Intake Manifold Spacer 4.0l Coming!
Discussion in 'Performance and Tuning' started by highaltitude, Feb 6, 2012.
  1. Feb 9, 2012 at 10:39 AM
    #121
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Good info!
    I'm with acdronin on low end power. I've also got a shell and lots of tools so I'm pretty heavy even when unloaded. The truck has plenty of power and I can get the tires lit up if I want to, but for just everyday driving, it seems almost hesitant to get up and go unless you really put your foot into it. Just cruising along, if you want a slight acceleration, it still requires the engine to downshift, it doesn't want to slowly pick up speed at cruising RPM. Just my $0.02. I don't think the truck is underpowered per say, it's done exceptionally well towing and hauling so far but if I could get some extra power in the low end for every day driving, it would be a welcomed addition.
  2. Feb 9, 2012 at 11:27 AM
    #122
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Need more meat on those tires. :D
  3. Feb 9, 2012 at 11:34 AM
    #123
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I am not sure about the the MAF Cal specifically starts making adjustments per the tuning, but I do think it worthy for someone to ask Gadget. That way the information is as accurate as possible.
    Only reason that i say that, is because WOT is after the necessary percent of throttle depression to get the ECU to go into open loop. That being IF, it tunes in Open Loop only.I also cannot remember specifically where open loop occurs based off of TPS value. Whether that be 40, 50 or 60%?
    I have a ScanGauge II, and can check on the way home today. It will give a relatively close idea, by selecting TPS and Loop.
  4. Feb 9, 2012 at 12:10 PM
    #124
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Toyota wouldn't purpsely design their engine, for aftermarket companies to benefit off of it. And if they do have any power add on's that they know about, but the cost of manufacturing a ton of them and adding it on the assembly line, then there's TRD. Did you ever hear of a TRD throttle body spacer? Or a TRD manifold spacer? Nah brah
    Yerp
    700th post btw :spy:
  5. Feb 9, 2012 at 12:44 PM
    #125
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No. Never heard of TRD. I have heard of AFe and Eaton though. ;)
    Why didn't Nissan, with their VQ motors for the 350Z and G35/37, add the intake manifold spacer, or make the intake a little taller? When they clearly knew from testing that two of the cylinders for their motor were not getting enough air flow compared to the rest, and under modding, a problem would present itself. I don't know. I am not an engineer or accountant for Nissan.
    Thus Skunk2 came up with a solution. Manifold spacer. In the link I posted earlier. With dyno results for that motor.
  6. Feb 9, 2012 at 12:48 PM
    #126
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    URD, bosal, JBA and APR come to mind as well.
  7. Feb 9, 2012 at 12:53 PM
    #127
    Pugga
    Massachusetts
    Of course a company would overdesign their engine. An engine capable of handling 500 HP but only putting out 250 would last a lot longer than an engine pushed to it's limit and operating at the high end all the time. When you start pushing more and more power out of an engine, tolerances need to be tighter and things tend to break easier (in extreme cases of course).
  8. Feb 9, 2012 at 12:59 PM
    #128
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    tread width is right at 10.2"....x2. :)
  9. Feb 9, 2012 at 1:02 PM
    #129
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Just to be clear the MAF Cali comes into play in open loop, not WOT, as you've said. I thought I read the WOT is considered >90%, but can't cite it now, oh Scanguage.......
  10. Feb 9, 2012 at 1:15 PM
    #130
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Mine are only 10.8". :( Need some 315's. That should stick better. :D
  11. Feb 9, 2012 at 1:30 PM
    #131
    Clifford
    Clifford Well-Known Member
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    you need more then 315's lol, how bout some 18x12 +15 or so all the way around with 335's?
  12. Feb 9, 2012 at 1:38 PM
    #132
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not doing 18's because I have 20's.
