Intermittent CEL PO171 &174
Discussion in '1st Gen. Tacomas (1995-2004)' started by Snafu, Apr 16, 2013.
  1. Apr 16, 2013 at 4:41 PM
    Snafu
    Snafu [OP] Member
    central texas
    05 4x4 V6 , 86 Turbo
    2005 v6 tacoma. Have been plagued for month's with intermittent CEL light that no dealership could trace or cure. Symptoms include very rough idle when hot and not moving, erratic take off from stop sign and even dying one time and reluctantly starting. $180 for bank one sensors and much pain installing the one closest to the firewall--- wrong wild ass guess. One dealer said it was due to the gasket for the mass air flow sensor, so they installed a new one -reset CEL. Made 30 miles before CEL reappeared. New stealership checked fuel pressure and it was 35 and should be around 41. They had no parts and $980 installed for fuel pump seems bloated. nice website.
  2. Apr 16, 2013 at 6:07 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    P0171 and P0174 are for fuel system lean. That means the computer is reading the incorrect level of oxygen content in the exhaust. Since it is BOTH banks that are affected, the highest probable cause is a vacuum leak. This is not a guarantee mind you, but the highest likelihood. The only way to properly diagnose these codes is to know what the actual readings are for both banks, short term AND long term. Without that information you will be just throwing parts and hoping to get lucky. Can you get this data?
  3. Apr 16, 2013 at 6:57 PM
    Snafu
    Snafu [OP] Member
    central texas
    Have records of five different CEL.
    1 2 3 4 5
    STfuel trim 3.1 (.8) 0 7.0 3.9
    st fuel tr2 3.9 0 0 (.8) 3.9
    ltfueltri 37.5 37.5 35.2 36.7 35.2
    ltfueltri 2 35.9 35.2 31.3 39.1 29.7
  4. Apr 16, 2013 at 7:17 PM
    BamaToy1997
    Bill
    Navarre, FL
    Short term fuel trim is not really the numbers to concern yourself with. They are a quick response to current stimuli. The Long Term is where the information is at unless you are doing active testing. Numbers that high on your long term trim are SCREAMING vacuum leak as a likely cause.
    That being said, a vacuum leak can be internal or external. An example of an internal vacuum leak is a stuck EGR valve. (While this would not typically cause a fuel trim lean condition, it can affect the calculations due to the fact that a leaking EGR valve allows unmetered air into the engine) Also a bad PCV valve can cause erratic fuel trim as this is also unmetered air. Basically ANY air that enters the cylinder that is not either expected (In the case of a properly operating PCV valve, or EGR valve) or measured by the MAF sensor, is considered unmetered, and a possible source of incorrect fuel trim readings.
  5. Apr 17, 2013 at 12:35 PM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    If you haven't already tried it, you might clean your MAF sensor, using special MAF sensor cleaner.
    Are you running a TRD, K&N or other washable filter?
  6. Jun 3, 2013 at 1:03 PM
    mark1257
    mark1257 Member
    mark
    ga
    05 Prerunner
    I had the same problem with my 2005.
    I changed the MAF and the dealer diagnosis "twice" was the fuel ratio sensors.
    The problem is the fuel pump!!!!!
    The real problem is the filter/screen attached to the pump,its flat and small.
    I don't know if you can just buy the screen.
    I bought a denso fuel pump kit from advance auto parts for just over $100.00,its a pump and filter. Easy to change.
  7. Jun 3, 2013 at 7:53 PM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
    Would probably get more personal responses in the 2nd gen forum.. Though bamaboy is a guru of excellence
  8. Jun 4, 2013 at 2:08 PM
    Snafu
    Snafu [OP] Member
    central texas
    Thanks Mark. Gonna do it.
  9. May 15, 2014 at 8:08 AM
    skygear
    skygear                    
    Mine did the same over the weekend. I think it is the pump. But after doing all the routine changes. I'm seemingly back to normal. I will drop the fuel tank and swap out the pump just to be sure. I mean, It has a little over 135k on it with no filter change or pump.
  10. May 15, 2014 at 8:09 AM
    skygear
    skygear                    
    Reason I found this thread was I decided to search some more.
