Intermittent No Start Condition (long cranking before starting)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jar-sr5, Sep 18, 2009.
  1. Feb 8, 2011 at 12:16 PM
    Killian
    Killian Member
    Normal, IL
    '10 Super White TRD Sport Double Cab
    I've had this same problem as well on my 2010. Happens about once a month since the day I got it. I will probably just mention it to the dealership next time I am in there. It is very frustrating.
  2. Feb 8, 2011 at 12:24 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    My 07 had that issue the first week I owned it...took it in and after the tsb was performed it hasn't happened since.
  3. Feb 8, 2011 at 12:47 PM
    hansonian
    hansonian swims with fishes
    Tampa, FL
    2010 Double Cab PreRunner SR5
    Stock
    My 07 does it. The first couple times where when it got cold so I assumed it was due to the weather. Now it doesn't care about the temp. I was thinking about swapping out the plugs to see if that helps before I let the dealer touch it.
  4. Feb 8, 2011 at 1:17 PM
    XSB41
    XSB41 If I had a hammer...
    Rik
    Va.
    2010 SR5 4X4
    hitch haul, bed extender, bed mat, behind seat gun rack, roof rack
    Subscribed...off/on prob, catalytic converter a mother too, extreme egger at times...
  5. Feb 8, 2011 at 5:31 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    UPDATE: I was having this problem. From what I heard in another thread, it takes a second for it to sense the chip in the key after you put it in the ignition. If it doesn't sense the chip in the key, the fuel pump is shut down.
    So basically don't stick the key in and instantly turn it. Wait a second. I've gotten into the habit of getting in the truck, putting the key in the ignition, fastening my seatbelt, and then starting it. I haven't had the problem since.
  6. Feb 9, 2011 at 11:02 AM
    johnny 5
    johnny 5 Well-Known Member
    wisconsin
    Black 07 TRD Off road 4x4
    7-6'' sno-way plow w/DP
    It's the Toyota way of prelubing the motor before starting
  7. Feb 9, 2011 at 11:10 AM
    tonyplanet
    tonyplanet Well-Known Member
    Glendora, CA
    09 Tacoma 4x4 TRD Off-Road
    enough to get me there
    Happens to me only when my car stalls out. I have a manual tranny. And it happens only when I try start right after my truck stalls out. It's frustrating when it happens, but doesn't happen very often.
  8. Nov 29, 2011 at 6:02 AM
    bschmitt09
    bschmitt09 Active Member
    Western WA
    2011 TRD Off-Road Access Cab
    Bump. My 2011 is exhibiting this problem. What about any other '11 owners?
    Happened ~5 times already w/ <8K miles on the truck. I've tried leaving the key in the ON position for about 3 seconds to let the computer recognize the key and the fuel pump build up pressure, but it doesn't fix the problem. Guess the TSB is the next course of action. Yippie.
  9. Nov 29, 2011 at 6:09 AM
    Cbass38
    Cbass38 Well-Known Member
    sebastian
    scottsdale
    07 pre runner
    projector hids,wheels,small lift,flowmaster
    thats generally a fuel delivery problem. alot of our chrysler jeep and dodge cars have that.its always the fuel pump or pressure regulator. pressure bleeds down over night so when u go to crank it the pump cant make enough pressure... so ya turn it off and back on,which re primes the system and gets the pressure back up to where it needs to be. just a possiblity
  10. Nov 29, 2011 at 6:46 AM
    JPasquini
    JPasquini Member
    New York
    2011 Tacoma TDR Sport DCLB
    None yet
    My new 2011 DC Sport (less than 3k miles on it) is also exhibiting the same (and very intermittent) problem. When it does happen, it will fire right up on the second attempt EVERY TIME.
    Took it into the dealer who said, of course, that the "computer" didn't find any trouble codes, so everything must be fine and that the truck was operating "within normal characteristics." :confused: The advisor did say the previous TSB could be extended to later model years if enough 2011's are brought in for the problem, but that it unfortunately does not apply at this time.
