Intake Manifold Spacer 4.0l Coming!
Discussion in 'Performance and Tuning' started by highaltitude, Feb 6, 2012.
  1. Sep 25, 2014 at 3:12 PM
    #1421
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    I say agree firm yes, increases torque. But I already had exhaust on my truck so I can't say for a stock truck but I think it will help. It will also start to lean out the F/A ratio... I believe the stock computer only adjust a small amount so if you put on the spacer, intake and exhaust you will be running a lot leaner than stock so you can gain and loose at the same time. You also have to reset the computer after mods to feel the full effect faster.
  2. Sep 25, 2014 at 3:14 PM
    #1422
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    are u verifying this thru a gauge, or is someone else proving the lean AFR?
    Just curious
    6xchamps likes this.
  3. Sep 26, 2014 at 3:50 PM
    #1423
    shr133
    Muskego, WI
    2010 V6 Sport
    I don't have a gauge yet just using 20 years experience of tuning...
    And my mpg went up from 17 to 19.8 until the computer added more fuel and it went to 18.8, so a 1.8 mpg change from adding the exhaust and intake.. It was running better but felt weak, that means it lean... Added the maf cal and that did the trick runs great, 0 to 60 went from 8.1 to 7.2 and tows great and stopped the exhaust drone while towing..... But mpg went down to 16 so I'm trying to make a compromise map that can still get better mpg at part throttle and maintain power when I'm on it..... but so far mpg is a inverse relationship to power so I'm making changes slowly...
    So I thought it was lean and by added the maf cal I could easily prove it was lean because adding fuel made it run much better but then the mpg goes down...
    I think the computer is very limited on how much it can change the fuel, I think it only has a small window to work with... The computer is suppose to be able to maintain 14.5 with production variances, wear over time and weather conditions, I don't think this is true, people are getting from 20 to 16 mpg I was getting 17.1 driving like an old man or running at 80 with 32s.... that is why people are getting different results with the same mods because every ones f/a ratio is different and the f/a ratio can change the "feel" a lot...
    It doesn't take much adjustment with the maf cal to get it right 10 is neutral and my highest point is 10.8... I'm guessing I'm around 12 to 1. I had to lean out open loop and enrich closed loop. It even idled better on the first start up...
  4. Sep 26, 2014 at 6:48 PM
    #1424
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I get 21 lol
  5. Sep 27, 2014 at 2:54 AM
    #1425
    Deerhunter1911a1
    Deerhunter1911a1 Jeeper gone Taco!
    San Diego, CA
    2012 Tacoma TRD V6 6-speed MANUAL BABY!
    None yet. Soon to come.
    Huh. So takeaway being we don't really have dyno numbers and one dude on like page 15 said it sucked, but the overall consensus is it helps, if even only a little, so it's just a matter of how much money you are willing to spend for how little potential gain. Interesting. I'll add it to the long list. Towards the bottom but on the list!
    7six2Fan likes this.
  6. Sep 27, 2014 at 8:59 AM
    #1426
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Im used to mine now that I forget its there. But when I first installed it, I noticed a huge improvement in acceleration. Low end power/torque is where it is really noticeable. Don't have to give it as much throttle to get going pretty quick.
    But like I said, Im soo used to it now that I forgot what it was like without it. lol
  7. Nov 13, 2014 at 8:02 PM
    #1427
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Sub'd to read.
  8. Jun 21, 2015 at 1:59 AM
    #1428
    1tacoplease
    1tacoplease I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    So after about a year later. I finally installed this and feel a power increase. It feels like some more torque. I think it's worth the price.
  9. Jun 22, 2015 at 12:34 PM
    #1429
    Crocodile Tears
    Crocodile Tears Member
    Maumee, OH
    2015 AC TRD OFFROAD
    Am I the only one who finds it odd that on the automatic the higher power number was made at 2:28 PM and the lower was at 3:41 PM the same day?
    I haven't read the whole thread to know what order they did the test in, but I would think a baseline would come first, then bolt on the new part. Like I said, I don't know and don't want to try to disprove anyone, I'm just asking the question.
  10. Jun 25, 2015 at 12:58 PM
    #1430
    6xchamps
    6xchamps Well-Known Member
    Fuquay Varina NC
    2015 AC
    Supercharger weigh ins?
  11. Jun 25, 2015 at 2:34 PM
    #1431
    highaltitude
    highaltitude [OP] Well-Known Member
    Asheville, NC
    2017 ZR2
    I would have to look at everything again to remember exactly what we did, but because we had such limited time at the dyno shop as we were paying per hour. We prior to arriving at the shop installed a spacer on one of the trucks while the other did not have a spacer. That way while one truck was on the Dyno, we were either installing or uninstalling the part on the other one so that we could switch back and forth easily. Basically run 1 on one truck had a spacer, and run 1 on the other truck had no spacer. So run 2 on one truck had no spacer and run 2 on the other truck had a spacer. Hopefully that makes sense. ( it was also done that way because one of the guys bought the spacer from me so he wanted to drive home with it installed on his truck, the other guy was not purchasing one but just testing and that's why we had it on his truck to begin with so that the second run we took it off ) Bottom line was both trucks saw a power and torque increase
  12. Aug 17, 2016 at 12:08 AM
    #1432
    WorldWar546
    WorldWar546 Baja Member
    Anthon
    Utah
    TRD Charged '14 Black TX Baja
    TRD Supercharger And a lot of rice n chrome
    Would this work with a TRD supercharger? Does it change or add sound?
  13. Aug 18, 2016 at 1:10 PM
    #1433
    shr133
    Muskego, WI
    2010 V6 Sport
    It makes the intake runner longer, I don't know if you will need it with a supercharger...
    It could add more torque but raises the intake / supercharger so I don't know how it would effect belt length....
  14. Aug 18, 2016 at 1:51 PM
    #1434
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Why does the automatic see a better gain that the manual?
    Was everything on these trucks bone stock other than the spacer? 12hp and 20+tq for $265 sounds too good to be true..
  15. Aug 18, 2016 at 1:54 PM
    #1435
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    trd SC belt wont fit (but urd prolly wont have an issue) been discussed somewhere (may not have room under the hood too I think) and I think the manuals couldn't lock out a gear low enough to do a pull where the gains are most noticeable or something like that.
  16. Dec 27, 2016 at 12:19 AM
    #1436
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Anybody in for another Discount Buy ?
    TortyB likes this.
  17. Jan 14, 2017 at 3:18 PM
    #1437
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
  18. Jan 22, 2017 at 1:16 PM
    #1438
    sy272004
    sy272004 Well-Known Member
    West Chester
    15 TRD V6 4x4 DC
    3" lift. 33" tires. Headlight Retro, intake, exhaust
    Did u guys thought about making it out of thermal plastic or something to prevent or delay upper intake thermal soak?
  19. Feb 9, 2017 at 8:40 PM
    #1439
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    My offer still stands. Anyone want to dyno test this on their truck on the URD Dyno in Owings MD, contact me at URD to set it up.
    yota243 likes this.
  20. Feb 10, 2017 at 5:23 AM
    #1440
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
