Intake Manifold Spacer 4.0l Coming!
Discussion in 'Performance and Tuning' started by highaltitude, Feb 6, 2012.
  1. Feb 9, 2012 at 5:42 PM
    #141
    acdronin
    acdronin Well-Known Member
    IMO i think this has been a good healthy discussion on the topic, I for one, look forwards to your data, there will always be naysayers to anything that one does but dynos cannot lie, it's the proof in the pudding
  2. Feb 9, 2012 at 6:18 PM
    #142
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I think you hit it on the head..... you just posted this too soon. Get it made, get a half a dozen guys to test it for you and get real #s (keeping in mind that a lot of guys here know how to interpret data). You'll get a lot less pessimism.
  3. Feb 9, 2012 at 6:20 PM
    #143
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    :laugh:
    Sorry, couldn't resist :eek:
    I agree though, I'm curious to see some data!
  4. Feb 9, 2012 at 8:01 PM
    #144
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    What's the return policy? [​IMG]
    Exactly my point in a way, Toyota made their engines to last. This spacer claims it won't hurt engine life, easy to install, cheap, add's horsepower. Why wouldn't they have done it?????? :confused::confused:
  5. Feb 9, 2012 at 8:53 PM
    #145
    chriss
    chriss Well-Known Member
    chris
    This a reasonable explanation of intake runner function. But not very complete. It doesn't address the harmonics of the pressure waves. Runner length is typically tuned for a particular RPM or RPM range.
    Find one of the online intake runner length calculators and play around with the numbers to see what they recommend. You may be surprised.
    I also saw some posts regarding exhaust gas temperatures. Peak combustion temperatures are at the stoichiometric balance. Richer OR leaner will lower this temperature.
    The air/fuel ratio of 14.7 to 1 is for a standardized fuel. Gasoline with additives, especially alcohols, are lower. Sometimes much lower. Peak power is typically had with a rich mixture of 11 to 12 to 1.
    And dynos can lie. Any measurement tool can be misrepresented. The more complex the tool, the more opportunity for manipulation.
  6. Feb 14, 2012 at 6:55 AM
    #146
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Was the dyno run done yet???
  7. Feb 14, 2012 at 7:06 AM
    #147
    Pugga
    Massachusetts
  8. Feb 14, 2012 at 7:27 AM
    #148
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The dyno i have scheduled still has not yet. It is for this Saturday, the 18th.
    Also have another friend who is dynoing his Tacoma as well. NST lower pulley, TRD Gen 1 CAI, Headers, modified URD y-pipe, and 3" catback. Going to be a good morning on Saturday. :)
  9. Feb 14, 2012 at 7:32 AM
    #149
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Im curious to see the numbers of both of those runs tor... could you send me sheets for both. Email maybe?
  10. Feb 14, 2012 at 7:42 AM
    #150
    Pugga
    Massachusetts
    Don't be selfish, post 'em up for all to see :D
  11. Feb 14, 2012 at 7:45 AM
    #151
    memario1214
    Colton
    Missoula, MT
    I just thought to avoid unnecessary clutter in this thread... not trying to be selfish at all.
  12. Feb 14, 2012 at 7:47 AM
    #152
    Pugga
    Massachusetts
    Oooh... I thought they were trying the manifold spacer on both trucks, one stock, one modified to show the difference before and after :confused:
  13. Feb 14, 2012 at 7:49 AM
    #153
    memario1214
    Colton
    Missoula, MT
    I don't think so... but maybe. Im mainly curious on the second one as that is close to what my setup will be very soon.
  14. Feb 14, 2012 at 8:05 AM
    #154
    Pugga
    Massachusetts
    Are you looking to add pulleys a URD Y-pipe to your garage collection? You're going to end up just like OZ with his Relentless bumper :D
    Coming Soon: 3" OME Lift (Sitting in garage)... DTLT Headers (also garage sitting) TRD or URD Supercharger
  15. Feb 14, 2012 at 8:43 AM
    #155
    memario1214
    Colton
    Missoula, MT
    Haha screw you. :brianr:
    I don't plan to add the Y-Pipe for now anyway as I feel like I am going to be combating rasp by adding in the headers anyway. I have been looking into the pulleys actually... March 12, the construction begins. I should put a countdown in my sig or something.
  16. Feb 14, 2012 at 8:57 AM
    #156
    Pugga
    Massachusetts
    Sorry man, I couldn't resist :eek:
    I'm curious about pulleys. I've always kind of viewed pulleys as a way to eek out that last bit of power after you've attacked the other major items like intake and exhaust. Like if you've already done a bunch of work, they will help with that last little bit (at least on a N/A engine, obviously supercharger pulleys are a different story).
    Doug Throrley's Y-pipe claims that their built in resonators help eliminate rasp caused by the headers. I'm actually looking into the URD Y-pipe to use with stock headers and maybe a TRD cat-back to see what it can do for me. I still need to spend some time on the phone with Gadget.
    Can't wait to see the truck all built up!
  17. Feb 14, 2012 at 9:01 AM
    #157
    acdronin
    Can one of you guys link me to these pulleys? I agree with you, it's about eeking out every last drop of power on these engines without the big cost of a s/c.
  18. Feb 14, 2012 at 9:06 AM
    #158
    memario1214
    Colton
    Missoula, MT
    Yeah, I've always really wanted to boost... But then I think hell, I could put that $5k towards a sports car. I'm going after the smaller stuff, but at this point I could have easily bought an S/C with all the money I spent on just the lift stuff even!
    I am kinda thinking of getting the DT Y-Pipe eventually. I have my rear cats cut out right now and have the sound where I like it. I am afraid that adding the headers and therefore removing the front cats may push me over the raspiness boundary. We shall see. I'll play it by ear though. I need to get all of the shit I have lying around onto the truck before I decide to buy any more stuff haha. Lift, wheels, tires, headers, backup cam, pop n lock, xm radio module, ballasts... Spring break is gonna be epic!
  19. Feb 14, 2012 at 9:06 AM
    #159
    memario1214
    Colton
    Missoula, MT
  20. Feb 14, 2012 at 9:10 AM
    #160
    acdronin