    FWIW, I did find that the ground connection from the battery to the chassis was not very tight.... tightened it up myself in a few seconds. I doubt that's the cause in this case, but it can't hurt.
    As a side bar, I LOVE my truck, but this sort of silliness is slowly starting me to question Toyota's committment to their build quality.
  11. Nov 29, 2011 at 7:02 AM
    Tippett's TRD
    Tippett's TRD Well-Known Member
    Josh Tippett
    Lake Linganore, Maryland
    2010 Speedway Dbl Cab L/B 4x4
    6" Pro Comp Suspension Lift, LEER Cap, NFAB Nerf Bars, Avid Off-road Bar, K&N Intake, Weathertech Liners, 2011 Grille, BedRug, Westin Taillight Guards, Tinted Windows, RedLine Hood Struts, Mag Lite Mod, Stubbie Antenna...
    My 2010 does this only when it is cold out... I took it back to the dealership last winter and they said that they didn't notice any problems.
    It is definitely intermittent... but still pisses me off on a new truck
  12. Nov 29, 2011 at 7:12 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I dnt have time to read the whole thread but don't forget you can't just turn the key all the way over guys.... go to RUN. Wait a second for the fuel to prime THEN start.
  13. Nov 29, 2011 at 7:28 AM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    Mines done it about 4X since I bought it...I chalked it up to insufficient fuel pressure at the rail as it fires up every time on the second attempt. When mine does it, it cranks for an abnormally long time, starts/stumbles then dies out within less than 1 second. Is this what is being referred to here?
    The problem only happens once in a great while, fuel type and temperature (of engine or atmospheric) doesn't seem consistent to give it to a dealer with any valid information...also, no stored codes for the stalling:mad:
  14. Nov 29, 2011 at 7:38 AM
    bschmitt09
    Western WA
    Yep, same issue I bumped the thread for. I was just wondering if any other 2011's were having the same problem that can be attributed to the TSB mention earlier in the thread. It appears they are, but Toyota isn't willing to own up to any model years post 2007.
  15. Nov 29, 2011 at 4:39 PM
    #35
    OffroadToy
    That may work but but you shouldn't have to do that on these trucks. My problem back in 07 was it wouldn't start alot of times unless I pumped the gas pedal first. After getting the ECM recalibrated via the tsb the problem went away completely...now I just turn the key and it starts right up everytime.
  16. Nov 30, 2011 at 1:58 PM
    #36
    vpcustoms
    vpcustoms Well-Known Member
    2017 Double Cab 4X4 TRD Sport
    It’s been about a year since I had the TSB done for the excessive cranking and it just started doing it again about 3 weeks ago. It always starts right up the second time but I hate when it happens anyway. First time it happened was about 2 weeks after I bought it, drove over to a buddy’s house and he was checking it out. As I was getting ready to leave I turned the key and it just cranked and cranked :eek:. I was like oh shit. Dealer wants to try to duplicate it so they can diagnose it but it is so speratic that it would be a waste of time to start it and shut it off over and over again.
  17. Feb 10, 2016 at 3:27 PM
    #37
    huntnfishrig
    huntnfishrig Active Member
    NJ
    14 DCSB Off Road
    Bilstein 5100s at .85, 265/75r16 BFG ATKO2, Mickey Thompson Baja Locks 3 5/8th backspacing.
    Digging this thread up. I have the same problem on my 14. It has done it a few times since I bought it new. Today was the worst, long crank followed by start and stumble until stall. Has anyone remedied this? I work out of town and get nervous every time it fails to start. No codes.
  18. Feb 10, 2016 at 4:43 PM
    #38
    vpcustoms
    My 06 hasn't done it in a long time but sucks when it happens. The good thing is in the end it has always started. Still sucks but it is what it is I guess
  19. Feb 10, 2016 at 8:08 PM
    #39
    TacoEngineer23
    TacoEngineer23 Well-Known Member
    NJ
    2022 Tacoma Sport DCB 6MT
