Interest in shackle flip for 05+ Taco???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fabjunkie, Apr 20, 2012.
  1. May 14, 2012 at 5:57 PM
    #161
    weazel
    weazel Well-Known Member
    You will not have a big choice on shocks, 10" is about perfect with expo leafs.
  2. May 14, 2012 at 6:01 PM
    #162
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    Can you run a 50T with these?
  3. May 14, 2012 at 6:45 PM
    #163
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Any recommendations on an extended travel rear shock to use with this flip kit? I'm running the full OME 3" suspension with the Dakars. I'm fairly certain that the standard rear OME shock will be the limiting factor now.
  4. May 14, 2012 at 7:01 PM
    #164
    fabjunkie
    fabjunkie [OP] Well-Known Member
    50T?
    Working on some shock options now. Looks like an 10-11" shock is going to be about perfect.
  5. May 14, 2012 at 7:07 PM
    #165
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
  6. May 14, 2012 at 7:20 PM
    #166
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    I'm interested, but I need to see more to know exactly what I'm getting myself into
  7. May 14, 2012 at 8:18 PM
    #167
    Jib Bandits
    Jib Bandits Pork eating crusader. An "infidel".
    Ari
    Cedar Fort, UT
    06 Access TRD Sport
    Red devil horn emblem, All-Pro Expo leafs, Fox shocks, K&N CAI, aFe throttle body spacer, Flowmaster american thunder dual exhuast, Defender roof rack, Hell Bent steel level kit, Rigid Dually LED lights, smoked halo headlights, smoked LED taillights, Cobra CB, red badge mod(+30 HP), Spider-Trax wheel spacers!
    I've been wanting a shackle flip forever! so once this thing gets really goin count me in. Just redid my whole rear setup with the all pro expos and some fox ext. travel shocks so all I need now is this! and a bump stop :(
  8. May 14, 2012 at 8:18 PM
    #168
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    A
    Wow. So now I know they will be really strong when you weld them to my frame. :D
  9. May 14, 2012 at 8:22 PM
    #169
    Jib Bandits
    Ari
    Cedar Fort, UT
    06 Access TRD Sport
    Holy crap!:eek::eek: Didn't see this post before... I'm in for sure! BUMP to get the new order list growing!!
  10. May 14, 2012 at 9:50 PM
    #170
    Defined
    Defined Well-Known Member
    mike
    southern california
    the 50t pack will not fit in the stock front spring hanger!
  11. May 15, 2012 at 5:21 AM
    #171
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    Glad to see someone else trying to tackle this. There's lots of geometry challenges in there to get it just right. I'm curious though, why all the extra holes in the bracket both where the shackle bolts in and where it bolts to the frame?
  12. May 15, 2012 at 6:03 AM
    #172
    arrrghhh
    arrrghhh Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
    This ^^. Provides for a TON of mounting locations... As was stated you can flip 'em and mount them on the opposite side and get even more mounting locations...
    The shackle flip that grows with you!
  13. May 15, 2012 at 6:04 AM
    #173
    Fire931
    VA
    00 4Runner
    Yea that's what I was assuming, only problem is you can't put the shackle in one of the forward bolt holes because then it can't lay flat under compression. It will hit the bracket, and it's hard to say from the pictures but you can't move the bracket back much or it will hit the bumper brackets which would void those holes as well. Just curious if he had tested for all those things. That's a big part as to why ours isn't back out, just so many variables to work through that eats up some much time and resources. I bet I've got 5 different versions sitting on the shelf, each one an improvement over the last but still issues that prevented it from working perfect.
  14. May 15, 2012 at 9:41 AM
    #174
    fabjunkie
    Yes it's for adjustability. The bumper bracket would need to be trimmed very little to move it rearward. Not enough that it will affect any structural stability of it. With stock springs, there is no need to move it back. The additional shackle mounting holes are more for when a longer spring is used and they're flipped the other way. The first two holes aren't really usable in this configuration unless you're going to a shorter spring, which I haven't seen anyone do and I doubt anyone will. There's a few tweaks before it goes to production to address these issues.
  15. May 15, 2012 at 10:05 AM
    #175
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Looks good dude nice solid welds definitely overkill for a shackle hanger but that's a always a good thing :D
  16. May 15, 2012 at 10:11 AM
    #176
    fabjunkie
    I have a bad habit of overbuilding things....:D
  17. May 15, 2012 at 12:15 PM
    #177
    06harris
    06harris Well-Known Member
    Shawn
    tuckerton rd shamoung NJ
    06 trd sport tacoma4x4
    3in skyjacker coilovers 6inch procomp lift, spc performance uca, skyjacker limit straps, 33in maxxis bighorns, flowmaster 10 series, spare tire holder in bed, 10in almani sub 2000 watt in custom box 1500 watt amp, infinity kappa door speakers dynamated, pioneer DVD touchscreen head unit,k&n cai
    im rocking blocks in my rear for lift ... will that cause any problems?
  18. May 15, 2012 at 12:42 PM
    #178
    arrrghhh
    Denver, CO
    09 TRD Off-Road
    If you 4wheel, probably. I wouldn't flex the suspension out in the rear if I was on blocks anyways...
    Most people that do block lifts know they're just for show - and if you actually wheel with them, you will probably damage the suspension...
    The shackle flip itself shouldn't actually effect the blocks one way or another tho. I was more stating in general.
  19. May 15, 2012 at 12:45 PM
    #179
    06harris
    Shawn
    thank you ,an yeah i know i gota get rid of the blocks asap
  20. May 15, 2012 at 3:31 PM
    #180
    Gramps
    Gramps
    07 TRD DC 4x4
    Yes you do. We need to talk about the 4 door Zombie killer someday. :D
