Intermittent Left Front Speakers...Loose RCA?
Discussion in 'Audio & Video' started by IrishPilot, Feb 10, 2010.
  1. Feb 10, 2010 at 6:04 PM
    IrishPilot
    IrishPilot [OP] Well-Known Member
    MN
    09 TRD Off-Road 4x4 Double Cab
    My ongoing aftermarket woes continue.
    My front left speakers seem to come and go today. Would that likely be a loose RCA or something more consuming?
  2. Feb 10, 2010 at 7:07 PM
    tacomarock
    tacomarock Well-Known Member
    Irish, I have an audio system in my truck but I am not expert. But I would think even experts will need as much detail as you can provide. Just my input. :)
  3. Feb 10, 2010 at 7:22 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    I can just give you my experience with a similar situation
    I had a JL 300/4 wired up and working perfectly.
    I had one speaker randomly cutting in and out for months. I finally pulled all of the wire and rewired the speakers themselve with no improvement
    then I realized that I could push on the headunit and cause the front left to cut out
    turns out, the head unit was so deep that the wires were jammed behind it and had put a kink in the RCA wire connector. over time the cable broke down inside.
    changed the RCA and it was good to go
    I would start wiggling connections and see if you can create the symptom
    good luck
    Justin
  4. Feb 10, 2010 at 7:55 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I'd check the speaker connections too. RCA's are usually pretty tight and don't really come loose. If a shop used those spade connectors on the speakers it might be loose.
