Intermittent air problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by michaman, Oct 4, 2020.
  1. Oct 4, 2020 at 8:09 AM
    michaman
    michaman [OP] Active Member
    Michael
    2005 Desert sand mica Tacoma 4x4
    I have had 3 occasions now that the air in my truck will not work. When I turn fan on, nothing at all happens (heat or a/c). On the first 2 occasions, the air worked again the next time I started my truck up. On this 3rd and last time it happened, the air didn't work for about 3 days. But then it worked fine again on my way home from work one day. Probably a matter of time before it quits for good, so I would like to resolve the problem now. Any suggestions?
  2. Oct 4, 2020 at 8:17 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I think I'd begin checking fuses, then switch, then fan motor, then wiring.
    Look for breaks, loose connections, burnt connectors........
    Meanwhile, you probably need to use Ol' School climate control. Roll down the window for cooling, Roll up for less cooling.
  3. Oct 4, 2020 at 8:18 AM
    medic2230
    Murph
    Bama! Roll Tide
    Known problem with these trucks. Check the resistor on the blower motor.
    Sandman614 and jbaker1976 like this.
  4. Oct 4, 2020 at 8:45 AM
    michaman
    Michael
    thanks
  5. Oct 5, 2020 at 5:51 AM
    Taccat
    Taccat 2009 Base
    Caribbean
    2009 Base
    Toyota now recommends 3rd gen resistor and connector kit for 2nd gen.
    jbaker1976 likes this.
  6. Oct 5, 2020 at 6:00 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Does it work on high speed?
  7. Oct 5, 2020 at 6:13 AM
    TacoDia
    TacoDia Well-Known Member
    St. Louis
    11 DCSB SR5 V6 OME Kit H-Dakars
    When I had this problem it turned out to be a my power connection to the fan. Passengers were kicking/pressing their shoes against it and caused a short. Figured out it was that by leaving the fan on at all speeds and then moving the connection around and it would kick on and off. Ended up replacing both the fan and power line.
    Sandman614 likes this.
  8. Oct 5, 2020 at 6:45 AM
    jbaker1976
    jbaker1976 It's always Taco Tuesday
    East TN
    2015 DCSB OR
    Camper shell with side windoors and bed slider, JL Audio Component Door Speakers, JL Audio Stealth box, Grill Craft Grill, Husky floor liners, Hondo Radio knobs, Predator steps, Remote Start, Pop N Lock, etc...
    x3 on the resistor
  9. Oct 5, 2020 at 6:50 AM
    scflyntaco
    scflyntaco Well-Known Member
    brandon
    09 tacoma sport
    lift, supercharger, trd exhaust
    Its absolutely the resistor! Mine was doing the same thing last week. I picked up one from oreiley, comes with a resistor and pig tail. I recommend changing the pigtail as well.
  10. Oct 5, 2020 at 6:53 AM
    jbaker1976
    East TN
    2015 DCSB OR
    I have replaced my fan switch resistor twice. The first replacement lasted about a month.
  11. Oct 5, 2020 at 7:22 AM
    Taco'09
    Taco'09 Well-Known Member
    Suppose you could elaborate a bit more about this?
  12. Oct 5, 2020 at 7:40 AM
    Muddinfun
    Muddinfun Well-Known Member
    Fan speed checklist.
    Fan doesn’t work on any speed - motor connector
    Fan only works on high - resistor and resistor connector
    Fan works on all speeds except high - climate control panel and connector
    Jimmyh likes this.
  13. Oct 5, 2020 at 5:30 PM
    cee_gee_ess
    cee_gee_ess Member
    2010 Pyrite Mica TRD Sport Double Cab 4wd
    I keep an old umbrella in my passenger floor board to give the squirrel cage assembly a big whack when this happens.
    whatstcp likes this.
  14. Oct 6, 2020 at 4:44 AM
    Taccat
    Taccat 2009 Base
    Caribbean
    2009 Base
  15. Oct 6, 2020 at 4:55 AM
    Taccat
    Taccat 2009 Base
    Caribbean
    2009 Base
