Intake Manifold Spacer 4.0l Coming!
Discussion in 'Performance and Tuning' started by highaltitude, Feb 6, 2012.
  1. Sep 18, 2013 at 8:19 AM
    #1221
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
  2. Sep 18, 2013 at 10:32 AM
    #1222
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    I drive ~50 miles daily for work and noticed it is helping the most on flat ground. I have to drive over a hill so I fight it halfway and coast down the other :)
    still managing to maintain 17+ mpg with 33's(255/85) with a lot of armor.
  3. Sep 18, 2013 at 11:23 AM
    #1223
    CWG
    CWG Active Member
    Seattle?
    2013 DCLB Sport
    Truck Covers USA Hard Tonneau, DynoLock, OEM steps, TRD SE Anthracite wheels, Duratrac tires
    I drive a hilly 40 miles daily roundtrip and I didn't notice much on the mpg gains. For me the powerband shift down in RPM was the fantastic part. No more contstant downshift in traffic on my variable speed hilly commute. Rarely get it over 3000 rpm now, which should have helped mpg but haven't noticed over 1/2 mpg variance.
  4. Sep 18, 2013 at 11:28 AM
    #1224
    3ps14
    3ps14 Well-Known Member
    Orange, CA
    05 trd sport dc
    OME 885s, Black FJ Alloys, TSB AAL, BHLM, Satoshi, Hellas, Black Valence, 6k HIDs
    Thanks for all your guys' help and insight! Im gonna be purchasing one here soon.
  5. Sep 18, 2013 at 4:21 PM
    #1225
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Plan ahead in regards to the intake supports. My lightly used NST spacer came with 2 out of three brackets, and these were already trimmed.
    It's not difficult, just be prepared if your spacer does not come with them.
    You might also consider cleaning the il residue from inside the manifold and throttle body while apart.
    PK
  6. Sep 21, 2013 at 11:31 AM
    #1226
    3ps14
    Orange, CA
    05 trd sport dc
    For sure, thanks for the heads up.
  7. Sep 21, 2013 at 11:34 AM
    #1227
    DavisBladeWorks
    DavisBladeWorks Well-Known Member
    North ATL
    2013 DSCB TRD Sport 4x4
    Exactly how does this affect performance? I don't know much about exhaust flow dynamics, so I don't understand how a simple spacer could make such a difference.
  8. Sep 21, 2013 at 12:19 PM
    #1228
    highaltitude
    highaltitude [OP] Well-Known Member
    Asheville, NC
    2017 ZR2
    Some reading about the spacer - > http://extremetruckperformance.com/?page_id=2
  9. Sep 21, 2013 at 2:25 PM
    #1229
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Intake man. but I supose u can't have one without the other.
  10. Sep 21, 2013 at 3:03 PM
    #1230
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This is where the long awaited dyno results would come into play :rolleyes:
  11. Sep 21, 2013 at 3:24 PM
    #1231
    T-rev
    T-rev Resident Mall Crawler
    Tempe, AZ
    2017 TRD Offroad
    x2. Still waiting..
  12. Sep 21, 2013 at 4:29 PM
    #1232
    luka
    Kailua, HI
  13. Sep 21, 2013 at 4:33 PM
    #1233
    Pugga
    Massachusetts
    What, someone had to say it :D
  14. Sep 21, 2013 at 4:46 PM
    #1234
    luka
    Kailua, HI
    :D
  15. Sep 21, 2013 at 4:59 PM
    #1235
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    While you're waiting for highaltitude to keep his word,
    here's the dyno test results for the 2TR FE intake manifold spacer.
    (blue=no spacer, red=spacer)
  16. Sep 22, 2013 at 11:43 AM
    #1236
    PMK
    Florida
    10 DCLB TRD Sport
    My truck does "feel" more driveable. Similar to what others have said, and from the basis dyno runs on the NST Spacer.
    I am close to having run 1 tank of fuel through it to see if mileage does come up.
    The scangage display was reconfigured to show MPG constantly. Pretty depressing to see the low numbers while pulling away from a light.
    PK
  17. Sep 22, 2013 at 2:07 PM
    #1237
    highaltitude
    Asheville, NC
    2017 ZR2
    I
    Funny how much of a doubter tooter is, when he doesn't have a v6 4.0 truck as far as I know? Not sure why he keeps popping up when the results either way wouldn't effect him, other than to just create doubt for people. So far the 30 or so people who have bought this spacer have not complained at all. Not to mention there are dynos showing these spacers do have gains. There is nothing different between my spacer and NST's spacer other than the gasket design. There is nothing stopping anyone who has purchased one of these from doing their own dyno. I just don't currently have time to do a dyno test during the week. Time is always short for me. I would love to have the results to put the speculation to rest, finding a shop to do a run on a weekend and the time to do it is difficult here. I work 3 jobs, time is a luxury I don't often have. I will get them done when I get things lined up. Test truck, dyno shop, time...
  18. Sep 22, 2013 at 2:39 PM
    #1238
    T-rev
    Tempe, AZ
    2017 TRD Offroad
    Send one here for free and I'd be more than happy to put my truck on a dyno. :D
  19. Sep 22, 2013 at 2:40 PM
    #1239
    tooter
    Greg
    Los Angeles
    You have my apologies.
    I've deleted the comment.
  20. Sep 22, 2013 at 3:20 PM
    #1240
    highaltitude
    Asheville, NC
    2017 ZR2
    It's certainly a possibility. Something I have thought about.
