Interest in shackle flip for 05+ Taco???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fabjunkie, Apr 20, 2012.
  1. May 21, 2012 at 8:23 AM
    #221
    fabjunkie
    fabjunkie [OP] Well-Known Member
    Here a couple pics of the shackle angles to go with the pics above. There are so many options for mounting the hangers/shackles, everyone is going to have to try different settings to see what they like. With the stock shackles, there are five mounting options. I'll get pics of all three when we get the production model on. Pics below are with the shackle sitting at ~3* at ride height. This gave the best ride with the most shackle movement throughout the articulation range.
    Using longer shackles (XJ or drop Chevy) opens a lot more mounting options.
    Extended (you can see the other side too)
    Compressed
  2. May 21, 2012 at 8:27 AM
    #222
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    Just an FYI... Those are far from ideal shackle angles in those pics.
  3. May 21, 2012 at 8:30 AM
    #223
    fabjunkie
    What would you consider ideal?
  4. May 21, 2012 at 8:35 AM
    #224
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  5. May 21, 2012 at 8:38 AM
    #225
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Pass some over here :cheers:
  6. May 21, 2012 at 8:58 AM
    #226
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    :eek::confused:
  7. May 21, 2012 at 9:03 AM
    #227
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    IIRC they should be at 45 degrees at ride height, at least thats what the LT folks say :notsure:
  8. May 21, 2012 at 9:04 AM
    #228
    arrrghhh
    arrrghhh Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
    Perhaps it's not clear, but those shackle angles fabjunkie posted are from the exact same pics I posted. So right wheel stuffed, left drooped... Not ride height!
    I'd like to hear what Fire931 thinks about it tho - perhaps he was thinking the shackles were at ride height too? :confused:
  9. May 21, 2012 at 9:06 AM
    #229
    blackhawke88
    SGV, CA
    07 TRD Offroad
  10. May 21, 2012 at 9:13 AM
    #230
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  11. May 21, 2012 at 9:15 AM
    #231
    blackhawke88
    SGV, CA
    07 TRD Offroad
    also, IIRC, if you are using stock length leaf packs, then the distance between the front hangar and the rear shackle pivot should NOT change.
  12. May 21, 2012 at 9:18 AM
    #232
    fabjunkie
    LT is a whole other world....
    :popcorn::spy:
    :confused: Source?
  13. May 21, 2012 at 9:24 AM
    #233
    blackhawke88
    SGV, CA
    07 TRD Offroad
    just basing off what I read about certain deaver leaf packs need to have the hangars a specific distance apart from each other. The length of the shackles dont matter, but the shackle pivot and front hanger need to be a specific distance. Whether or not that means the same with stock springs, i am not sure, but i dont see what that would change.
  14. May 21, 2012 at 10:32 AM
    #234
    DonnoD
    DonnoD Well-Known Member
    don
    las vegas
    07 dc 4x4 v6
    the shackle is suppose to be perpendicular to the frame at full droop or even a little less angle to prevent shackle reversal
  15. May 21, 2012 at 11:58 AM
    #235
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    If you move the shackle to the furthest forward hole it should fix it
  16. May 21, 2012 at 1:49 PM
    #236
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Well looks like it has 3 holes of adjustment in the dirrection you all recommend, one over at the top, and two at the bottom. So it's cool? :cool: What leafs are used in the pictures? I have 3" All pro leafs....wonder if it's be same hole settings
    Looks like the stock shackle it kinda short, I might just upgrade to 1" lift ones for my set....might as well have zerks too.
  17. May 21, 2012 at 1:57 PM
    #237
    fabjunkie
    Leafs in the pics are TSB w/ Wheeler's 3-leaf AAL w/ the overload still in.
    The length of the stock shackle is somewhat of a design constraint. Like I said, going to a longer shackle opens up more options for mounting. Other than XJ shackles, Chevy shackles will work also, as long as they are for the 3" wide spring, not the 2.5". I have some stock Chevy shackles here that are 7/8" longer than the stock Tacoma. They also provide a little more clearance. That would be another option with minimal lift.
  18. May 21, 2012 at 7:42 PM
    #238
    weazel
    weazel Well-Known Member
    You guy's have a great product and glad to see you working to get it right. The combination of holes is going to make it really easy for someone to use with any combo.
    Here is a pic of Expo springs 1" XJ shackle at rest
  19. May 21, 2012 at 7:56 PM
    #239
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Are those Chevy Shackles an option when we work on mine?:D
  20. May 21, 2012 at 8:00 PM
    #240
    weazel
    Is the hanger 3" wide or 2.75
