Intercooler pump relocation!!!
Discussion in 'Performance and Tuning' started by extremachn1, Apr 10, 2012.
  1. Sep 4, 2015 at 3:02 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    How good are you at chemistry/maths? There are actuall a lot of studies on many varying types and grades of steels and the rate at which they corrode over time with given exposure to specific chemicals. I only know this because i have a couple books at work specifically for that perpose. I would be willing to wager that methanol and mild carbon steel are both in there together. You can probably extrapolate the time constant out based on the amount of meth you wanna run and the desired corrosion of the engine.
    BenMara likes this.
  2. Sep 4, 2015 at 3:52 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I probably have those same books if not something similar lol. It's the water along with the extreme temperatures & service environment that make me question the compatibility and long term metal loss. The latter is what gives me pause for running methanol injection in a daily driven vehicle.
  3. Sep 4, 2015 at 3:59 PM
    WOODEX M.E.
    Corey
    Maine
    I hear you. But there are a lot of heavily boosted evo 8s and wrx stis running around with a methanol/water setup setup. Those guys have been out since 03/04 Respectivly. Agreed it is something that merits looking into a little deeper, but i have a hunch its gonna be fine for longevity. We probably have worse things to worry about on our trucks....like the frame lol.
  4. Sep 4, 2015 at 4:02 PM
    Biscuits
    Lol no kidding.
    Again, it could be a complete non issue but I'm of the mind set "better safe than sorry". Like I said, I emailed some folks (a metallurgist & corrosion engineer) about this very subject and I'm keen on what they have to say.
  5. Sep 4, 2015 at 4:03 PM
    WOODEX M.E.
    Corey
    Maine
  6. Sep 4, 2015 at 4:30 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Wow yea, not quite apples to apples, but that does bring alot to mind. The 10 gauge steel with 15% water had a service life of 150 years, immersed in the stuff. Standing by for word from Biscuits metalurgist next week, might hust go ahead and do it.
  7. Sep 4, 2015 at 5:01 PM
    Biscuits
    Consideration of temperature is crucial though. Heat tends to accelerate corrosion.
  8. Sep 4, 2015 at 5:59 PM
    VolcomTacoma
    Jeff
    NorCal
    True. But wouldn't it just burn off? I don't think id be worried about in the short term, as long as i pull apart the SC internals every 50,000 miles and inspect for corrosion, im aure it would be fine. Hmmmmmm
  9. Sep 4, 2015 at 6:22 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What you need to look up is methanol effects on s/c lobes. I cannot say what the concentration levels are on any of the examples you'll find.
    Me personally, if my charge temps were getting to hot, and nothing else was helping, that'd be the next step. With a "decent" mixture of course..
    BenMara likes this.
  10. Sep 4, 2015 at 6:47 PM
    VolcomTacoma
    Jeff
    NorCal
    Yea that was my thought, run it and pull the S/C apart after 50k miles and see if theres any corrosion and if so, decide if i want to stop injection or just replace internal every 50k.
    I can definitely feel a power boost when its 60 degrees in the morning vs close to 90 degrees in the afternoon, so i think cooling my intake temps down would definitely help power alot!
    Wont adding a pulley just increase my blower temps due to faster internals?
  11. Sep 6, 2015 at 10:41 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    @TripleThreat been running water meth for the last 2-3 years.
    My buddy is running 50/50 in his turbo car for the last 3 years and his intake looks better than mine. Yes different setup. Get a nice steam cleaning. Valves and ports are so clean. Only scary issue could be is if your controller keeps spraying non stop. That is pretty rare or you have really sketchy electrical. I'd run meth if I needed it.
  12. Sep 6, 2015 at 11:35 AM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I used water/methanol injection on my 1978 2wd Toyota pickup. I rebuilt the engine and there was no corrosion.
    The stock carburetor died so I put a Weber on it, there was no carb heat. I used 50% water 50% methanol (shellac thinner) in the winter, worked well.
  13. Sep 6, 2015 at 11:44 AM
    VolcomTacoma
    Jeff
    NorCal
    You guys are not helping my wallet lol!
    WOODEX M.E. likes this.
  14. Sep 7, 2015 at 1:11 AM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    back on topic... any progress on relocation?
  15. Mar 26, 2019 at 7:16 PM
    #35
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    dug up this post because I need to relocate mine in order to install a hidden winch bumper. Any ideas?
  16. Mar 26, 2019 at 8:28 PM
    #36
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    I ended up flipping the straps on mine so it "swung" towards the radiator instead of towards the bumper. Took a little flexing in order to get it all to fit right but it allowed me to fit a 10k winch in my bumper without issue.
    scootter82[QUOTED] and BenMara like this.