    But once I install that manifold spacer back on my truck, and make some jaw-some torque, I will hit up HRE or Rotiform for some fatties to fit those 335's. Lol
  13. Feb 9, 2012 at 4:38 PM
    #133
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    There's a tear in my eye. A little bit of REAL tech talk and debate on tacomaworld.
    I came over from the mustang community. I had my 66 and my 99, sold them both to get my truck. Intake manifold spacers are nothing new. There are many a company that makes them. From all I have seen and read, they serve their purpose. From all I have seen they bring your tq curve down lower and or increase it. It's also one of the few mods that give more power and better mpg's. Kind of like underdrive pullies, a few free hp and better mpg's.
    I had many a dynoday when I had my stangs. My 99 was an auto. Most of my dyno's started at 2000 rpm BUT I had the ability through the tuner to lock the converter and keep the tranny from down shifting. I had a 3000 stall in that car so under 2500 rpm's I really didn't care about. Now on my dd truck, it's a diff ball of wax. I don't think your going to be able to get a super low rpm start point without the tranny down shifting or haveing "blips" in the graph from the converter locking or unlocking.
  14. Feb 9, 2012 at 4:42 PM
    #134
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Hmm... Let's just say that one of these definitely does work. I am adding headers to my truck here really soon. Would this mani spacer combined with LT headers essentially raise my entire power curve?
  15. Feb 9, 2012 at 4:51 PM
    #135
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It is fun, isn't it? :cool: I am a little concerned as well about that fact with the auto. Luckily, I have other friends with the same truck that live close enough.
  16. Feb 9, 2012 at 4:57 PM
    #136
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    From what was able to gather from my ScanGauge was this:
    1, going past 30% throttle would put you into Open Loop. No matter 2k RPMs or higher. Cannot believe that I forgot that. :(
    2, even being at 27% throttle, when I passed around 3400 RPMs, it still went into Open Loop.
    For those unaware of what the difference is between Open Loop and Closed Loop is, it is pretty simple.
    Closed Loop means that there is feed-back going on between the sensors. Mainly MAF and WRAF. That data is constantly being read and adjustments are being made. Open Loop means NO feed-back. It basically runs off of a pre-determined MAP for fueling and timing.
  17. Feb 9, 2012 at 5:04 PM
    #137
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
    if you guys wanna do a group buy on this we can get them for 215 instead of 265. Im up for that if anyone is interested ill start a GB
  18. Feb 9, 2012 at 5:30 PM
    #138
    highaltitude
    highaltitude [OP] Well-Known Member
    Asheville, NC
    2017 ZR2
    With that kind of philosophy, why didnt they put headers, and a catback exhaust and a Superchips programmer in it too? Oh, cuz they make no power either? There must be absolutley no way to improve the HP and power of these trucks, guess you guys all better be happy with what you have then. LOL :p
  19. Feb 9, 2012 at 5:37 PM
    #139
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cat back isnt good, as there are noise restrictions the manufactures have to meet. Also, most cat backs only give about 5 hp.
    Superchips programmers dont work on the Tacoma.
    headers are expensive.
    So...Can more power be gained? Sure. At the expense of longevity, perhaps.
    By leaning the A/F ratio, you can get a few more Hp. And thats what an APR X1 and MAF Calibrator do. IIRC, The APR can adjust timing a bit also, for a bit more power.
    Regardless, everything comes at a price.
  20. Feb 9, 2012 at 5:38 PM
    #140
    highaltitude
    Asheville, NC
    2017 ZR2
    Look, I wont sit and try to convince you guys with no Toyota data, I will get it made, do testing and then see what you guys think. I know for a fact they work on other vehicles, like my Nissan. There are literally several hundreds of these on Nissan Frontiers, Xterras, Pathfinders, Maximas, and Altimas out there making power. I may have jumped the gun posting this thread before having one ready, but I was guaging the market to see if there was interest. I have tons of happy customers running them, anyone who is not running them cannot conclusively say they dont work.
