Intake Manifold Spacer 4.0l Coming!
Discussion in 'Performance and Tuning' started by highaltitude, Feb 6, 2012.
  1. May 7, 2014 at 5:43 PM
    #1401
    highaltitude
    highaltitude [OP] Well-Known Member
    Asheville, NC
    2017 ZR2
    Shipping is provided when requested, otherwise things ship usually within a few days.
  2. May 15, 2014 at 2:06 PM
    #1402
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
    The dyno charts for the 2011 show results starting at 2750 rpm.
    The text says "@ approx. 3125 rpm 20+ Torque ft. lbs. gain!"
    Honestly, I very seldom rev my truck past 2500, and reach 3000 rpm even less than that.
    I'd be down with more off idle to 3000 torque, if it's there, and very noticeable.
  3. May 15, 2014 at 6:40 PM
    #1403
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    If you have feather foot...don't buy it.......most people(especially the S/C crowd) like to mash it to the floor now and again...to each his own....:D
  4. May 15, 2014 at 7:12 PM
    #1404
    smaldo76
    smaldo76 Well-Known Member
    steve
    Clover, SC
    Black Baja
    TRD BOOST afe intake, doug throrley headers, predator step bars
    Can you use this spacer with the trd supercharger?
  5. May 15, 2014 at 10:35 PM
    #1405
    AlanLoshbaugh
    Alan
    Columbia, MO
    Understood; thanks
  6. May 24, 2014 at 12:32 PM
    #1406
    highaltitude
    Asheville, NC
    2017 ZR2
    Actually if you did mean to say "feather foot" then this can benefit you. Because of the extra power gained, then less throttle is required to get the same output, therefore less gas is used, in turn gives you better mpg. However if you have a "lead foot" like me, you still obviously get more power, but will not see better mpg. So this spacer can benefit many different types of drivers and different reasons for needing it.
  7. May 25, 2014 at 1:23 PM
    #1407
    1tacoplease
    1tacoplease I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    Can I just purchase the gasket?
  8. Jun 19, 2014 at 9:18 AM
    #1408
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I order my IMS some months ago, and installed it about 4 weeks ago. I've run around 4 tanks of gas. Following is my review:
    Order process
    o never dealt with a person or vendor who did not send out shipping notifications, I don't agree with not sending them out and minmally should be noted that no confirmation will be sent
    o IMS was delivered within 6 days from my order day though, just didn't know it was on its way
    Unboxing
    o nice looking woork, the IMS is detailed and smoothed very well and the gasket fits :)
    Installation
    o went well overall
    o problem is that during the install, on my truck there is a bracket on the back of the upper manifold that contains the heater core hoses and the wiring harness. this bracket is not documented in the instructions and is a royal PITA to deal with, you have to either unbolt the bracket (much more difficult than it sounds) or get the hoses and harness disconnected from the bracket (again, more difficult than it sounds) as the bracket is up against the firewall, no room, and can't see back there, anyway royal PITA
    o even if the vnedor does not have a truck with this bracket, instructions should reference that late model trucks have that bracket and be prepared to deal with it
    o as it turns out, I spent as much time on just that bracket as I did the rest of the install
    o other then the bracket, very easy to install
    o one note is to try and line up the IMS, gasket and lower manifold as there is some play and it you are off, it can affect the flow due to the port mismatches.
    Use
    o I do not have any figures to back this up yet
    o I did not notice any difference in performance, for or against
    o I've run 4 tanks of gas through and have seen no mpg differences, for or against
    o overall, I am a bit disappointed, I am considering taking it off and selling it, but I do want to run some 0-60 and 1/4 mile times first
  9. Jun 19, 2014 at 10:06 PM
    #1409
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Just put my spacer on and reset the computer ( a must after all mods) and so far it's running great...
    combined with my cat back part throttle acceleration is great and pulls much harder, passing is better, holds speed much better and with both I'm getting better MPG so far...
    Idle seams higher and exhaust seams louder at lower rpm intake my be louder also...
    So far great mod for low RPM torque.
    The computer is still adjusting but so far real good.
  10. Jun 20, 2014 at 7:15 PM
    #1410
    1tacoplease
    Temecula
    Worked great for me! I'm happy.
  11. Jun 21, 2014 at 11:35 PM
    #1411
    shr133
    Muskego, WI
    2010 V6 Sport
    After my 1000 mile trip up north, this is a great mod, passing power with the cat back is great. I was passing cars like crazy even double passing cars, first time truck hit over 90mph in 4 years.
    I added the spacer after I added my 2 1/2" cat back exhaust with a 18" round muffler. The exhaust worked good but lost some low end torque but had great top end. I was thinking about getting the spacer, I thought the spacer would work good with the exhaust and I was right.
    The combination of my intake mods, cat back and adding the spacer brought everything together and worked great. The truck is just fast and the motor rocks above 3,000 rpm. It feels like a hot rod and I'm finally happy with the motor, it's just fun to drive. I look forward to passing and stop lights.
    I also picked up some mileage, I was getting 17 mpg with the 32" coopers at any speed, after the exhaust and spacer I averaged 18.6 with a high of 19.8, my new record high ever. my first fill up was 20.1 but the computer was still running lean.
    So good mod, worth the money.
  12. Jul 10, 2014 at 5:25 PM
    #1412
    highaltitude
    Asheville, NC
    2017 ZR2
    Great to hear it's working for you!
  13. Jul 10, 2014 at 7:32 PM
    #1413
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    where are you guys getting the spacers from?
    i have a s/c thing it will help?
  14. Jul 10, 2014 at 7:39 PM
    #1414
    highaltitude
    Asheville, NC
    2017 ZR2
  15. Jul 11, 2014 at 3:49 AM
    #1415
    Blacktaco2042
    wisconsin
    thanks it will work with my trd supercharger right?
  16. Jul 11, 2014 at 3:50 AM
    #1416
    highaltitude
    Asheville, NC
    2017 ZR2
    I'm not 100% sure, but I do believe there are a couple guys on here running them with a SC.
  17. Jul 11, 2014 at 1:18 PM
    #1417
    Blacktaco2042
    wisconsin
    hopefully they will chime in
  18. Sep 24, 2014 at 12:57 PM
    #1418
    Deerhunter1911a1
    Deerhunter1911a1 Jeeper gone Taco!
    San Diego, CA
    2012 Tacoma TRD V6 6-speed MANUAL BABY!
    None yet. Soon to come.
    Wow, what a thread! So some guys bolt it on and say wow. Some do so with other mods and say wow. Some say it doesn't do a thing. Crap! 72 pages of thread and still no firm yes or no....or did I wildly miss something?
  19. Sep 25, 2014 at 9:22 AM
    #1419
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    I have this spacer on my truck, no other mods, and after a couple of months, my mpg's are at 17-18mpgs, from 16.5. I guess a bit more holding power on hills at lower rpms. could be in my mind, could be the truck breaking in still. I wont take it off to find out though. at least not now. truck currently has 27k. installed prolly at 24k.
  20. Sep 25, 2014 at 2:55 PM
    #1420
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    to me, it's a firm yes. bigger difference than my shorty headers ever made.
