Interesting thing I found out about the stock jack.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hillbillynwv, Nov 15, 2010.
  1. Nov 15, 2010 at 6:38 AM
    hillbillynwv
    hillbillynwv [OP] Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I was rotating my tires this weekend and discovered that the stock jack is not tall enough to change the front tires. I have 265/75/16 tires with Bilstein 5100's set at 1.75. I had never used this jack and thought I would try it for this tire rotation just to see how it performed. I installed the jack under the frame member where it says to do so but had to put the jack on two 2x10's to be able to use it. Anyone discover this when they tried to use the jack????
  2. Nov 15, 2010 at 6:41 AM
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
    where were you jacking the truck up from?
  3. Nov 15, 2010 at 6:41 AM
    jrdbrn
    jrdbrn Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    Your truck is not stock. It is made for stock. Mine works perfectly fine.
  4. Nov 15, 2010 at 6:42 AM
    FearNothing321
    Tony
    Knoxville, TN
    2019 Audi S3
    x2
  5. Nov 15, 2010 at 6:44 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2. Kinda expected when you lift your truck... It's an emergency use jack only for a stock height truck. Your fix with the 2x lumber is your best bet to lift it and get a jack stand under the frame.
  6. Nov 15, 2010 at 6:46 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    One of the main reasons I'm getting sliders for my truck is for use as a jack point for the hi-lift jack.
  7. Nov 15, 2010 at 6:57 AM
    hillbillynwv
    Fairmont, WV
    I never referenced the manual but the yellow sticker on the jack said to place it where the frame begins to curve near the cross member. Looking from the outside it would be about lined up with side mirror on the door.
  8. Nov 15, 2010 at 7:29 AM
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '18 Tundra Platnium
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    Thats why I carry some 2x4 in the cubbies to give a bigger platform for one, and to stack to get more lift from it. Or get a longer travel bottle jack that some have suggested...oh and my floor jack wont get the rears off unless i jack from the pumpkin.
  9. Nov 15, 2010 at 7:39 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I don't know what everyone's problem is, but my stock jack works just fine. I put it under the transmission cross member and it has no problem lift a front tire off the ground. so your doing it wrong.
  10. Nov 15, 2010 at 8:14 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    Under the transmission cross member isn't a jack point...
  11. Nov 15, 2010 at 9:15 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    quick glance...it IS a jack point..not a support points..right?
  12. Nov 15, 2010 at 9:20 AM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    I just take it to the tire shop $5 buks for rotation
  13. Nov 15, 2010 at 9:22 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Ya with my Camburg 4" lift spindles keeping the travel I found it extremely hard to change the front tires in case of a flat. So I went out bought some Avid sliders and a 60" farm jack from Harbor Freight!
  14. Nov 15, 2010 at 9:40 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Nah, he calls AAA.
  15. Nov 15, 2010 at 9:41 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    No, those are different places. The front jack point is that little round spot on the frame cross-memeber bracketed by the front and rear splash guards.
  16. Nov 15, 2010 at 9:42 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    X2 that's what I pay them for i do have wood blocks in the back of the truck just in case. But I'll have sliders and a high lift in a month or two.
  17. Nov 15, 2010 at 10:06 AM
    hillbillynwv
    Fairmont, WV
    I say Toyota needs to supply a jack that interlocks with the a-arm. It wouldn't make any difference then what size tire or lift that you have.
  18. Nov 15, 2010 at 10:25 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    lift your truck a couple inches and you have to put a couple inches under the jack to make it work....yup, that sounds about right
  19. Nov 15, 2010 at 10:45 AM
    kjf216
    kjf216 Fitz
    Kyle
    Ridley Park, PA
    2016 Jeep Wrangler Sahara
    Head unit, speakers, LEDs
    my trucks stock and i can just barely get the truck high enough to get the front tires out. toyota really could have given us a little bigger jack.
  20. Nov 15, 2010 at 10:55 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    They need to supply those bottle jacks that can extend by Twisting the top part
