168
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Hey tor I hear when you step on the gas it pulls in cold air.... ( or cooler than engine temp)
  9. Jul 19, 2013 at 7:24 PM
    #1169
    tooter
    Greg
    Los Angeles
    I agree. Aluminum is best for small low risk production runs regardless of its temperature properties.
  10. Jul 19, 2013 at 8:02 PM
    #1170
    acdronin
    acdronin Well-Known Member
    I average about 25K a year in driving, this mod would pay for itself by just a 1 MPG increase
  11. Jul 19, 2013 at 10:22 PM
    #1171
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I do 30264 miles just going to work each year.
    As you said, even at 1mpg it's a god send.
  12. Jul 19, 2013 at 10:52 PM
    #1172
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    :dancingbacon:
  13. Jul 20, 2013 at 4:23 AM
    #1173
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Crikey!!! (Australian accent)
  14. Jul 20, 2013 at 8:08 AM
    #1174
    luka
    Kailua, HI
    I have that dynolicious app on my phone from a bunch of years ago, I could make a few runs and track the before/after the spacer. not sure if it will show much different numbers, but it should chart the acceleration/braking G's chart a little differently.
    probably the easiest way to ball-park it using the gps and accelerometers using a constant vehicle weight of 4200 lbs.
    can track 0-60mph in time, 0-1/4 mile distance time@mph.
  15. Jul 27, 2013 at 4:03 AM
    #1175
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    It has been a few weeks since these began being installed. Overall the topic has died to almost nil.
    Those that have installed them, are the mpg numbers stable, or consistent. Has anyone done the dyno runs and have more to offer.
    The seat of the pants impressions still remain better than oem?
    Not concerned or even worried about peak HP, just is the truck more drivable.
    PK
  16. Jul 27, 2013 at 11:47 PM
    #1176
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    definitely better mpg and more power. not lot of power but you can feel it getting on the freeway and just rolling on the throttle, it just keeps pulling. doing 65-70mph i get 20-22 mpg with it. i never saw that before the install.
  17. Jul 28, 2013 at 7:53 AM
    #1177
    SoCaltaco65
    what were you getting @65-70 before?
  18. Jul 28, 2013 at 8:42 AM
    #1178
    tooter
    Greg
    Los Angeles
    Greg ;)
  19. Jul 28, 2013 at 11:26 AM
    #1179
    3ps14
    3ps14 Well-Known Member
    Orange, CA
    05 trd sport dc
    OME 885s, Black FJ Alloys, TSB AAL, BHLM, Satoshi, Hellas, Black Valence, 6k HIDs
    Do you have a lift or larger beefier tires?
  20. Jul 28, 2013 at 4:27 PM
    #1180
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    about 17-19 mpg at 65-70. and yes i do, 265/70/17 tires with a 3in lift and alloy rims that are heavier than the stock 16's. the tires are bf goodrich rugged terrain.
