Intake manifold spacer
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bigtear1, May 5, 2018.
  1. May 5, 2018 at 9:22 PM
    Bigtear1
    Bigtear1 [OP] Member
    Binny
    1996 white 2.7 3RZ tacoma
    Doug Thorley headers, thrush muffler, deck plate mod, and intake elbow cut flat.
    Hey guys. Been reading all night following all that's been written about the remake of Tooter's spacer. Who do I contact to get one of these? Any help would be appreciated. From what I have read, someone has started up production again. Thanks, Binny
  2. May 6, 2018 at 3:42 AM
    tcjacado
    tcjacado Well-Known Member
    Is this the same as a throttle body?
  3. May 6, 2018 at 5:19 AM
    Bigtear1
    Binny
    No. This is a spacer that is placed between the cylinder head and intake manifold.
  4. May 6, 2018 at 5:20 AM
    Bigtear1
    Binny
    Throttle body spacer is at the other end.
  5. May 6, 2018 at 8:35 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    send @tooter a private message. maybe he'll answer.
    tooter was last seen: Apr 26, 2018
  6. May 6, 2018 at 9:22 AM
    Bigtear1
    Binny
    Thank you
  7. May 6, 2018 at 2:10 PM
    Tydeorum
    Tydeorum Well-Known Member
    Anderson S.C.
    4x4 SR5
    why use a spacer for the intake?
  8. May 6, 2018 at 2:34 PM
    Bigtear1
    Binny
    Excuse me. Not making more torque. Really just shifting the torque band to a lower range on the scale. I did this on a BMW r1150r years ago by changing the intake tube length and diameter. Very different feel with the bike. According to old post, makes a noticeable difference in the I4 Toyota. My wife always busy my stones that I can never leave my vehicle alone. LOL.
  9. May 6, 2018 at 3:06 PM
    Bigtear1
    Binny
    Someone was put them back into production by limited supply and on demand order years ago. As one of those people have contacted me and said they were for gen2. I have two messages left with companies about purchasing intake flanges. I guess I'll see what happens. Does not sound promising. I would like to confirm with someone that gen2 spacer would not fit gen1. My knowledge is not that extensive. That's why I am trying to get some input from these gurus from years ago.
  10. Jun 14, 2018 at 9:51 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
  11. Jun 14, 2018 at 10:45 PM
    Bigtear1
    Binny
    Thanks for the response. My truck is first gen. Eight hole not four. I had a spacer made from a guy that makes the racing manifolds. I am still gathering parts and will probably do this next week;with new multi hole injectors, EGR block off kit, lce throttle body spacer, and manifold spaced out 1.50 inches. I should be fine. This is my daily driver and runs much better and stronger with headers, deckplate mod, and high flow air filter, and bosal 50 state legal cat. I am sure I will feel enough to be satisfied. Thanks for answering.
    05Taco4x4 likes this.
  12. Jun 14, 2018 at 10:48 PM
    05Taco4x4
    2TR-FE Enthusiast
    1st Gen had both 8 and 4. Are you going to post the results here or do you have a build thread? I'd like to see :D
  13. Jun 15, 2018 at 12:27 AM
    Bigtear1
    Binny
    I will let you know when I do it and show you pix. Right now going through a little flare up with my back. Hoping for next week to do it. What might stretch me a day or two will be after I get it apart, having to get longer bolts/studs. Don't know what I will need until I get old ones out. I will be in touch.
  14. Jun 15, 2018 at 12:30 AM
    Bigtear1
    Binny
    One other thing. After this is done, I am eyeing the URD MAF Calibrator. $210. This should complete the mechanics of what I want to do.
