Interchangeable Parts
Discussion in '1st Gen. Tacomas (1995-2004)' started by RustyYota, Dec 10, 2009.
  1. Dec 10, 2009 at 3:55 PM
    RustyYota
    RustyYota [OP] Active Member
    Dave
    Rust Belt, NY
    TRD Auto
    Toolbox in the summer tenau in the winter, 3in toytec lift, 33'' BFG muds, Tint
    If anyone remembers im the guy with the frame rot issue. I go in monday to hopefully fail my inspection. The local dealer there has a 2001 v6 5spd sr5 ext cab taco with 38,000 miles and it apparently just got a new frame (mechanic spent 30 hours to do it). It will be almost a straight trade. Anyways Im stripping parts off my 2000 ext cab sr5 and Im wondering what will fit the new one. I have the following: Lund bug guards, Lund ventshades, 2.5 rough country lift (coil-over spacers, extended shackles), Westin bull bar thing (the older one), and a trailer light relay that plugs into the tail-lights (are the plugs the same?), and a custom made speaker box that I soldered the original speaker plugs to my wires (are the speaker plugs the same?)
    Thanks I appreciate any input
  2. Dec 10, 2009 at 4:02 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    You mean you're one of many guys:D.
    The two trucks are of the same generation, but different sub-generations (yours is a 1998-2000, while the trade-in's a 2001-2004).
    They're slightly different, mostly in the front, so as far as front bug guard, no, because the hoods are different. Bull bar is also questionable as the bumpers are different, but if the frames are the same, maybe it's possible.
    I know they changed shackles in 1997-1998, so you should be good there, and also coil spacer lift is pretty simple to not be universal for the most part.
    Speakers are also pretty hard to mess up, as there's only 2 wires per speaker, and it kind of doesn't matter which way you plug them in, anyways.
    Don't know about the trailer wiring, but I don't see why Toyota would change them...they did put different taillights in...but not THAT different.
    You should be good. Just take EVERYTHING that you can off of it, and if it doesn't fit, SELL IT!
  3. Dec 10, 2009 at 4:11 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Alberta
    03 2.7L 4x4 5spd
    speakers will work backwards if the wires are crossed. ex: a bass hit makes the speaker move out, if wires are crossed the speaker will move inwards.
  4. Dec 10, 2009 at 4:11 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Sam covered your question pretty well. You may encounter minor differences in electrical connections, or maybe not. I only say this because I found differences in simple plugs and such across the 90-95 4runners. The wiring will be pretty much the same, but there may be differences in wire colors, plug colors, and (in my case) plugs looked very similar for certain components, but were not interchangeable. I found these differnces in 4 runners that were 1 year apart from each other.
    I'm not saying this will be the case, but it might.
  5. Dec 10, 2009 at 4:13 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    I bought a WAAG grill guard off of someone who's 2000 was bought back. The part was listed as 95-2000 (from manufacturer) It mounts oup fine theres just no clearence against the grille. The top support brackets will probably not work. (because the mount to the bumper support, which is different) You can fab your own, get ones for a 2001, or leave them off like me.
    I would check the part number on WEstin's website first. I remember that there was one manufacturer that had the same part for both years.
  6. Dec 10, 2009 at 4:14 PM
    sachou
    Sam
    yup. Won't make a difference, unless you're running multiple subs inside one box.
  7. Dec 10, 2009 at 6:11 PM
    RustyYota
    Dave
    Rust Belt, NY
    TRD Auto
    I also have a tenau cover and toolbox are the box dimensions about the same? All the things I mentioned earlier are already off I'm just curious
  8. Dec 10, 2009 at 6:16 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    they should work fine
  9. Dec 10, 2009 at 6:17 PM
    matthew5olson
    matthew
    pittsburgh, PA
    tool box yes, tonneau not sure. I believe the beds were slightly different dimensions. since the tanneau cover relies on it fit to work you might not be able to use it
  10. Dec 10, 2009 at 6:29 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    i have a lund tri fold cover on my 04 that i bought on craigslist. it was on a 97 so it should work
  11. Dec 11, 2009 at 1:21 PM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    It won't play the song backwards? :p
  12. Dec 11, 2009 at 3:57 PM
    sachou
    Sam
    Only The Stairway to Heaven.
